Question about GE Refrigerators
Pss26lsrd ss Both sides are not cooling
    Novelist:
    Scholar:
  • 166 Answers
Is compressor running? If not, it's likely a control board issue.
If compressor runs, then suspect failed defrost function causing iced up evaporator. Again, likely caused by defective chinese made control board.
Posted on May 26, 2014
2 Suggested Answers
  • 11800 Answers
SOURCE: GE Profile Side by Side
The temperature setting in the fridge section of your refrigerator is generated by diverting a part of the cold air generated in the freezer. This is done with the help of a fan and is controlled with a thermistor. If the temperature doesn't drop low enough then either the fan is faulty and it will have to be replaced
http://www.appliancepartspros.com/part_details.aspx?part_id=3875639
or it's not properly commanded because either the thermistor is faulty
http://www.appliancepartspros.com/part_details.aspx?part_id=3185407
or the control board itself has failed and it continuously activates the defrost resistance
http://www.appliancepartspros.com/part_details.aspx?part_id=4436216
If you need diagrams you can find them here
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5236940&diagram_id=23953624#d23953624
Posted on May 28, 2011
Hi. Our GE GSH25JSDD SS side by side drive just stopped freezing, cooling. The fan is on inside freezer and lights, and motor down on bottom, back is running. Drain is clear. Won't cool down.
I need someone to feel the top of the compressor. Is it cool, hot or too hot to keep your hand there? Usually on GE models like yours the=> WR55X11072 Main Control Board is the problem along with the start relay, overload and run capacitor. GE Refrigerator Model GSH25JSDD SS Parts
I'm here should you have question, Thanks, Sea Breeze
Oct 10, 2015 | GE Refrigerators
Oil leak in ss ducatui
Hi, Anonymous for more information about your question and valuable free downloads that you will need please visit the websites below. Good luck and have a nice day.
Wildgoose Chase Moto Guzzi
Free Ducati Motorcycle Service Manuals for download
Ducati OEM Parts Fiche Lookup and Online Ordering
Ducati Maintenance
Ducati ST3 2006
Jun 25, 2012 | 2001 Ducati 900 SS i.e. N-C
Freezer side of pss26lsrd is work refrig side is not
SOUNDS LIKE YOUR TRANSFER FAN IS NOT WORKING.. OPEN YOUR FRDGE DOOR AND PUSH AND HOLD LIGHT BOTTON YOU SHOULD HEAR A FAN KICK IN ..IF NOT YOU NEED TO CHANGE IT .
ITS BEHIND PANEL BACK OFF FREEZER CAPARTMENT.
MARK 07779933829
Nov 23, 2011 | GE PSS26LSR Stainless Steel Side by Side...
Gss25xsrd ss GE fridge gets warm on the top (both fridge and freezer side) and freezes at the bottom. Ice completely melts and veggies in the drawers freeze too.
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Dec 26, 2010 | Refrigerators
Ge refrigerator side by side , PSS26LRE SS, does not cool After manual defrost, it will work for several days and repeat again. Refrigerator bottom draw freeze everything. Please help
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
How to Defrost Refrigerator Defrost Timer Problem
heatman101
Sep 11, 2010 | GE Profile 26.6 cu. ft. Side-by-Side...
How do u replace a heater core on a 1994-1996 impala ss
That is usually a worst case scenario. Most of them just need to be flushed from the engine side. Unless it is leaking into the passenger side of the car, you probably only need to run a garden hose thru the inlet and outlet pipes to the core on the engine side of the firewall. Then you must bleed the air out of the system with the bleed valve located near the water pump/Optispark as you refill with green standard antifreeze. Try to choose one without silicone and absolutely under NO circumstances use the manual recommended Dex-Cool.
Nov 30, 2009 | 1996 Chevrolet Impala SS
Refrigerator will not cool
Unplug power, pull refrigerator away from wall and gently remove and examine both sides of control board, Look for burn marks or smell of burns and then let me know what you find. Thanks, Sea Breeze
Mar 24, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
The refrigerator side of my kenmore refrigerator does not cool
Make sure the evaporator fan is operating. Since the fresh food side is cooled by the air flow from the freezer side. Check for blockage of the air duct from the freezer to the fresh food side. Set the temp control half way. Over adjusting this setting can cause problems with cooling. If I can help you any farther, let me know.
Nov 12, 2008 | Kenmore 53642 / 53644 Side by Side...
GE Side by Side Fridge Problem
could be defrost problem. check frost pattern on evaporator.
May 18, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerators Logo
Top Refrigerators Experts
Sal DeAngelo
dweatherby
