Question about Kodak i2400 - document scanner
Scanned data is not readable
Characters are not readable
The labels/stickers on the bottom of my laptop are not readable.i need to find it please help.i would greatly appreciate it.
I believe you are pertaining to the COA Sticker (Certificate of Authenticity) and you need the product key of your Windows. Here's what you can do do get one:
1. Try to check for a part number on the sticker (provided some part are readable). The part number's format would be X12-12345. Contact Microsoft Support at 1-800-936-5700 and have them generate one for you. They can generate a product key based on the part number. Note that you might be charged 10$ for this.
If the information you need on the sticker is the model of your computer, you can easily look for the name on top of the laptop. You should see some numbers like "dv6000" etc.
Mar 05, 2011 | Computers & Internet
I want to program my LS2208 Symbol following: ? Baud Rate ? 9600 ? No Parity ? 8 data bits and 1 stop bit ? A prefix character of the tilde (~) character ? A Carriage Return (CR) suffix character
In order to program the device please refer to the "Programming Reference" on the guide available on this link.
There are sample codes you can scan to set up the device as per your requirements listed above.
If this doesn't work for you, please comment and let me know, and I will be happy to assist you to further resolve your issue.
I will appreciate your feedback and positive rating for this solution.
Thank you.
Nov 03, 2010 | Symbol LS2208-7AZK0100S Handheld
What would I put under the suffix and prefix when bar coding? My scanner is Symbole LS 2208
Hello Norma, you can use the suffix or prefix to send characters, which are not included in the barcodes tgehter with the scanned barcode data.
If you dont need any character before or after the data, you can leave it blank.
It is usually used to add an Enter or Tab to switch to the next line, while scanning to some application like excel.
Nov 02, 2010 | Symbol LS2208 Handheld
SPACE problem. Hello i have Symbol LS 2208. I need remove space/gap from this code 09/ 5864 I tried to create rule for this (remove all spaces) but it wasn´t work - the scanner scaned no data. I use...
Hello, if all your barcodes have the same structure, it will an easy task. You would need to scan following barcodes from ADF chapter in the Product Reference Guide located at http://support.symbol.com/support/search.do?cmd=displayKC&docType=kc&externalId=5880807apdf
Create New Rule Send Characters Up To Space Character in Alfanumeric Section Skip Ahead 1 Send All That Remains Save Rule
This will by all scanned barcodes send all characters up to the space character, skip the space and send the rest of data.
Oct 22, 2010 | Symbol LS 2208 Barcode Scanner - P/N...
I cant join a chatroom coz i not complete the varification to retype the characters on the skrin
You need to input the correct verification characters on the screen. If you can't read it, there is an option where you can change another characters that are readable. just click it then type it correctly. Capitals should be capitals and small should be small.
Jan 03, 2010 | Yahoo Messenger
Total available char can be scan
The number of characters read is defined in your application and the width of the printed bar code. Also the width of the laser or ccd. One program to develop applications JobGen Plus de Unitech.
Roberto Martinez
Aug 16, 2009 | Unitech PT630 Portable Terminal
When scanning, the scanned page is not readable from a third of the page down to two thirds of the page.
It is important that the item you scan comes in close contact with the scanner glass. If the resulting scanned image is not clear, check to see that the item is in full contact with the scanner glass. The scanner uses optical character recognition (OCR) to convert text on a page to text that you can edit on your computer.
  • If you scan text but cannot edit it, make sure that you make the following selections during scanning:
  • Scanned text might not appear on your computer exactly as it appeared on the original, especially if the original contains faint or smudged text. For example, some characters might be incorrect or missing. As you edit the text, compare the scanned text against the original, and then make corrections as necessary.
  • To change text scanning options, click the Scan Document Settings button in the initial What are you scanning? screen.
  • The OCR software is installed by default when you install the HP Scanning software during scanner setup. If you use the Custom option when installing the software, you can choose not to install the OCR software. Try reinstalling the software using the default install options.
  • Email to jdiaz@coretec.us
  • If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
    Thanks, Joe
Nov 07, 2008 | HP Office Equipment & Supplies
Kodak i2400 - document scanner Logo
16 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
