Question about aFe 2000 Chrysler Concorde - 2.7L V6 - Air Filters
Car starts, then won't run
Car will start, but not run. I have often used a remote starter to warm up. can hear iy start, but then die. same when using key. I have tried swapping relays to no avail
    Prodigy:
    An expert who has answered 500 questions.
  • 517 Answers
You have dirty jets in carb need cleaning
Posted on Feb 12, 2014
Engine cranks very slow on starting and will not start
refill the battery with electrolyt and charge it fully, then try to start the vehicle
If it cranks/turns over no faster have the starter motor checked.
Ensure that the timing belt is intact before you do anything, and that it is in the correct position.
Ensure that the oil is clear of water and is clean and is topped up to the top mark on the dipstick
Assuming you have checked the above and the belt and oil/coolant is all as they should be, and you have a fully charged battery and the starter is ok .......attempt to start the vehicle. Turn it over/ crank it over a few times if it does not start immediately.
Should it not start perform a compression check to find out the
engine's state of health.
Then come back with the results and we can go feom there.
Add the detail of your work and the make and model of the vehicle, along with the engine option, and repost the query
Jul 18, 2015 | Spectre 2003 Dodge Stratus - 2.4L 4-cyl....
My car wont start after I have driven a while and turn off engine. When I try to start it cranks well but will not turn over. If I let it sit for 20 minutes it will start again???
Sounds like you're in tank fuel pump is starting to go bad..happened to my astro van a few years ago..kept doing this until one day it just didn't work. Have someone do a fuel pressure test before and after turning the engine over...Also try this..before trying to start your engine turn your switch to ON for about ten seconds and listen very carefully for the pump running to prime the fuel system and injectors it should run for about five seconds...then try starting the engine...get into the habit of waiting those 10 seconds to insure proper priming of the system..good luck
Dec 14, 2014 | Spectre 2002 Chevy Impala - 3.4L V6 - Air...
Could you tell me were the immobiliser unit is on a 1990 nissan pulsar n13 motor as it starts sometimes soon as you turn it off it will not start again,
Wait a minute, thats probably too old to have a chip in the key, in that case it's likely its the wiring harness to the fuel pump, perhaps there is an access port under back seat to get at it. check your connectors and run a ground wire directly to the gas tank and make sure it's grounded then try it. Do you hear the fuel pump when you turn the key on?
Nov 23, 2017 | Hyundai Used 01 02 03 04 05 06 Santa Fe...
Wont turn on
does the lights come on but the motor does not turn, if it is this it can be the starter for the motor inside next to the motor is a started solenoid this starts the motor to run. when they start to fail you get a buzzing sound or a humming, eventually it just fails. also the motors are prone to fail after time, and they don't do replacements for this part
Mar 30, 2014 | Air Purifiers
Van does not stay running.
Yes, you have a fuel pump in the gas tank.
But, before you replace the pump, check the fuel pressure.
Mar 26, 2013 | AM Auto Parts 1997 to 1999 Ford E350 Van...
My holmes air purifier makes a screeching sound
If you can access the fan, spray lubricant onto the shaft as close to the fan body as possible. It will work it's way into the bearing
Apr 14, 2012 | Holmes Products Air Purifiers
Jeep rpms fluctuate and car dies 1 mile from start-up
could be voltage regulator is faulty or there could be another faulty sensor. You can test any sensor with an ohmmeter.
Nov 24, 2009 | Air Purifiers
CAR DIE WHEN SLOW DOWN OR STOP AND LET GO THE GAS
i went to my mechcanic the same day my engine started to make the same loud noise that you are talking about. he said that it was the flex pipe. just this morning (5:30am 8/3/09) i went to dunkin donuts for my morning coffee and while waiting in line, my car just stopped running. like you said, when you take your foot off the gas and press the break, the car stops. no doubt about it, it is the flex pipe. im sure by now you got your car fixed but i thought that i'd share my car troubles with you :)
Feb 12, 2009 | Blueair Blue Air 402 Smokestop Particle...
Car dieing
You may have a Vacuum Leak, Throttle Position Sensor may be bad, and the MAP Sensor. Those are know to go on the 3.1L Chevy Lumina's. Thank you for using Fix Ya! Don't forget to rate the overall rating of this answer. Good Luck.
Jun 30, 2008 | Blueair Blue Air 402 Smokestop Particle...
aFe 2000 Chrysler Concorde - 2.7L V6 - Air Filters Logo
47 people viewed this question
Top aFe Air Purifiers Experts
Pcm2048
Jim Goldsmith
Jim Goldsmith
Thomas Perkins
Thomas Perkins
Are you an aFe Air Purifier Expert? Answer questions, earn points and help others
