Question about managemylife.com
None of the burners on my kenmore elite stove light unless I use a match. I tried clearning out with paper clip. There is no clicking sound.
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 68 Answers
Bad spark ignitor
Posted on Feb 11, 2014
Kenmore gas range 790, not getting gas to the stove top, oven works, all 4 igniters fire when any knob is used. Is this a safety shutoff and how do I fix it?
Burner Spark Electrode Replacement - Kenmore Gas ...
? 2:23
www.youtube.com/watch?v=U0VcfMJPaiY
Nov 12, 2010 - Uploaded by RepairClinic.com
+Tony Eatinsky If the electrode is not damaged than the spark module ... I have a kenmore gas stove ( 362.7555190) that won't ignite unless I use a match. ... I have a Kenmore Elite 5 burnergas range top, it auto light continually sparks? .... You most likely will need to cut or grind off the screws and get new ...
kenmore model 790 gas range. the gas stove top burners ...
www.shopyourway.com > Manage My Life > Questions
kenmore model 790 gas range. the gas stove top burners stopped sparking. ... NOTE: I do not recommend measuring voltage unless you have experience and feel ... if the spark module is getting 120 volts when the burner knob is turned to the ...
Oct 19, 2015 | Kenmore Kitchen Ranges
Igniters not working, no clicking sound. Cannot light stove with match.
Greetings
If none of you top burners produce clicking then it's most likely your ignition module. They can completely die. look for small box on back of range. @$60 Sears Parts Direct.
Easy Fix
Feedback Much appreciated
Aug 05, 2011 | Tappan TGF657 Gas Kitchen Range
No Clicking Sound
Sounds like the ignitor control module is bad, if none of the ignitors are working. If it is only one burner with a problem, it is likely an ignitor.
May 12, 2010 | Brown Stove Works TM210-3 Gas Kitchen...
Kenmore electric stove with glass/cermanic top. Element on light indictor light stays on all the time even though no burners have been turned on for 5 hours. None of the burners are hot when you run your...
Tony, this sounds like you may need to have a new burner switch installed, it is called an infinite switch. If it is for the dual burner, make sure you tell the appliance parts store this so they can order you a dual infinite switch.
Nov 08, 2009 | Kenmore Ovens
Kenmore elite gas range clicking sound
If unplugging it for a couple minutes and plugging back in does not rectify then it sounds like a bad spark module or a shorted wire inside. All 4 should spark at the same time when any burner is used. (Does trying to light a burner make the other 2 spark too?)
Eric
Jun 20, 2009 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Counter top stove burner won't light
Hi, You asked a very generic question but I will try to give you a good answer. If the pilot is good and you can light the burner with a match, (this checks everything else) then the most common problem would be the burner holes in front of the pilot are clogged. When cool, remove the burner and inspect the holes, any debris needs to be removed, a bent paper clip works really well. Compressed air helps as well. If there is a tube to the pilot make sure it is exactly where it belongs and that it is clean. If the match didn't light the burner or the flames is not all blue like the rest, there is something else wrong and you need to get back to us with a make and model to better help you. Make sure the burner gets seated back on the orifice correctly and best of Luck to you!
Feb 05, 2009 | GE Profile JP930 Electric Cooktop
Ge spectra gas stove top not lighting
If your top burners are not lighting or will not work, it is possible that the burners have become dirty or wet. Please follow the troubleshooting directions below before calling service:
  1. Turn you burner to the Lite position:
    If you hear clicking or sparking, go to Step 2.
    If you do not, check your circuit breakers. If the circuit breaker is ok, we recommend that you schedule service by calling 1-800-432-2737 or schedule service online.
  2. Clean the burner and electrode:
    First remove the burner grate, cap, and head. Use a needle or paper clip to poke through the holes on the burner head. Re-assemble and try the burner.
    Remove the burner grate, cap, and head. Even if it looks clean, wipe the tip of the electrode with a clean, dry paper towel and PRESS IT DOWN. Re-assemble and try the burner, again.
    Check to see if the burner works, If not, then go to Step 3.
  3. Re-assemble - Make sure that each burner top matches its burner bottom. The burner top will lay flat if put on correctly.
    Check to see if the burner works, If not, then go to Step 4.
  4. The spark igniter is operating properly, but the burner is still not lighting. At this point, we would recommend that you schedule service by calling 1-800-432-2737 or schedule service online.
Aug 15, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
Kenmore Elite Gas Stove
Will have to ask some basic questions first.  How old is the stove?  What is the entire model # from the sticker on the unit?  Is this LP or natural gas?  Also, make sure that the orifices in the center of the burners are clean (can use a safety pin or paper clip to poke them a few times to clean).  Make sure that the black caps are on top of the burners and seated properly or they will not lite.  Let me know what you find.
Oct 16, 2007 | Kenmore 79383 Dual Fuel (Electric and Gas)...
managemylife.com Logo
43 people viewed this question
Top managemylife.com Computers & Internet Experts
Steve
Paul Bade
Are you a managemylife.com Computer and Internet Expert? Answer questions, earn points and help others
