Question about Birds
The name for small parrot starting with a P - Birds
How do I rest parrot password
Try using the pin code 1234, as that is the automatic pin code for many new parrot devices.
Here are some quick start guides from the company
http://www.parrot.com/usa/support/parrotck3100ck3300ck3500/
Jan 26, 2015 | Parrot Cell Phones
PAIRING PARROT TO BLACKBERRY 9320
To pair your BB to parrot go to connections
check whether the Bluetooth is ONthe search for devicesand when the name of the system comes..pair with the device.
Thank You.
Dec 26, 2012 | Parrot SA Parrot Ck3100 Lcd Handsfree...
Do I need a Parrot perches?
Parrot perches are usually made for large sized birds. If you own a couple of small birds you don't really need this cage bur if you own more than 3 parrot you should consider a parrot perches to provide your birds the space they need.
Aug 05, 2012 | Birds
I cannot get the galaxy ace to automaticaly connect to my car hands frre kit ( Parrot )
The parrot car kit varies, there are about 10 different types of the parrot car kit and the connections varies slightly. Just follow these steps to connect ur galaxy phone to the car kit.
For this model of the parrot car kit,after the installation on your car,ensure the car is on
Parrot CK3000:
1. Start the car and ensure the car kit is on.
2. Activate Bluetooth on your phone, and search for Bluetooth devices.
3. Select "Parrot CK" from the list.
4. Enter 1234 on your phone when prompted for a password or code.
5. The Parrot CK3000 will sound a beep when connected to your phone.
Your phone has now been paired with the Car Kit and is ready for use.
For other models of the parrot car kit,repeat step 1 & 2 above and for step 3, u select the model name like "parrot EVOL" for the CK3000 Evolution model.
Aug 30, 2011 | Samsung Cell Phones
Paired backberry 8520 with parrot ck3100 but contacts will not syn with parrot. tried to transfer contacts to parrot but message just says refer to handsfree maunal .have looked into this with no luck...
Hello chicks,
Pairing both devices from the Parrot Product:
Select Setting / Advanced Settings / Pair with phone / Other phones
* From the phone:
* Select MENU / OPTIONS / BLUTOOTH / ADD DEVICE / SEARCH
* The phone will search for available devices
* Select the Parrot Product name from the list, and enter the PIN code '1234'
* The phone will pair with the Parrot Product and auto connect
Sending contacts via Bluetooth For all contacts sending
* From the phone:
* Select MENU / MANAGE CONNECTIONS / BLUETOOTH OPTIONS
* Select the Parrot Product from the list of paired devices and go to OPTIONS / TRANSFER CONTACTS
May 07, 2011 | RIM BlackBerry Curve 8520 Smartphone
I bumped the unit getting into the car with the seat forward now at car start up it rapid beeps about 3 times but does not turn on? parrot 3100
The cable has come out underneath the display, you will have to pull it off the dashboard and unscrew the two small screws behind, you will see the connector there.
Feb 07, 2011 | Parrot Hands-Free Car Kit with LCD Display...
Nokia 6303c and Parrot 3200ls colour. It was working great. Now I have lost a lot of my voice recognition and some of it is mixed up with the wrong addresses.
Best to do a resest , repair bluetooth and for voice calling all phone book entrys should be first name last name for the least amount of confussion
Mar 03, 2010 | Parrot 3200 Ls Color Handsfree Bluetooth...
My nokia n95 will connect to my parrot hands free but no names transfer to the parrot what am i doing wrong?
Object Push: To send one contact:
* From your phone go to MENU / CONTACTS
* Select the desired contact to send and go to OPTIONS / SEND BUSINESS CARD / VIA BLUETOOTH
* The phone will start searching for available devices
* Select Parrot Product from the list of available devices
* The contact will be transferred
To send several contacts:
* Select the desired contacts to send with OPTIONS / MARK/UNMARK / MARK
* After the desired contacts are selected go to OPTIONS / SEND BUSINESS CARD / VIA BLUETOOTH
* The contacts will be transferred
Oct 04, 2009 | Parrot Hands-Free Car Kit with LCD Display...
Birds Logo
63 people viewed this question
Top Birds Experts
Tom Chichester
Are you a Bird Expert? Answer questions, earn points and help others
