What does please run auto channel search - Televison & Video
  • 8 Answers
SOURCE: Auto Channel Search
sounds like the tuner section of the main pcb isn't working properly.
Posted on Aug 21, 2008
Danmart
  • 291 Answers
SOURCE: auto channel search.
Check the r/c[remote control] for ' fresh ' batterys.
Do you have " air wave " reception? or cable connection?
air wave reception will scan but cable reception can't scan because the channel is 'fixed' at ch.3 or ch.4.
Posted on Nov 30, 2008
SOURCE: No digital channels after running auto search
Same thing with my vizio vx37l tv. Did you fix the problem bpakja? If so please let me know how.
Posted on Dec 10, 2009
falspet
  • 438 Answers
SOURCE: Auto Channel Search places all channels in Skip
check the agc line from the tuner is functioning properly, if the agc signal , is not reaching the processor it will register that channel as being inactive and lock it out, there is not much circuit to contend with so a multimeter should do the trick to trace down the fault, you should find AGC marked on the board where the tuner modual is mounted.. i suggest obtaining a service manual to do the job good luck
Posted on Jan 28, 2010
pabloloco
  • 2335 Answers
SOURCE: Polaroid FLU-2632 channel searching
Often when using a Sky box, one doesn't use the channel tuning feature of the Polaroid HDTV. Often one connects the Sky box to a component video input, and the Sky box does the tuning.
I hope that helps.
___________________________________________
Polaroid FLM-2632 Manual Download
Polaroid FLM-2632 Service Manual Download
Posted on May 01, 2010
How to run a n auto channel search?
stop pushing buttons your not sure of.
To perform a channel scan using the coaxial input:
Press the INPUT button on your remote to view your current input source. ...
If the TV input is not selected, press INPUT until the TV input mode is selected.
Open the on-screen menu and select TV or Tuner option. ...
Highlight Tuner Mode and select the correct option:
Dec 26, 2015 | Insignia Televison & Video
Auto Channel Search, how do you accomplish this.
Use your Insignia remote to select the initial set up procedure and run auto channel search.
Mar 03, 2015 | Insignia Solutions NS-24E200NA14 24" LED...
How do i finde auto chanel seargh
Auto channel search is how your tv finds channels that are available. Under settings in the menu should be initial set up. There you will find channel search.
Feb 20, 2015 | Insignia Televison & Video
Element tv keeps saying please run auto scan
May be there are some out of frequency channels. Go to searching menu option and use manual tuning for personally. Auto scan for all channels.
May 11, 2014 | Element Televison & Video
How do you scan the channels on the PDH42L40? I need to go to a certain channel on the TV to get my Dish Network to work. It is not hooked directly into a box, it is on a secondary receiver. Please...
hello and good day to you!!!!
if you wish to scan your TV to go for a certain channels..
you need to reset auto scan on your TV...
this are the procedure on how to reset auto scan...
  1. Get your remote control..
  2. press the menu button on your remote
  3. go to the settings..
  4. try to find the auto search.
  5. after you find the auto search press enter to scan the channels.
Note: Please complete the 100% scan for better results..
Jul 12, 2011 | Televison & Video
Does not tune in channels 1 to 10
run a scan on your tv through the menu to search channels. it will auto pick up any channels you dont have. also you can go to oyur channels and edit the channels you want to skip. more than likely they are skipped.
Please take the time to rate :] Thanks!
Apr 22, 2011 | Televison & Video
Someone tried changing channel manually. Now I get a message that says "run auto channel search' but I don't know how to do this, please advise
you have to be on the Cable/Antenna Input. Then you can access the menu option to auto search for you channels again.
Mar 21, 2010 | Insignia 37" LCD Flat-Panel HDTV
Sep 30, 2009 | Vizio VX37L Television
Auto search through
Tested and verified solution:
  1. Set Tuner Mode to "antenna".
  2. Run a channel scan. Should get zero channels found.
  3. Set Tuner Mode to "cable".
  4. Run another channel scan.
  5. Celebrate!
Aug 16, 2009 | Vizio VX37L Television
Televison & Video Logo
14 people viewed this question
Top Televison & Video Experts
Electro Med Services...
