Question about Sewing Machines
Singer 9836c foot problems
3 Suggested Answers
SOURCE: how do you thread a singer 9836c machine
I have this machine and the manual but it will be difficult to explain without the diagram. Here are the instructions without the diagram ... I'm assuming that you know some parts of the machine i.e. the foot etc
NB. thread the bobbin FIRST - points number 8 onwards....
1. Raise take-up lever to highest position on machine by turning the hand wheel towards you and make sure the presser foot is raised.
2. Place spool of thread on the spool pin at the back making sure spool cap is firmly in place to keep it on.
3. Take thread and place through the thread guide (plastic bit same side as spool pin) a under and over action. Across from this guide is a small metal wheel on top of another loop pin on the top at the front of the machine. Take the thread and put through the loop pin. 9Thread should come out on top of the pin towards you).
4. On the front of the arm is a tension wheel numbered between 0 - 8. The thread should then be placed down the front of the arm, underneath the tension wheel (behind the body part of the arm not under the wheel) and lifted up to catch the tension spring unseen behind the wheel. It should then be threaded through the eye of the metal piece (that moves as the needle goes up and down).
5. The thread should then be passed down the gap in the body work and down through the middle of the metal spiral loop in the front near the needle.
6. The thread should continue down through the horizontal clip just above the needle.
7. The needle should be place with the flat part at the back and held firmly with the screw. The eye of the needle will face you. The thread should then be threaded through the front and out the back and under the foot leaving a six inch tail.
Your thread should now come off the spool move towards the left through the plastic guide, across the top of the machine at right angles, through the metal loop; down the front of the machine (you can't see the thread as it sits behind the body) and reappears through the metal arm hole that goes up and down with the needle. It should then come down through the metal spiral and behind the clip above the needle, through the eye of the needle and away from you under the foot.
8. The bobbin needs to be wound. The bobbins are particualr to each make of machine. So only singer bobbins can be used on Singer machines. The bobbin winder is the metal pin on the right on the top of the machine.
9. To wind the bobbin. Place the bobbin over the metal pin nad push firmly down. It is located on the top on the right hand side.
10. Place thread on the spool pin as before and thread the cotton through the plastic thread guide.
11. Take the thread as before but rather than going through the metal clip on the top at the front, place it anti clockwise partly round the metal wheel on top of the metal clip (don't go all the way around) and across to the right where the bobbin has been placed.
12. The thread should be wound clockwise as many times as required not to slip off when the thread is automatically wound with the electic foot peddle.
13. Push the bobobin manually to the right along the groove in the body and press the electric foot peddle. Bobbin should wind moving the thread up and down (not necessarly evenly) and filling the bobbin. Fill about 80%. Leave a six inch tail.
14 Pull the plate forward under the needle. Place bobbin in its slot. The thread should be in a clockwise direction and when the bobbin is placed catch the thread under the groove found on the left at the top of the bobbin case. Close the plate with the thread coming out above in the slot under the needle.
15 Manually turn the hand wheel a couple of times until you can see the bobbin thread making a loop with the stitch thread and pull through.
16 Both threads should be under the foot and away from you.
17 Tension normally is around 5 -6 on the tension wheel with standard cotton and polyester cotton thread. To tighten the tension the number should increment upwards.
Machine is a cracker and according to my local shop never goes wrong. I have had mine since 1999 and that's true.
Hope this helps.... I would send you the manual but I'm not sure how you keep email addresses private.
Good luck.
Posted on Aug 22, 2009
SOURCE: TENSION ADJUSTMENT ON SINGER 9836C
try adjusting the top thread tension to one number higher at a time until the stitches start looking right
also check with singer customer service for a instruction manual
Posted on Feb 24, 2012
I have a singer sewing machine model 1 I am wanting to order a blind stitch foot. I don't seem to be able to locate can you help me?
Hm, if you talking of a blind hem foot, this indicates that one came with the Singer One.
1 ONE Singer Sewing
It appears your machine has a snap-on foot capability, so if that is the case, a snap-on blind hem foot should work.
http://www.sewingpartsonline.com/blindhem-foot-singer-006812008.aspx
Apr 01, 2017 | Singer Sewing Machines
The foot pedal won't turn the hand wheel singer simple 2263
Sounds like there's a problem with your foot pedal. You can purchase another at SewingPartsLine for $27.00. Here's the direct link http://www.sewingpartsonline.com/foot-control-and-cord-singer-359102-001.aspx.
Feb 05, 2017 | Singer Sewing Machines
Is it possible to get a replacement motor for my singer 9836c sewing machine
Yes, it is available at Sewing Parts Online for $91 plus shipping. When you go to the site, just select "Singer Parts" from the menu on the left, then enter your model number in the search box, and you'll see it; it is part #362180-012. You'll also see that it's the motor for a number of other machines, which is probably why you can still buy it.
Feb 20, 2015 | Singer Sewing Machines
I HAVE MODEL 9410 SINGER JUST BOUGHT SINGER EVEN FEED FOOT IT FITS BUT DOES NOT GO DOWN FAR ENOUGH MAYBE NOT LONG ENOUGH WHAT ELSE DO I NEED
Triple check that you have the correct Even Feed Foot for your machine; they are made for different shaft lengths.
YouTube tutorials:
https://www.youtube.com/watch?v=qVczdRK_K6s
This MIGHT have some information you can apply to your problem.
Problems installing my walking foot
Feb 07, 2015 | Singer Sewing Machines
Manual for singer 9836c
I did a search both at Singer and Sewing Parts Online without success. Chances are, that model and another model number were identical. I DID find a site that charges $5.95 for a downloaded copy and it accepted my email address and the model number, indicating that they had it that you might want to try. http://sewconsult.com/singer/singer_instruction_manuals_6000_9999.htm
Jul 05, 2014 | Singer Sewing Machines
I need a manual for my singer 9836c sewing machine
hi can i ask a copy of the manual for singer 9836c? I really appreciate it! iresmae@gmail.com
May 07, 2012 | Sewing Machines
Feb 23, 2012 | Singer 5050 Mechanical Sewing Machine
How do you thread a singer 9836c machine
Good luck.
Jun 29, 2009 | Singer Sewing Machines
Sewing Machines Logo
10 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
