Benq Joybook A52 will not boot from CD/DVD / USB.
I went into bios (with F2) changed the device boot order (I even excluded the hard drive) but it will not boot from them. I am sure the optical drive is working , same for USB . I am sure the DVD I am trying to boot from is bootable - same thing for the Flash memory. I've searched for similar problems other users have encountered but cannot find any way to solve this. Have you encountered this issue? What should I do?
    New Friend:
  • 44 Answers
What are you trying to boot and how did you create the USB and/or CD?
need computer help? Join our forum
http://forum.wasatchtechies.com/
Wasatch Techies Smartphone Tablet and Computer Repair in Utah
Posted on Feb 11, 2014
  • Andrei Morarescu
    Andrei Morarescu Feb 12, 2014
    I am trying to boot winXP from a bootable USB flash drive. I created it using WinToFlash (http://wintoflash.com/home/en/ ). I have also tried booting WinXP sp2 and sp3 from different CDs and 1 try with a Win7 which I was sure was good because I am using it for my personal laptop.Trust me , the issue is not the bootability (if that is a word) of the CDs I am trying to boot .
How do I unlock the Bios on an Acer ES-1 111M Laptop
To boot from a CD, DVD or USB device, make sure that the device has boot sequence priority over the hard drive.
BIOS Boot
BIOS (Basic Input Output Subsystem) is a programmable chip that controls how information is passed to various devices in the computer system. A typical method to access the BIOS settings screen is to press ESC, F1, F2, F8 or F10 during the boot sequence.
BIOS settings allow you to run a boot sequence from a floppy drive, a hard drive, a CD-ROM drive or an external device. You may configure the order that your computer searches these physical devices for the boot sequence.
The first device in the order list has the first boot priority. For example, to boot from a CD-ROM drive instead of a hard drive, place the CD-ROM drive ahead of the hard drive in priority.
Before you set boot priority for a USB device, plug the device into a USB port.
To specify the boot sequence:
  1. Start the computer and press ESC, F1, F2, F8 or F10 during the initial startup screen. Depending on the BIOS manufacturer, a menu may appear.
  2. Choose to enter BIOS setup. The BIOS setup utility page appears.
  3. Use the arrow keys to select the BOOT tab. System devices appear in order of priority.
  4. To give a CD or DVD drive boot sequence priority over the hard drive, move it to the first position in the list.
  5. To give a USB device boot sequence priority over the hard drive, do the following:
    • Move the hard drive device to the top of the boot sequence list.
    • Expand the hard drive device to display all hard drives.
    • Move the USB device to the top of the list of hard drives.
  6. Save and exit the BIOS setup utility.
  7. The computer will restart with the changed settings.
Boot Priority Options
Some computer manufacturers allow you to select the device that contains the boot sequence from a special device selection menu. The example below uses a Dell system board.
To set boot priority using a device selection menu:
  1. When the computer starts to boot up, after the manufacturer's ID screen, press F12 several times. The device selection menu appears.
  2. Use the up and down arrows to select CD-ROM or
May 04, 2015 | Acer Aspire Computers & Internet
Tip
Non-System disk or disk error
<p><b>Issue:</b><br /> <p>Non-System disk or disk error<br /><br /> <p><img src="reyjoshua07.jpg" /><br /> <p><b>Cause:</b><br /> <p>The current media is not bootable or there was a disk error in attempting to boot.<br /><br /> <p><b>Workaround:</b><br /> <p> <br /> <p>1. <b>Change Boot Media </b><br /> <p>If you are booting from either a DVD, CD, diskette or a USB drive, remove the media and boot from the hard disk. The media is either damaged or is not intended to be bootable.<br /> <p> <br /> <p>2. <b>Set the Correct BIOS Boot Choice </b><br /> <p>The BIOS may be configured to boot from the wrong device. If you suspect this, the device boot order can be changed in the BIOS setup. Be aware there little consistency in BIOS setup operations, even with the same manufacturer on different models. As such, these instructions are bit less precise than we'd prefer.<br /> <p> <br /> <p>Reboot and enter the BIOS setup. Often the BIOS displays the correct key to use briefly on screen or you may need to refer to the computer's user manual. Typically you hold down the Del, Esc, F1 or F2 key immediately after booting.<br /> <p> <br /> <p>Look for a section on Boot or Booting. Often this appears on top menu. Select the Boot option, and if necessary the Boot order choice. The Boot order choices should list the order of boot devices. Typically the CD is the first boot device with the hard-disk typically second. The diskette may also occur before the hard disk, which is acceptable, although this will slow your hard disk boot by a few seconds. Avoid USB and network boots before the hard disk unless you know for sure you are using them (which is exceptionally rare). <br /> <p><br />Save and exit the BIOS. It will force a reboot. See if this change corrects the issue.<br /> <p> <br /> <p>3. <b>Check Hard Disk and Cables </b><br /> <p>If you had changed, added or removed hard drives, or changed or removed drive cabling, likely something is wrong. Recheck that the drives are properly installed and the cabling has not changed. Switching cables to different motherboard connectors or changing the master/slave drive jumpers (on old ATA drives) can cause this problem. In some systems, the cables were not plugged into the drive or motherboard securely and may have worked loose. Reseat all drive connectors.<br /> <p>It's also possible a hard drive is failing. Use a system diagnostic to validate the drive or swap to another hard disk.<br /> <p> <br /> <p>Hope it helps,<br /><br />Thank you for using FixYa<br /> <p> <br /> <p>Best regards,<br />Reyjoshua07<br />
on Jan 24, 2011 | Computers & Internet
Toshiba Satellite L355D-S7815 re-soldered cmos battery onto mother board and re-set the bios, now I have the f2 and f12 option available, tried to boot cd/dvd drive with windows 8 disk and it will not
Go into the BIOS setting abd check it the BIOS detects the hard disk and CD/DVD drive.
If it detects these drives then go to the boot device order and select the CD as the first boot device then the hard disk as the 2nd boot device.
Apr 03, 2013 | Computers & Internet
Tried to boot from USD, CD/DVD Drive but failed. Still showing No bootable device -- insert boot disk and press any key
To boot up from the DVD drive go into the BIOS setting - boot device order and move the DVD as the first boot device and the hard disk as the 2nd boot device.
If you want to boot up with the USB then move the USB as the first device. If the USB is not listed as a boot device then it is not possible to boot up with an USB device.
May 26, 2012 | Acer Aspire 4930-6862 Laptop
I tried to install windows 7 on my HP Pavillion DV9, but it's not booting from CD-ROM, i tried using a USB CD-ROM, but it's still not booting. pls I need assistance.
Try to check if the windows 7 disc that you are using is not just an upgrade disc. Make sure that it is a bootable disc. Try to use other bootable disc to test. Also make sure that the boot device priority is set CD/DVD drive.
Hope this helps.
Jun 06, 2011 | Computers & Internet
What is the booting priority order for aspire 3680
Usually it's preset to HDD/CD/Network. You can change the order in the system setup.
Mar 05, 2011 | Acer Aspire 3680 Laptop
Well i just bought a dell optiplex gx620 (full tower) and im trying to install windows pro but every time i put the disk in the pc and turn it on it keeps saying that theres no bootable device...so i tryed...
From the info you supplied...
Boot (power off/on) and go into the BIOS (Usually hit F2 as it powers on and the white bar goes across the bottom for self test).
F2 will probably be listed as an option along the top (right). You only have a limited time to hit the key.
One of the menus should show what devices are connected (CD, hard drives). Make sure the system sees you're hard drive and CD-DVD. If the CD/DVD is not listed anywhere I would guess it is not installed correctly. I am not sure if the 620 will support an external USB C/DVD. This is another option and again, boot order would have to be changed.
Another menu has boot order. Make sure CD/DVD is at top of the list since you stated the drive is blank. I would make sure hard drive is second in the list. Save/Exit BIOS
Be CAREFUL MAKING any CHANGES to the BIOS.
Jan 11, 2011 | Dell OptiPlex GX280 PC Desktop
Dell b130 upgrade to new hard drive trying to boot of from cd-rom but wont..... need help
did you change the order in the bios setinbg?put the 1st device for boot to be the CD/DVD-rom not HARD drive, to get into bios try F2., ESC, ,F12 . and in the bios setup change the order put 1st boot device to be CD/DVD-rom, then try again to setup Windows.
Mar 13, 2009 | Dell Inspiron B130 Notebook
Want to Boot from dvd ROM
when the pc in post usually on dells bios there is a boot menu option it is usually f12
if you don't know what your doing in the bios it is not a good place to test your skills after pressing F12 just choose cd rom for boot
Jan 28, 2009 | Dell OptiPlex GX280 PC Desktop
Computers & Internet Logo
1,111 people viewed this question
David Payne
David Payne
