Question about Sony DVP-NC665P/S Multi-disc DVD Player
"Cannot Play Disc"
The unit was In CD Playback when I got A C 59 19 Error Code. Now It will not palyback any CD. It does However playback all DVDs. Please Help?
SOURCE:
SOURCE: Playback stops after 45 secs
my advise is that you need to take that set to qualified techn for repairs.
Posted on Jan 27, 2007
SOURCE: DISCWON'T PLAY, RECEIVE MESSAGE "THIS DISC CANNOT BE PLAYED, PLAYBACK PROHIBIT BY AREA LIMITATIONS
i am ohamed scondo
i have pdf repair
Posted on Sep 16, 2008
SOURCE: Sony DVP-NC600 Powers down during CD playback
The tray won't open. I took top off and dvd top side holder, but the laser mechanism won't disengage so the tray will open, even with no dvd in it. How do
I reset it. I power on, hit open key, it makes hum noise then goes by to
standby mode.
Posted on Oct 11, 2008
ginko
  • 19396 Answers
SOURCE: need unlock code.
I found this region hack here Sony DVP-NS575P region code , check it out:
"Warning
The following guide describes how I managed to make my Sony DVP-NS705V DVD player multi-region.
There are no guarantees that you will be able to do the same. Be aware that you will probably void any warranty you have and possibly even break the player.
Put shortly, you proceed at your own risk.
Introduction
First of all, the Sony DVP-NS705V can be made multi-region simply by applying appropriate service codes, you do not need to install a so called "mod chip".
This supposedly applies to the entire NS-series of Sony DVD players. There are some encouraging reports out there supporting this, but nothing has been verified by me. Again, if you choose to apply this guide to any DVD player, you do so at your own risk.
If you do find that this procedure works on another model, please drop me a line at [email protected] and let me know. Include the exact model number and original region of your player.
Update: Some users have reported success on the following players:
DVP-F21 (special thanks to Garry Self for this one)
DVP-LS500
DVP-LS755
DVP-LS785
DVP-NC615
DVP-NS300
DVP-NS305
DVP-NS310
DVP-NS315
DVP-NS330
DVP-NS333
DVP-NS355
DVP-NS360
DVP-NS400
DVP-NS405
DVP-NS410
DVP-NS430
DVP-NS433
DVP-NS575
DVP-NS585
DVP-NS590
DVP-NS700
DVP-NS730
DVP-NS765
DVP-NS900
DVP-NS905
DVP-NS930
DVP-PQ1 (thanks go to Michael Joy for this one)
DVP-PQ2
RDR-GX3 (thanks to Andreas Norman)
RDR-GX7 (thanks to Daniel Tapie)
RDR-GX300
RDR-GX700
RDR-HX900
RDR-HX1000
Please note that not all players behave exactly like the NS705. For example, some players do not display "success" when hacked.
Thanks to all who have contributed.
The infrared service codes required to make the update are available on the Internet. Unfortunately, not many people have an appropriate device to enter the codes into. You basically need a programmable remote (Philips Pronto, One-For-All) or a PDA (Palm, iPAQ) with suitable software.
This guide shows you how to make the update with a regular PC equipped with an IRDA port.
The procedure
1. Download the winsamp -package from Blank Frank's site.
http://www.veg.nildram.co.uk/remote.htm
This innovative piece of software allows you to send standard home electronics IR signals using a PC IRDA port.
2. Extract the package onto a bootable DOS floppy disk.
3. Download this IR code
http://www.selen.org/files/REMOTE.TXT
file and place it in the same directory as the package above.
This file holds the five necessary IR codes converted to the format used by Blank Frank's winsamp.exe. Please do not bother Frank with questions concerning this particular procedure.
4. Boot up your PC from the floppy disk and run winsamp.exe.
If your IRDA port doesn't appear as COM2 you may override this by using an appropriate command line switch. For example, use COM1 by running 'winsamp C1'.
5. Press the 'r' key to load up the codes into winsamp.
6. Make sure your DVD player is in standby mode and your IRDA port is within range.
7. Run the IR codes from 1 to 5 by pressing Enter on each corresponding button.
8. Your DVD player should start up and display the text "SUCCESS".
9. Repeat step 7. Your player should return to standby mode.
10.Your player is now multi-region."
Posted on Feb 10, 2009
  • 22 Answers
SOURCE: problem with dvd playback
The problem may be on the len, laser focus ... take it to service or buy a new one.
Posted on Dec 18, 2009
HOW DO YOU GET MP3 TO PLAY?
hi ozzy, without asking the name and model number of your unit.... simply insert the MP3 recorded cd-r disc OR original disc OR usb flah drive into your unit and playback should commence automatically. if your unit does not support MP3 playback OR usb plaback then no MP3 palyback is possible. good luck.
Sep 08, 2013 | Car Audio & Video
No Disc Error in Philps FWD17 with DVD and MP3-CD playback system
The problem with the system Philips FWD17 shows NO DISC for certain CDs which wont play. With regard to DVDs it doesnt recognise them at all. The disc spins and then stops showing NO DISC
I have replaced the lens with the same type and model SF-HD65. It still doesnt detect DVDs
Please advise.
Regards,
Gerry
E-Mail [email protected]
Feb 22, 2010 | Philips HTS3400/37 System
Home burned DVDs won't play in regular players
you need to select the disk as audio disk in the burning application, then select tracks and burn it.
Dec 20, 2008 | Pioneer (DVR-K15 BLACK) DVD RW Dual Layer...
Playback
saving .jpg/.JPEG/ .BMP file to a dvd disc don't wrie properly. try using a CD-R disc and save pctures as .jpg.
Jul 30, 2008 | Televison & Video
WONT PLAY COPIED DVDS ANYMORE
were you able to play copied dvd's on this unit ? if yes then check setting on the dvd menu for things like DVD REGION and DVD playback speed and types of DVD playable, this is quite likely as i ha this problem on a pioneer model previously.
do those copied dvds no longer play on the same unit ? and you have tried them again on another unit or dvd player ?
rather i suspect problems with the DVD burn itself and its compatibility with the dvd player you are palying them on now (asuming settings in DVD enu are correct as loosely outlined above in point 1)
it may be that if this is a new dvd player than the one you played them on before, the dvd's may have to be closed in a certain way using your burning software so that they are playable on standard dvd players.
please also check that region is not an issue and that the recording speed of the dvd (the rip speed) is not too high or too low for your unit, as this data is stored on the written dvd and is responsible for the quality of the palyback data.
Mar 08, 2008 | JVC TH-M303 System
SRD4900 Sylvania DVD/VCR Combo
Well first of all, why the hell would you press play when there was nothing in it???
Feb 01, 2008 | Durabrand DUR7 Portable DVD Player
Playback of dvds
is the country code different on the dvds than on the unit?
Nov 28, 2007 | Emerson EWR20V4 DVD Recorder/VCR
Recorded finalized CD's will not play on standard CD player
Are you using the same brand of discs you used to? Do they palyback on the machine in both the record and the playback deck? Do your old cdr's you recorded still play in the standard cd player? You can try the diagnostics - hold down the 'play' and 'fwd' keys on the record side as you power it on.
Oct 31, 2007 | Philips CDR778 2-Disc CD Recorder
How do you get the receiver to palyback mp3s?
How to set the clock of pioneer DEH-2800M car radio?
Oct 09, 2007 | Pioneer DEH-2800MP CD Player
Sony DVP-NC665P/S Multi-disc DVD Player Logo
24 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
