Question about HP Md6580n 65 in. HDTV
Picture problem After being off for a while, when I turn it on the color is fine but after a few minutes it turns to Black and white.
4 Suggested Answers
goalie39
  • 469 Answers
SOURCE: 12 black and white copies per minute
be sure you are selecting B&W when copying, and the same if printing from the print driver.
Speed is based on 8`1/2 x11 paper fed side ways. First copy speed not incluced, once the first copy exits the machine it should work at the rated speed.
Hope this is of some help.
Ed
Posted on Apr 22, 2009
  • 15 Answers
SOURCE: No color on screen - just black and white. I
can you hear the system working or see the hard drive light blinking ?
Posted on Feb 20, 2010
  • 6771 Answers
SOURCE: Screen goes black for a second or two every few minutes
This indicates the inverter transformer is going or a capacitor issue.
Posted on May 08, 2012
The picture color is very red. Sound fine.
I have a solution for this depending on what you tell me:
Go to a channel with the program in BLACK AND WHITE, TURN THE COLOR ON THE SET TO ZERO.
What color is the screen? If it is red or somewhat red (not black and white) I CAN TELL YOU HOW TO CORRECT THIS--I HAVE SEEN IT BEFORE AND IT IS A TEN MINUTE FIX--NO PARTS WILL NEED TO BE REPLACED.
Confirm not black and white picture---respond with a comment here and I will tell you exactly what to do and how---- I have seen this problem before.
If this helps you, rate this solution as very helpful as I do this here for free.
REGARDS, SD TECH
Aug 14, 2010 | Hitachi 51F510 51" Rear Projection...
Re: Mitsubishi WD62627 projection TV issues
This is the most common problem for rear projection tvs and it is known as the color convergence problem.You will need to replace or repair its ics to solve it.
Mar 26, 2008 | Mitsubishi WD62627 62" HDTV
When I turn my TV on it plays just fine for about 10 minutes. Then it goes to black and white. If I turn it off for a few minutes and then turn it back on, the color returns for a few minutes and them goes...
The tube harnesses may be a little loose and when tube warms they short. Try adjusting the wiring harnesses. (Only attempt to do so if you have electronics knowledge.)
Nov 20, 2009 | Philips Magnavox 27MS343S 27" TV
Have to push power repeatedly to get TV to turn on, b&w picture
the CRT is obviously very old and discontinued ,I would recomend investing in a new set
Jun 11, 2009 | Televison & Video
TV Picture is tinted pink
depending on how much you paid for the tv , the cost of the repair may be more than the tv is worth. but if this is a large tv , then the repair would be most likely worth it
Dec 29, 2008 | Televison & Video
Color flickers on and off
I went to the Sony support page for your model.(link below)http://esupport.sony.com/US/perl/model-home.pl?mdl=KP61V85&LOC=3
They are undergoing maintenance right now, so I couldn't find any answers for you. I would check back with the website to see if they can help you. If the Standby timer light flashes, you may need to have the TV repaired. There is a "Hot Topics" section for "How to troubleshoot television picture issues" that will probably be very helpful to you.
Dec 05, 2008 | Televison & Video
Negative screen image
Look in System Preferences for Universal Access, there is a Display option which says Black on White(the normal setting) and White on Black (the setting that has been enabled).
There is a keyboard short cut to change the setting, it involves pressing four keys - Apple, Option, ^ and 8.
Nov 29, 2008 | Apple iBook G3 Mac Notebook
Sony KV-27TW75 Black and White Picture
this is usually due to bad ground check cable line comming into tv and
CHECK/RESOLDER CONNECTIONS IN TUNER WHERE CASING IS SOLDERED TO PCB NEAR 4TH FEED THRU BACK FROM ANTENNA INPUT
Feb 04, 2008 | Televison & Video
LG Plasma TV 50PC3D
The TV should be under warranty. Send back. Sounds like the panel is faulty (half the value of the set).
Feb 06, 2007 | LG 50PX4DR 50 in. Plasma TV
Black and white picture on the JVC TH-505
If you hold the VFP button while a movie is on, you will get a small box on the corner that shows your color. My default color also turned black and white. I just moved over to a user1 color setting (push the right arrow on your remote), and it allows to the change the colors. You might be able to put the colors to come out through here. Hope this helps.
Jan 28, 2007 | JVC TH-M505 System
HP Md6580n 65 in. HDTV Logo
26 people viewed this question
Top HP Televison & Video Experts
Tony
Computer Links
Are you a HP Televison and Video Expert? Answer questions, earn points and help others
