Question about Staples Cross-Cut Shredders; 22 Sheet
Paper jamed and machine has not power - Staples Cross-Cut Shredders; 22 Sheet
IF PAPER HAS NOT JAMED BUT MACHINE ARE SHOW PAPER JAMED
Try cleaning the rubber paper feed rollers. If it fails to pick up the paper in a pre determined time it will show paper jam. The pick up tires must pick up paper when turning, if not the paper will not feed into the machine and it will show paper jam with no jammed paper.
Mar 16, 2011 | Canon imageRUNNER 400S Copier
It says clear paper jam
what brand of fax machine do you use?
try to open the fax machine ande see if there is any paper jamed or piece of paper jamed at the sensor.
Nov 11, 2010 | Office Equipment & Supplies
Lexmark printer 3600-4600, after paper jamed and took paper out . but it still shows " paper jam " all the time . And printer seems not remove "paper jam" away even reconect box jection behind ...etc....
check that their is no pieces of paper broken off in machine and that all the paper sensors are not still jammed and moving freely then switch off machine for at least 30sec then switch on should work if not check again and make certain all covers and doors are properly closed
Oct 13, 2010 | Lexmark X2600 InkJet Printer
Paper keeps jaming when trying to print fax it
If the jam is consistent with exiting the drum, there's a chance the drum isn't secure and is the paper is getting caught on the exposed area of the drum. If this isn't the case, there may be paper caught in the feeder wheels.
Oct 18, 2009 | Brother IntelliFAX 4100 Laser Fax
The machine will not always shred when you put a piece of paper in it. It works sometimes but doesn't work always.
You most likely have bits of paper scrap jaming the switch. Remove the power cord and look for any small pieces and pick them out. A small dental pick works well for this task.
Sep 23, 2009 | Fellowes Powershred 220CC Shredder
PAPER JEM WHILE PRINTING. I NEED A HEIP TO REPAIR THE PRINTER.
first, if thare any paper is jamed in the paper tray, pull the paper stright out. take out the remaining paper. close the paper tray.
opne the front cover pull out the toner cartirdge, remove the jamed paper.
open the inner door (where the paper exit). make sure there is not paper jamed it.
close the front door. if any paper jamed inside of the machine, it should automatically eject it out.
Note: reset the printer by opening and closing the front door.
Apr 03, 2009 | Samsung ML-2510 Laser Printer
Samsung fax machine SF-365TP
Before diagnose the problem please turn off the Machine.
Check all sensor if they have dust then clean it.
Close properly the cover.
Sep 15, 2008 | Samsung Office Equipment & Supplies
Paper jam
Remove the paper following the procedure below.
(1) Load a single sheet of the same paper in the Auto Sheet Feeder in portrait orientation.
Do not load it in the landscape orientation.
(2) Turn off the machine.
(3) Turn on the machine.
The paper is fed and then pushes out the jammed paper as it ejects.
If you cannot remove the jammed paper or the paper jam error continues after removing the paper, contact your Canon Service representative.
James Mac
Sep 09, 2008 | Canon PIXMA MP600 all-In-One InkJet...
Panasonic FP-7750 will not feed paper through machine correctly
Look where you remove the last jamed piece of paper closest to the fixing unit. Dose it jame when you make one copy? If it dose jam in the same place, I would have to say the problem is in the fixing unit. Look, in the unit for any pieces of paer jamed and remove them. Also, is it only happen with one paper tray and not the other. If so make sure you haze the tray and paper are set correctly.... Really need some more info.
Aug 05, 2008 | Panasonic FP-7750 Black and White Copier
Panasonic kx-fp 342 papaer jam
paper jam or missfeed always due tothe following:-
1-malefunction of paper feeding system due to broken gears belt chain please check smoth mechnical movement and apply light grease in gears and change any broken part.
2-something is blocking the paper path (staplers-pins)droped inside.
3-malefunction of paper detection micoswitch please confirm free operation for the lever in mechnical one and clean of dust and dirt from optical one,
Mar 06, 2008 | Panasonic KX-FHD351 Plain Paper Thermal...
Staples Cross-Cut Shredders; 22 Sheet Logo
Top Staples Office Equipment & Supplies Experts
Saleem Baig
Saleem Baig
Terry Hair
Tom Chichester
Are you a Staples Office Equipment and Supply Expert? Answer questions, earn points and help others
