Question about GE 23333 Digital to Analog TV Converter Box
Not getting any reception when box is hooked up. Ant connected to box box to TV box and TV on channel 3
2 Suggested Answers
gregjr_pl1
  • 138 Answers
SOURCE: i have a GE guide+
your have problem with the system IC's which store the channel and all the control in the TV or it can be remedy by soldering the pin of the IC's if the problem persist well your have to replace that system.
Posted on Sep 07, 2011
Yes hello, i'm trying to hook up my Coby 12'1 digital tv to a converter box is that possible or do i need a cable box for it to connect?
You should be able to connect the tv to a converter box. This is good for OTA signals to a TV with an NTSC tuner (coax) or composite video input. http://www.cobyusa.com/?p=prod&prod_num_id=205&pcat_id=2007#features-tab has the manual for the DTV102. Put the antenna coax cable to the converter box ANT In and then either the antenna out to the TV or the A/V (composite) out to the TV's composite in. If you use the RF connection, you will need to set the TV to channel 3 or 4 and set the switch on the converter box appropriately. For a composite video connection, you will need to change the input to AV1 (if there are several inputs). Depending on the TV, there may be a source or input button on the TV. For other models this is only on the remote. If you have the original remote, no problem. If you have a universal remote, make sure that you have a key that corresponds to the feature and that you found the code that lets the key work for your TV. (Not all universal remotes have the feature.)
However, you should get the best antenna that you can and have it pointed correctly to receive the stations. Digital signal doesn't have borderline reception. Try antennaweb.org or tvfool.com to check the stations and directions in your area. Antennaweb assumes an outdoor antenna but is very conservative in the channel list that it will indicate you can receive. Tvfool lists the channel reception depending on the antenna type. Tall trees and buildings can block the signal.
I hope this helps.
(please note that surges from the antenna can damage converter boxes and kill the tuner.)
Feb 08, 2011 | Coby DTV102 ATSC STANDARDDEFINITION TV...
Trying to hook up to digital converter box and cannot get the tv to see it? It won't let me in to set channels.
Check ur tv converter box a small button on the back of the converter box make sure it is not set to channel 4,make sure it set it to channel 3.Put ur tv on channel 3.Take the antena signal input put it in the converter box hole that call ANT.Take the wire that came with the converter box put the wire one side of it connected to the other hole into the converter that said OutPut.The other side of the wire should be connected to the hole in the tv said ANT hole.Now make sure ur tv converter box power a/c cord plug into the a/c power outlet and the power button is press on and have power to the converter box.The converter box now power LED light on indication should be on and it is green.Now the tv CRT screen picture should have a menu of the converter box funsctions.Just follow the on screen instructions and press the enter button on the remote and it will now auto scan for those free air Digital DTV channels.When the auto scan it reaches 100% is it done.Now u have done it.
Nov 12, 2010 | Curtis-Mathis Televison & Video
I need to connect a digital bos to my emerson 1304 tv.i can not find any place to connect the coax
The antena hole input in the Converter box that where said the input source said Ant.,use a antena like a digital antena,roof antena or a rabit ear antena.Hook up ur source of the antena go in that hole.The hole input said out to tv in the Converter box,use a cable that was supply to u,came with the Converter box.Use that cable plug in the Conveter box tv hole said out to tv.The other end of that cable go to ur tv Ant. hole.Now u got it all hook up.Turn ur tv to channel 3 or 4 now u got a menu from the Converter box,go down to the highlight word said scan channels,push that highlight word.Ater the scan are finish,u will now get all the free DTV channels.
May 05, 2010 | Emerson EWC1304 13 in. TV/VCR Combo
Hi just got a LG dvd/vcr Model RC897T. I have it hocked up right, but i can't get it to switch over so that it would be seen on the TV. can you help
If a cable box is not required for cable signal reception, connect the cable line to the ANT. IN connector on the recorder.
If a cable box is required for cable signal reception, connect the cable line to the IN connector of the cable box. Connect a coaxial cable from the OUT connector of the cable box to the ANT. IN connector of the recorder.
To view or record a CATV channel:
  1. Tune the TV to the Recorder output channel (CH 3 or 4).
  2. Set the Recorder channel selector to the cable output channel. (Example: CH3).
  3. Select a channel using the cable converter.
With this connection, you cannot record one program while viewing another.If you are using a cable box to tune channels, it is not necessary to do Auto Channel Set.
Oct 20, 2009 | LG RC897T DVD Recorder/VCR Combo
I had to cancel cable TV because of cost and now I can't connect my VCR with the converter using an older TV (from 1991). I will use VCR to record and watch videos. I have tried everything but nothing...
HOOK ANT TO THE CONVERTER BOX OUT OF THE CONVERTER TO THE INPUT OF THE VCR OUT OF THE VCR TO THE TV TURN THE BOX TO THE CHANNEL YOU WANT TO REC.PUT THE VCR CHANNEL ON 3 OR 4 AND THE TV ON 3 OR 4 THIS WILL WORK
Aug 24, 2009 | Televison & Video
My Zenith VCR is not working with the digital converter box
When the VCR is "off" the converter signal should go right through the box, which you say it does. Then, when you turn the VCR "on" the picture disappears. That, so far, how it should be. To get your picture back while the VCR is "on" you must set the VCR to "receive" channel 3, and use your new converter box to change channels...accordianman
Dec 16, 2008 | Televison & Video
After installing the DTV converter box, reception was dropped for most of the stations i received pre-box. now i have added a new antenna. and, i can't get anything through the converter box. connections...
If you have the box connected to the TV using an RF cable to the TV's antenna input, make sure the TV is on channel 3. You should at least see the boxes menu display when the power is on. Try channel 4 if you see nothing on 3. Every box I've hooked up has been on channel 3 by default, but who knows?
If you can, hook the box to the TV using direct video and audio connections, and make sure the TV is set to the correct input.
Unless the box you bought has "RF pass-through" (and if you got your box using a government coupon, it's a sure bet it doesn't) you will notice a marked drop in quality if you try to watch regular broadcasting with the box connected. I've been installing these with a bypass arrangement so people can still watch their analog broadcasts until they go off the air in February.
If the box does in fact have no display when you turn it on and your TV is on the correct channel, your box is defective and should be returned and replaced.
Dec 06, 2008 | Televison & Video
RCA DRC8030N
That sounds about right if you have cable instead of an antenna cable. If it can't tune anything but 5 channels in, that's all it claims; set it to CABLE IN instead and try that so the tuner can get along with your cable box. If you really do have an antenna hooked up, get it away from whatever's reflecting signal and screwing up reception.
Sep 12, 2008 | RCA DRC8030N
Tv/vdr/cable box
Your hookup is correct- Your VCR needs to be tuned to channel 3 or 4, to match the cable box.
Also, the VCR channel output needs to be matched to the TV. If VCR menu options are displayed on the TV then this part is right. If not, then set either the VCR or TV to the correct channel.
May 11, 2008 | Sharp VC-A420U VHS VCR
Ant/cable
your box might be blown out
also call the cable company to see if the outage didnt affect them
they might be out too
on the TV you might to look for setup or init setup
a model number of the tv set wouldnt hurt too
Jan 06, 2008 | Curtis-Mathis CM19011 TV
GE 23333 Digital to Analog TV Converter Box Logo
Top GE Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a GE Televison and Video Expert? Answer questions, earn points and help others
