Question about Homelite Electric Chain Saw
Oil leaks out when just sitting
Oil leaks before getting to the chain
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 50 Answers
Clean out the oiler holes, probably clogged up.
Posted on Jul 22, 2014
Husqvarna bar oil leak? I have a Husqvarna 55 Rancher. After it has been sitting for a while, there is a puddle of bar oil underneath it. After removing the bar and chain, then the clutch and starter...
There is always going to be some oil under the saw, the pump is a constent loss system, oil onto the bar and chain and away, there is a lot of areas in the crankcase and chain brake for oil to get caught and drip out once the machine is set down, if the oil loss is not excesive i would say yjere is nothing wrong here.
Mar 08, 2013 | Garden
Husqvarna chainsaw 450 oil leak
The 450 has a very simple non adjustable pump, it sits through a black rubber pick up/delivery pipe, they are quite prone to leaking where the pipe sits up against the crankcase, the part no. of the pipe is 544084201, changing this will help, you can also try using instant gasket to seal it, you will need to remove the clutch , sprocket, and pump plate to get acsess to it.
Oct 19, 2012 | Husqvarna 450 e-series 18" Chain Saw
Puddle of oil in case when not in use. If using it then shut off and sit it down leaves puddle of oil where it was sitting.
There will always be an amount of oil on the bottom of the saw, the oiling system is a constant loss system ie onto the chain and away, there are many places for the oil spray to sit in covers, which when sat will drip out, they rely on saw dust to dry the oil up, however if there is not a great deal of saw dust about the oil will not get dryed up and will drip under the saw.Unless the oil leak is excessive i would leave well alone.
Aug 01, 2011 | Poulan Pro Chain Saw 46cc 20"
Will it harm my Makita Chain Saw to store it on its side when not in use? If I stand it the right way up the oil leaks out.
There is no problem storing it on its side, you could also sit it in a tray to catch any oil, it is not uncommon on many machines to find chain oil under them after they have been left.
Jan 26, 2011 | Makita DCS51018 18" 45cc Chain Saw 2 Cycle
My chain saw (14 inch gas powered) would not
Modern chainsaws have the ability to run without turning the chain via the chain-brake. To set the brake the uppermost handle is pushed forward (toward the chain) and a firm snap should be heard and felt. To release the brake you pull the same handle back (towards the engine) and get the same "snap".
Concerning oil leakage: Bar/chain lube collects on the inside of the clutch cover and the sawdust mixes with it as you saw. A surprising amount of oil gets absorbed in the sawdust and later seeps back out when the saw is at rest. If the level of oil in the tank noticably drops after sitting overnight you may have a leak...otherwise it's normal.
As for a running chain that wont cut, it is common for chains to be installed backward and the unit still function perfectly (it just won't cut wood). See the proper chain orientation here. In this photo the chain travel is from left to right.
Sep 26, 2009 | Homelite Consumer Products 9.0 Amp, 14 In....
Craftsman 2.3 14" / Poulan 1800 auto oiler leaking
Loosten the oil filler cap before putting it away. The tank is pressurized to force oil to the chain. Relieve the pressure before storing. Lou
Jun 05, 2009 | Poulan 1630 16" Chain Saw
Chainsaw leaks chain oil when not in use
You might try loosing the oil cap on the chain oiler filler cap to release any preasure that might have built up during use and is forcing oil out as it sits. It sounds like a simple fix but it might just work.
May 06, 2009 | Garden
Not much oil on poulan chain saw bar
there is some debris blocking from entering the bar and when sits it seeps out,clean bar and are under chain cover
Jan 30, 2009 | Poulan 1630 16" Chain Saw
Homelite Electric Chain Saw Logo
56 people viewed this question
Top Homelite Garden Experts
roeb
Roland W VanLue
Roland W VanLue
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
