Question about Samsung ML-2855ND Laser Printer
Replace sensor on samsung 2855nd - Samsung ML-2855ND Laser Printer
Printer sensor failure #3 3112 samsung ML1860
Dear
Pl. check the fusser assy. thermistor resistance if it open replace it,check thermostat and heating lamp for short, if open replace it. If all are ok, try to up date latest firmware. if not solved replace the main board.
Thanks.
Jul 13, 2011 | Samsung ML-2855ND Laser Printer
I have replace my samsung ML 2855 toner but red led stil turn on and the message still apear replace toner please help me sorry for my english
1. Check inside of printer for pieces of paper (papaer jams)!
2. Replace toner cartridge, maybe your printer doesn't recognized electronic chip on your new cartridge!
Mar 14, 2011 | Samsung ML-2855ND Laser Printer
Open heat error cycle power
Disassemble fuser and inspect thermistor, thermostat and heat lamp. Replace broken part.
Oct 27, 2010 | Samsung ML-2855ND Laser Printer
How to clear the memory on a Samsung ML-2855ND?
In order to stop a stalled print job, perform the following steps in order:
  1. Stop the Print Spooling service.
    • Click Start.
    • Click Run.
    • Type cmd.
    • Hit Enter.
    • At the command prompt, type net stop spooler and hit the Enter key.
  2. Delete the stalled print job.
    • Open My Computer.
    • Go to C:\Windows\system32\spool
      • Delete any files you find in this folder (but do not delete any folders!).
    • Go to C:\Windows\system32\spool\printers
  3. Restart the Print Spooling service.
    • Return to the command prompt used in step 1.
    • Type net start spooler and hit the Enter key.
Sep 16, 2010 | Samsung ML-2855ND Laser Printer
Problem for Samsung ML-2855ND Laser Printer Led screen says open heat error cycle power, how do i fix this?
to totaly resovled this issue you got to replace the fuser & (SMPS) power board on the printer.
if not every time you on the printer you got to off it for 5mins and restart the printer again.
May 21, 2010 | Samsung ML-2855ND Laser Printer
Need to install the printer, lost the cd.
Try here, http://www.samsung.com/ca/consumer/detail/support.do?group=office&type=printer-multifunction&subtype=monochrome-laser&model_nm=ML-2855ND&disp_nm=ML-2855ND&language=&cate_type=all&dType=D&mType=DR&vType=&prd_ia_cd=06010400&model_cd=ML-2855ND/XAA&menu=download
Jan 12, 2010 | Samsung ML-2855ND Laser Printer
Samsung ML-2855ND Laser Printer Logo
18 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
CheckitRight
CheckitRight
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
