Question about Yard Machines Garden
12.5 90 sit on riding mower will not start
Ticking noise, will not turn over
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 140 Answers
Low Voltage ,Bad battery,or bad electrical connection, most batteries only last two seasons !
Posted on Jan 29, 2015
  • 79 Answers
SOURCE: riding mower will not start
Hi
Starter drive is stuck. Clean by spraying brake kleen on starter drive and blow drive with air. Might
have to remove starter to clean. Check for missing cogs on starter drive.
Posted on Apr 07, 2009
  • 71 Answers
SOURCE: Craftsman 42 inch riding mower. Runs great
how old is your plug? try cleaning and regapping it or replacing it at any rate make sure it is gapped correctly also make sure there is no rust dust or debris is on flywheel or coil also the flywheel keyway does more than hold the flywheel in place it servs as a timing pin and sometimes the slightest wear on it can cause the machine to start hard but otherwise run great good luck hope you find the problem.
Posted on May 02, 2009
  • 153 Answers
SOURCE: mower will not start will make clicking noise. did start at for one minute
Your battery is dead. Replace it.
In the winter keep a smart trickle charger on the battery to prevent it from discharging. Lead/acid batteries lose 1% of their charge per day and are basically junk in 3 months. They have to be kept charged.
Posted on May 05, 2009
  • 257 Answers
SOURCE: Model #917.270810 riding lawn mower. Turns over
not a expert just trying to help,,sounds like the starter gear has gone out,, need to replace,, most of them have either pin to knock out,or a ring that has to be froced off .. hope this help
Posted on Feb 17, 2010
  • 760 Answers
SOURCE: mtd riding mower won't start clicking noise
Take some sort of 12V tester and measure voltage on the small terminal on the starter to ground. You should get close to 12 V with key turned. If you see the 12 V, test the incoming large battery terminal. It should also be close to 12V. IF that's ok, check the large terminal on the starter. If you have 12V here, then check for bad ground connection. If any of these are not 12V remove cable and clean connection. How are you sure the battery is ok?
Posted on Jul 23, 2010
Can seem to start my riding lawnmower
Blades disengaged ? In neutral ? Brake depressed ? Sitting in seat ? All of these things have safety switches that will not allow mower top start .
Jul 23, 2014 | Craftsman Garden
What could cause my engine not to start and just make a tick-tick-tick noise when I turn the key?
Sounds like the electronic fuel pump. Could have a bad starter or solenoid. If battery is good, could also be igniter box. Are you getting spark, if you are then probably not igniter.
May 19, 2014 | Husqvarna Garden
Will not start, starter will not turn
wont start just spinning as if it wants to start been sitting 5 months yard machine 638rl riding mower
Aug 03, 2013 | Garden
Mower blades wont turn while sitting but turn when you stand up
I think you have a switch under the seat, which is malfunctioning
Mar 24, 2013 | John Deere 22HP VTwin 48" Riding Mower
My MTD Yard machines riding mower won't start.
Probably dead gas from sitting too long. Dump it out & put in fresh gas.Could have moisture in it. Pull out spark plug & crank it over several times after putting gas & let it sit a while to dry out or blow it out with compressed air. It should go.
Apr 04, 2012 | Mtd Garden
JUST GIVEN A MURRAY RIDING MOWER BUT WHEN I TURN THE KEY NOTHING HAPPENS...IS THERE A TRICK TO STARTING IT?
sit on the mower push clutch in,make sure the blade is in the off position,if no go be sure your
Jun 13, 2010 | Garden
Will not start
I have a feeling what happened was you shorted out the ignition switch, somehow. If you can get behind the switch without much trouble, try to jump the wires together 2 at a time just to see if it will jump the , lights, starter, ignition, one of the 3. or get a voltage tester, it will do the same thing. There is a fuse on there in the line, sits next to the battery. check it. Hope this helps,
May 06, 2010 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Mower will not start. Makes a loud fast clicking noise when the key is turned.
Loud ticking usually indicates near dead battery, take it out and charge it. If it still ticks you may need to replace it as they are only good for a few years.
May 10, 2009 | Toro Lawn Mower With Toro Power Tools
Husqvarna zero turn mower won't start
Usually if all you hear is a clicking noise, it is the solenoid itself that has gone bad...if you can jump the solenoid and the mower turns over, it is the solenoid.
May 01, 2009 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Garden Logo
Top Yard Machines Garden Experts
dannydoesita
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Yard Machines Garden Expert? Answer questions, earn points and help others
