Question about Sony UY-S100 Film Scanner
Scanner error Error Code :09 87 E7 / I install my scanner S100 but when I double clihe on the shortcut this message come, t
My sharp copier AR-5316, is showing error message E7. How do I clear it and solve the problem. Please I need urgent assistance.
For proper understanding of the error meainig it is necessary to obtain a Subcode of the error by pressing START at the moment of displaying error. E7-02 and E7-16 means Laser unit problems, E7-01 problem with memory, E7-10,11,12 Scanner problems Posted on Aug 16, 2016 -2017
Jul 29, 2016 | Sharp Ar 5316
Error code 0x80070005
Easy Way to Fix Error Code 0X80070005 - YouTube
? 4:04
https://www.youtube.com/watch?v=n9mHnVFrxUE
Aug 8, 2014 - Uploaded by Windows Error Support
Error 0X80070005 is a typical Windows Error Code. This error usually occurs during installation or Windows ..
Nov 17, 2015 | Microsoft Windows 7 Ultimate for PC
I have E7 and machine won't work????
E7 sounds like an error code. First step is to look it up in your owner's manual.
Aug 26, 2014 | Singer Sewing Machines
E7 ERROR CODE
when the E7 code comes their is sub code u can view it by pressing start key then we can guest how ever i think this is coming from scanner ccd or chick ribbon cable connecting to the mother board from c c d
Jan 14, 2014 | Toshiba e-Studio 161 Copier Copier
Hi my copier displays E7
Check this out :
E7 codes deal with the optical scanner unit and or the laser unit. It could also be the lamp in the scanner unit. The E7 is the main code. There is a sub code associated with it. To view the sub code hold down the start button. Below is a list of specific codes and their meanings:
E7-02: LSU trouble
E7-10: Shading trouble (Black Correction)
E7-11: Shading trouble (White Correction)
E7-12: Shading Trouble
E7-16: Abnormal laser output
If it is a laser (LSU) issue then the LSU may need replacing.
If it is a shading error the first step is to remove the platen glass carefully (with the power off because the inverter board). There is a thin white strip on the bottom side of the platen next to the **** glass. Clean this white strip with a soft cloth and a small amout of isopropyl alcohol.
Dust on the optics can also cause shading reference errors so gently blow off the mirrors with canned air.
Perform the following key procedure to reset error:
"#" key, Interrupt key, "C" key, Interrupt key
"1" key, "4"key
Start key, "CA" key.
See if unit cycles and comes back up. If not turn off and then back on the main power.
If error reappears on site technical service may be required.
Oct 31, 2010 | Sharp AR-5316 Advanced Digital Imager...
Copier not working shows a flashing L on display
Sharp AL-1553 code
E7 03 Scanner position error 04 Exposure lamp blown 05 CCD calibration error 12 White level calibration error 14 Main board malfunction 15 Exposure lamp blown L1 00 Scanner position error L3 00 Scanner position error L4 01 Main motor drive overloaded L6 10 Polygon mirror motor not up to speed H2 00 Fusing unit temperature error H3 00 Overheated fusing unit H4 00 The fusing unit doesn't heat up U2 01 Counter error 04 EPROM error CH blinking Dev unit is not properly installed
Nov 18, 2008 | Office Equipment & Supplies
AR-5132 Error code E7 13
CCD calibration error. Make sure the optics are clean in the machine in the scanner and free of dust.
Nov 03, 2008 | Sharp AR-5316 Advanced Digital Imager...
E 7 sub code 20
the error code is E 7 - 02 cant find solution, help
Oct 13, 2008 | Sharp AR-5316 Advanced Digital Imager...
E7 problem
E7-02: LSU trouble
If it is a shading error the first step is to remove the platen glass carefully (with the power off because the inverter board). There is a thin white strip on the bottom side of the platen next to the slit glass. Clean this white strip with a soft cloth and a small amout of isopropyl alcohol.
"1" key, "4"key
Jan 06, 2008 | Sharp AR-5316 Advanced Digital Imager...
Sony UY-S100 Film Scanner Logo
Top Sony Office Equipment & Supplies Experts
shaun taylor
Jaime Hernandez
Are you a Sony Office Equipment and Supply Expert? Answer questions, earn points and help others
