Question about HP Laserjet Pro 400 M401N
My M401N just shut down and won't turn on - HP Laserjet Pro 400 M401N
Hp laserjet pro 400 m401n printer 59.A0 error
59.X Error Turn off then on
Description
The product has experienced a problem with one of the motors.
Recommended action
Turn the product power off, wait at least 30 seconds, and then turn the product power on and wait for it to initialize.
If you are using a surge protector, remove it. Plug the product directly into the wall socket. Turn the product power on.
http://h20564.www2.hp.com/hpsc/doc/public/display?docId=emr_na-c03304304#N10143
Apr 20, 2016 | HP Office Equipment & Supplies
How do I reset the language to english on an M401n hp printer
1. Turn the product off.
2. Perform one of the following steps:
- LCD control panel models: Simultaneously press and hold the right arrow button and the Cancel button. Keep these buttons depressed as you turn the product on.
- Touchscreen control panel models: Press and hold the lower right quadrant of the touchscreen. Keep the quadrant depressed as you turn the product on.
3. When the Permanent Storage Init. message appears on the display, release the buttons.
4. When the product has finished the NVRAM initialization, it returns to the Ready state.
Feb 10, 2015 | HP LaserJet Pro 400 M401N Laser Printer
I cannot install laserjet Pro 400 4001n on my desktop
Do you mean the HP LaserJet Pro 400 M401n? If so, start here: http://h20566.www2.hp.com/hpsc/swd/public/readIndex?sp4ts.oid=5254078&lang=en&cc=us and select your OS. Expand the section labeled Drivers. In order to use all of the features of the M401n, download the Full Software and Drivers.
If you have connected the printer via a USB cable, make sure to uninstall the printer from the Printers control panel (in Windows - the location name varies with the version of Windows) and disconnect the USB cable before reinstalling the printer software.
I hope this helps.
Jan 15, 2015 | HP LaserJet Pro 400 M401N - CZ195ABGJ
Lite up blank screen
Shut off for at least 10 minutes with power source disconnected to clear any memory banks of this problem.
Sep 23, 2014 | HP LaserJet Pro 400 M401N Laser Printer
Hp laserjet m401n 52 scanner error
You have a scanner. It is the laser/scanner which writes the image to the drum. It is located under the top cover in the center. It is a black box and most times the issue is the scanner motor has become dusted up and does not turn to the correct speed. Not sure if yours can be repaired but on older models I have repaired them by opening the laser/scanner assembly and removing the little circut board with the motor and chrome spinning shaft. If you can remove the chrome piece from the motor you do so and then place a very tiny drop of synthetic oil down the shaft, install the chrome piece and spin a few time by hand and put everyting back together. You can download the service manual by doing a google search.
Apr 04, 2014 | HP LaserJet Pro 400 M401N Laser Printer
Dell Inspiron 8500 won't shut down, on/off button doesn't repond
Hold down the ON/OFF button for several seconds until it shuts off.
Mar 04, 2013 | Dell Inspiron 8500 Notebook
IMac G5 17" won't shut down
I have minor shutdown problem with mail, won't close or shut down. My ans top left APPLE drop down, force closure, turn of each programme listed. For me works a treat.
Jan 19, 2013 | Apple Computers & Internet
My hhr will not turn off, where is the battery so i can disconnect it
Unplugging the battery won't shut it down I don't think.
Get into your fuse box under the dash or in the engine compartment and pull the fuse for the fuel pump.
Jul 02, 2011 | 2009 Chevrolet HHR
My dell inspiron 1545 won't shut down went i click on the shut down icon it won't turn off .
Hold down the power button for 10 seconds. That will hard-shut the PC. Once that is done, fire it back up, and try again. Somethimes, windows will act goofy shutting down. Especially Vista when it is left on too long without shutting it down.
Jun 20, 2011 | Dell Inspiron 1545 Notebook
HP Laserjet Pro 400 M401N Logo
Seeker5211
Seeker5211
