Question about Maytag Kitchen Ranges
Maytag mgs5770adc range
We just moved into this house. It has a Maytag range of the model shown. We did notice early on that the oven took a very long time to reach the preheat temp. In past several days we noticed that there was the occasional "flop" sound when the set temp was reached and then the same sound as the oven cycled. However, today when we tried to used the oven it at first got only to 235 and then stopped heating. Now, it won't even light. Top burners work fine. When I try to use the broil, I can see the igniter glowing but the burner doesn't subsequently light. I suspect the same is going on with the main oven burner. Any thoughts?
4 Suggested Answers
  • 2651 Answers
SOURCE: Maytag gas kitchen range/oven model#
that actually sounds to be pretty normal operating procedure unless im not understanding correctly, the unit will shout off, and cycle back on to maintain proper temp as cooks, the" top lef bank of burners" they show signs of clicking??? but not actually igniting correct??? and do they ever start to click when unit is completly off???
Posted on Apr 07, 2008
  • 54 Answers
SOURCE: Maytag oven will not ignite
If its a square glow bar it must pull 3.5 apms to open the gas valve. Round ones pull 2.5 apms. even though the glow bar is on it must be real bright. Has it been taken over 45 second to light the oven. You will need some way to check the amps. If its getting enough amps the safety valve is bad.
Posted on Apr 27, 2010
  • 910 Answers
SOURCE: Unable to use either the oven or the broiler of
Can you smell or hear gas when you try and ignite the oven or broiler?
Posted on Jul 09, 2011
I have Maytag natural gas range #mgs5770adc want to know how to convert it to propane
you won't
it is a job for a gas fitter
he has the correct jet sizes for the conversion, knows where to place the air shrouds to get a good blue flame
knows the regulator pressure settings
is trained in gas fitting and is not likely to blow your house up
gas is not a diy project
Dec 20, 2016 | Maytag Kitchen Ranges
Location of the spark module on a Maytag range/oven model MGS5770ADC
Most time it is on the back side under a shield
Move a shield and you will find it
This stove has these sealed burners:
Give em a twist and lift these puppys out like this:
If it ain't on the back then remove the bottom drawer and it will be under a shield in there.
Hard to tell on the diagram
Sep 20, 2011 | Maytag MGS5770 Gas Kitchen Range
Maytag MGS5770ADC Two problems, 1) The temp.
I see you have two different problems, one for the display you would have to change your clock, and because you did not give me a complete model number I can't get you the part number you need (four different colors possible on this model). Second, when an oven ignitor becomes weak it can extend cooking times and cause the same problems you have, also if you oven sensor is defective or has oven cleaner n it can cause temperatures to be erratic. I will and can help you but need a complete model number to get you more information. Located left or right side of storage drawer when its pulled out along the frame rails.
Good luck..
Jul 22, 2011 | Maytag MGS5770 Gas Kitchen Range
I get an "F1" code on my Maytag range.
you need a new temperature probe. its usually located in the upper left hand corner in the rear of the oven.
Mar 19, 2009 | Maytag MES5570 Electric Kitchen Range
Bottom burner does not light, broiler works
Looks like you'd want a 74007498 oven igniter, which generally goes for about $75. Personally, I'd fix it, but the final call is your, or course. Please don't bother rating, as anything but a Fix-Ya lowers my score. Thanks.
Mar 15, 2009 | Maytag MGS5770 Gas Kitchen Range
I have a maytag MGS 5770 ADA range/oven. The oven does not heat. The top burners and broilers work fine. However, the bottom oven burner doesnt kick in. the igniter glows red hot but the gas never...
I would start by replacing the ignitor. It could glow enough to light the oven, but to maintain the burner, it often re-ignites several times during a cooking cycle. I have had the problem before, replaced the ignitor and all was well. You should be able to find an ignitor for under $40 online. Just google 'Maytag oven ignitor' and you should find many offers. My sister just bought one for $19.99!
No model number anywhere on the range
Reach behind the upper-left corner of the control panel. There should be a 1"x8" aluminum flag that can swing up. The model, etc. is on there.
Jan 17, 2009 | Maytag MER6872BAS Gemini Electric Kitchen...
Kitchen Ranges Logo
Top Maytag Kitchen Ranges Experts
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
