Question about Cozy Heating & Cooling
Thrmopile pilot ignitor for w 505 d - Cozy Heating & Cooling
  • 49 Answers
It is a 750 millivolt(mv) pilot generator, can pick one up at local hardware store.
Posted on Apr 06, 2015
Need to relight pilot light on MDG6200AWW gas dryer.
That unit has an electronic ignitor. You should not have to lite the pilot. There is no pilot to lite. If the dryer is taking longer then normal to heat. Check your vent to the outside. If the ignitor is not turning on it could be the ignitor, flame sensor and or thermal fuse. Check D.I.Y. Appliance Repair Troubleshooting to see if there is anything that can help you there.
Mar 28, 2013 | Maytag Atlantis MDG7400AW Gas Dryer
Pilot lights but ignitor still igniting and burners will not light.
check if pilot flame reaches the ignitor tip, if it does, check the connection of or replace the ignitor cable.if it does not, adjust he ignitor so that pilot flame will have good contact with the ignitor.
Mar 07, 2011 | Pitco Frialator SG14 Deep Fryer
I have a SG14T-JS that has six burners. They all light and stay on for about 10 seconds and then they go out. I cleaned the spark ignitor and cleaned the gas valve connection. Do you have any ideas? ...
Hi there.
Make sure that the gas supply has the same rating and type as written on the nameplate.
Check also the gap of the spark ignitor to the pilot. Spark ignitor also acts as flame sensor for pilot flame proving, it if could not properly sense/ detect pilot flame (in case pilot flame weakens during operation due to low gas supply), it will shut the burners.
Regards.
Nov 08, 2010 | Pitco Frialator SG14 Deep Fryer
Pilot lights but burner won't light. Display continues to read SPK
On these units, the pilot ignitor and the pilot rectefier are the same part. The pilot can be lit, but not be sensed by the rectefier/ignitor. This will keep your burner tray from igniting. You need to replace the ignitor assembley. If it is the same as the raypak digital 406a I charge about $75 for that part, and it takes about 20 minutes to install. Need the part or more help e-mail me. adamh@newconceptchem.com
Oct 22, 2010 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
The oven pilot does not light. The broiler will not work. The only thing that does is the light. GE XL44 range. The burners light and the pilots stay lit.
    If you have standing pilots, make sure the pilot for the oven/broiler is lit as well.  When you turn the thermostat up to call for heat, you should see the pilot get larger. That larger pilot flame heats a hydraulic sensor and opens the main burner valve.
    Jan 10, 2010 | GE Profile Spectra JGBP90 Gas Kitchen...
    Kenmore gas oven won't light. The pilot light is on but no gas. What do I do?
    Put a torch on the probe. If the flame comes on them the thermocouple is weak.If nothing at all replace the safety valve.That is if you have a standing pilot. If you pilot is an electric one then it should be so bright it is hard to look at but if it is dim orange it is weak.
    Sep 07, 2009 | Kenmore 30169 Electric Single Oven
    Oven not receiving any gas but pilot is working
    Sounds like you have a weak ignitor (pilot lite) . The ignitor has to turn white hot , not red , orange , but white , to open the gas valve . Replace the electronic ignitor and that should get the oven working .
    Aug 16, 2009 | Danby D9604 Refrigerator With Ice Box
    Raypak 207a ignition issue
    Is the ignitor sparking when it clicks?  If no spark then bad ignitor.  Is gas flowing to pilot?  If no gas then clogged line or bad pilot gas valve.
    May 29, 2009 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
    Oven doesn't work but the pilot light is on
    Hi, Does this have a standing pilot or is it electrinc start? If it is electronic start, and the ignitor glows but you get no flame, you will need to change the ignitor. Even tho it glows, it is to weak to open up the gas valve.
    If you find that you need an ignitor, I can give you my web site and you could order the ignitor from me. I have very competative prices.
    Thanks
    Vic
    May 11, 2009 | Whirlpool GS460 Gas Kitchen Range
    Pilot lit, ignitor glowing, oven will not light
    A pilot light and a ignitor do the same thing. no unit would have both.
    Perhaps you are confusing the thermo-coupling for an ignitor. An ignitor (glow plug style) is ceramic with a conductive coating on the end powered by electricity supplied by two high temperature coated wires that connect to the oven controller.
    A replaceable thermo-couple looks like a copper tube with a elongated bulb at one end and a fitting at the other. The bulb is placed in the pilot flame and the fitting screws into the gas valve.
    I am looking at a exploded diagram for the model number you listed. The unit uses a "safety valve" with the thermo-couple incorporated into it. To see the exploded view, click here If
    you are asked for a model #, use CPL1100ADW. In section 2, gas controls, Diagram location 17 is the safety valve. Click on the part photo for a better view of the valve.
    If you have any questions, let me know. Hope this gets your unit up and running again.
    Please take the time to give this solution a fix ya rating,
    clarkco
    Feb 19, 2009 | Magic Chef CPL1100AD Gas Kitchen Range
    Heating & Cooling Logo
    42 people viewed this question
    Top Cozy Heating & Cooling Experts
    paulcarew
    Dan Webster
    Dan Webster
    jdthefixer
    Are you a Cozy Heating and Cooling Expert? Answer questions, earn points and help others
