Question about HEWLETT-PACKARD EliteBook 8530p
My computer keeps beeping like there is something connecting to the USB drive, but there is nothing connected there
    Master:
  • HEWLETT-PACKARD Master
  • 788 Answers
Check if there is something in one of the USB ports. Also check all of USB ports; is there any bent metal? Usually, the metal is bent and short the port.
Posted on Mar 01, 2014
The power light keeps flashing and it is not being detected on my PC
Try hooking the drive directly to your pc and not with the usb connection you are currently using. Your usb case electronics could have gone south. If still no go, it is possible that drive is toast, especially if it is not being recognized by your pc.
Hard drives are notorious for dying when you least expect them and all critical material should always be in more than one place for obvious reasons.
Jul 25, 2017 | SmartDisk 250 GB USB Hard Drive
My 1tb seagate hard drive is beeping and not connecting
Andre,
Try Testdisk to see if there are any issues with the drive and if necessary repair or create a new boot sector.
Chappo07
Mar 22, 2013 | Seagate Freeagent Goflex Desk 1 TB Desktop...
Beeping noises
One thing you could try is take the drive out of the housing and place it inside your computer.
Oct 09, 2012 | LaCie 500GB Rikiki USB 30 Black
My iomega 320gb hard drive is just beeping when it's plugged in. I've tried plugging it into other computers, trying different USB ports, uninstalling it from my computer then letting it reinstall...
An external storage-device has four major components:
* the USB cable
* the power-adapter
* the disk-drive inside the enclosure
* the USB-to-disk-drive adapter inside the enclosure.
One of these components has failed.
Try a different USB cable.
Try connecting to a different USB port on your computer.
Try connecting to a USB port on a different computer.
Take a "multi-meter" and measure both the voltage and amperage output from the AC adapter, and compare with the specifications on the label on the adapter.
Open the enclosure, and remove the disk-drive, and then connect it as a "slave" disk-drive in a desktop computer, to see if it works at all.
Purchase a new, compatible, disk-drive, and install it in the enclosure, to "revive" your external storage device.
Get the part-number and serial-number from the label on your disk-drive, and access the manufacturer's web-site, and use "check warranty status", to see if they will replace the device, at minimal cost to you.
There exist commercial "data recovery" services that can try to repair your device, just long-enough to rescue and copy your files. For example, see: https://services.seagate.com/index.aspx?lng=en-US for a "no data - no charge" guarantee.
Dec 25, 2010 | Iomega (33600) 160 GB USB 2.0 Hard Drive
The screen on my camera is completely blank. i just want to download my pictures to my computer but when i hook it up with the usb nothing happens. is there something i need to push or something to get it...
have u inserted a memory card in your camera if yes then transfer it through a memory card reader and if not then connect it via usb and check for removable disk in my computer
Oct 04, 2010 | Cameras
My iomega external hard drive beeps when connected computer
I just bought an Iomega external Hard Drive model number SPDHDU and I couldn't get it to stop beeping when I connected it to my Mac... Then I changed the usb connection from one I had laying around for other devices, to the one it came with and now it works fine!
Jan 11, 2010 | Iomega (33600) 160 GB USB 2.0 Hard Drive
Seagate external hard drive problem
I have the same problem with a 500GB HD by the same maker. Fortunately mine started throwing "delayed write failed" errors regarding the MFT. I had enough time to save my data. Your event log should say something to point you in the right direction. Make sure your pc is up to date with the latest service pack too and start looking for a new External HD. Tiger Direct has great deals. I got a 1TB for about $120 Good Luck!
May 30, 2009 | Seagate FreeAgent Go 250 GB USB 2.0 Hard...
Maxtor One Touch 4 is beeping when I connect it by usb
Is this a new drive or have you been using it for some time and it just started doing this? What make/model computer do you have?
Usually when they start beeping like that, it's an indication that the drive is not getting enough power. It's possible that you are plugging into unpowered USB ports. Try using the USB ports that are directly connected to the motherboard (the ones in the back.)
Use USB 2.x ports if they are available. Try connecting the drive to another computer.
Jan 28, 2009 | Maxtor OneTouch III Mini Edition 120GB...
Does the HDD spinup?
My slightly educated guess... the Ext 2.5in HDD requires more power than it is getting from the single port.
1. Try another port
2. Try it on another computer (all USB ports do not provide 250ma to a load)You may be sharing this avail voltage with all plugged in devices and will have to pull 1-2 others to get the HDD online. Since STARTUP current is high, the HDD pulls all it can from the ports (logical) then settles down and uses 1/3 to keep spinning. After the HDD is up and online, try plugging the other USB devices back in, 1 at a time. If it stalls the HDD - you know the why
3. Take it back and find something a bit less power-hungry (Like Hitichi or Toshiba)
Jan 16, 2009 | Maxtor OneTouch 4 Mini 120GB External USB...
HEWLETT-PACKARD EliteBook 8530p Logo
Top HEWLETT-PACKARD Computers & Internet Experts
Bilal Ahmed Qureshi
Michael Vincent Cruz
Are you a HEWLETT-PACKARD Computer and Internet Expert? Answer questions, earn points and help others
