Question about Saeco Coffee Makers & Espresso Machines
CANNOT DESAMBLE THE COVER
I cannot deamble the upper cover of my Saeco Magic SIN017, due to vapor knot on the right hand side.
  • 3 Answers
On my saeco royal there are a few hidden screws in the grinder hopper. torx bit # 15 i think. also under the front panel looking up.
not sure which part you are refering to...vapor knot?
Posted on Feb 12, 2014
4 Suggested Answers
espressodoc
  • 29 Answers
SOURCE: Saeco Magic Deluxe - trouble light on
Not sure which light you are refering to because the far right light shuld be temp ready light. The one you describe slunds like the descale light but that shouold be second to from the left. In which case it is telling you to descale. I can't attach a manual here so do a search for saeco repair and an authorized repair center should be able to get you one.
Posted on Aug 09, 2007
  • 1894 Answers
SOURCE: saeco magic (sin017 9710639730) bayonette
use some adhesive solution to attach it instead of trying to thread it again which wont be stiff.
Posted on Aug 12, 2008
espressonist
  • 1711 Answers
SOURCE: I have a Saeco Magic
This is a
very frequent problem with scale. Despite that the steam water knob is tightly
closed, due to scale deposits one steam water valve, the valve cannot close completely.
So when you press for coffee there is a steam-water leak from the wand too.
So you just
need to perform de-scaling of the machine two - three times one every day and
try to draw out the dissolve water and de-scaling solution in steps with 5 -10
minutes interval. This will give more time to the solution to dissolve the sale
build up in your machine.
If after
three de-scale performs you still have the problem then you need to disassemble
the steam valve and manually remove the scale with a sharp tool and wire brush.
There is a
small possibility that you might need to replace some parts in the valve all
the whole valve.
You can
find all the parts you may need, de-scale solution and many other information for
your machine like manuals, diagrams at the
http://www.partsguru.com/
Posted on Jan 26, 2011
HOW TO REMOVE THE STEERING COLUMN COVER
Remove screws from bottom of the cover. Then the tricky part......the upper cover. It has a little tiny screw on the right hand side (stereo side) under the cover holding it down. I find that a 3mm or 4mm socket will take it out. It's a male star head, so opposite of torx.
Feb 16, 2014 | 2002 GMC Envoy
Hi, I have a Saeco Magic Comfort coffee machine which displays the following message when I switch it on 'Brewunit missing'. Hope you can help. Cheers
Hi
Open the door on the right. The brew unit is the thing with the handle that has the "press" on it. You need to push on the upper left side of the brew unit until it clicks. There is an outlet spout on the opposite side of where you are pushing. It goes into an intake port that needs to be lubed(food gade only), so the outlet spout will slide in without pushing back. That should take care of the missing brew unit.
Apr 17, 2011 | Saeco Magic Comfort Plus Espresso Machine
STARTING ROPE BROKE AND UNABLE TO START MOWER
Hi,,,,replaceing the rope is easy, just takes sometime. first, take the cover off the engine. turn the cover over and rope pully should be right there. Measure out 8 foot of new rope. burn both ends of rope so it don't fray. get all of the old rope off the pully. here is where an extra pair of hands come in handy. by hand rotate the rope pulley 6 revolutions, now have someone hold the pulley, then feed rope thru the cover and thru the pulley rope opening, then tie a knot in that end, now slowly release the rope and it will wind itself onto pulley, now put rope thru the handle and tie knot, now put back togeather and go mow your lawn,,,lol
Sep 22, 2010 | Mtd Yard - Man 160cc, 21" Self - Propelled...
Our old simnger machine knots up the threads from the bobbin side-below. What is the solution
Rethread the upper threading and adjust the tension. The knotting up in the under side of the fabric is due to incorrect upper tension.
Thanks,
Pat
May 24, 2010 | Sewing Machines
I can not get the side cover off my acer t180 I need help!
Viewing the back of the computer, there are two screws to remove on the right side panel, at the rear.
One close to the top, one close to the bottom.
Make sure the screws are going through the side panel itself.
After you remove them you pull back on the side cover with one hand, holding onto the computer tower with the other hand.
Sometimes the side cover is tough to pull back.
(Be SURE the computer is unplugged from power)
Would appreciate hearing the outcome of this.
(Post in a comment. Believe upper right of page - Comment)
Jan 08, 2010 | Acer Aspireā„¢ T180 PC Desktop
Steady Brew Group Light: Old Saeco Magic deluxe
Open the door on the right. The brew unit is the thing with the handle that has the push on it. You need to push on the upper left side of the brew unit until it clicks. There is an outlet spout on the opposite side of where you are pushing. It goes into an intake port that needs to be lubed, so the outlet spout will slide in without pushing back. That should take care of the missing brew unit.
Dec 08, 2009 | Saeco Magic De Luxe Espresso Machine
Error 9-363
Try to clean the dev rotary sensor. open the upper right hand cover then there are two assy's to be removed also for you to access the rotary sensor located inboard side. this sensor senses the home position of rotary developer. to removed this sensor, you have to open the rear cover, then rotary pwb. some 9-363 code is due to busted fuse in the rotary pwb. Thanks for using Fixya !
Feb 07, 2009 | Xerox Document Centre ColorSeries 50 Laser...
Replacement Parts For Vintage Magic Chef stove
You probably have a 1940's model of Magic Chef. Check for the model number under the lid of the cook top on the upper right hand side of the stove. It should have the model number and the serial number, too. You will need both. The Old Applicance Club run by Jack Santoro is the place to go along with a site called "Antique gas stoves"in Georgia. Good luck with the world of vintage stoves.
Sep 23, 2008 | Kitchen Ranges
Saeco magic (sin017 9710639730) bayonette mount (actual metal thread) broke and basket will no longer attach.
Aug 12, 2008 | Saeco Vienna De Luxe Espresso Machine
Aug 09, 2007 | Saeco Magic De Luxe Espresso Machine
Coffee Makers & Espresso Machines Logo
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
just-ice
83bj60
Level 1 Expert
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
