Question about Royal Office Equipment & Supplies
Jammed shredder royal 112 mx
I used too much paper at the same time. I've needed to manually pull shredders from bottom, but this time it doesn't help
  • Mary Beth Kuypers
    Mary Beth Kuypers Feb 11, 2014
    Thanks so much BHerman503. I had not replaced the basket...doing so and working "reverse" solved my problem!
  • 3 Answers
SOURCE: Gears won't pull paper through
http://www.geocities.com/jayrespler2/index.html
Posted on Nov 29, 2008
  • 45 Answers
SOURCE: Royal 15mx only works in reverse after clearing jammed paper
try resetting the shreddar, unplugging it waiting for about 20 seconds and then plugging back in. Check to make sure there is no paper or paper clips stuck in the shreddar, make sure the unit is properly mounted on bin, the overheat light isn't on is it? if none of this helps and you have a warranty on your shreddar now would be a good time ot call them as you might have a hardware problem.
Posted on Apr 16, 2009
FixinFax
  • 3085 Answers
SOURCE: Royal 10x Crosscut Paper Shredder (PCUA: 29054E) paper jams.
Try soaking the cutters with soapy water, yes it works. Oil after you are done.
Posted on Aug 02, 2009
  • 1218 Answers
SOURCE: Shredder motor runs but won't shred paper. No
If the motor is running do the cutting shafts turn??? if not then unplug and open up the top to see if any gears are broken/stripped; give Royal a call at 1-800-524-0799 for parts and prices once you've located the problem.
Posted on Aug 22, 2010
  • 1218 Answers
SOURCE: I own a Royal RL170MX shredder. I turn on the
If the blades rotate then the paper should go in...just be sure the blades are turning in the forward direction and not in reverse.Also make sure you lubricate the blades with shredder oil.
I have a Royal CX 66 Crosscut shredder and attempted to shred 10 pages. The unit shredded 1/2 of the papers and the other 1/2 are stuck in the shredder; the reverse mode will not release the papers. Is...
The Royal cx-6 shredder is a small consumer shredder rated for "up to 6 sheets at a time" so yes it will jam with anything more that 6.
If running it in reverse won't work you will have to try to open it up and see if you can manually turn things to get the paper back out...there is no other way if it wont run in reverse...hopefully when you have the paper removed the machine will still function.
Oct 27, 2010 | Royal CX6 CrossCut Shredder
My royal paper shredder is jammed. How do I unjam the shredder?
Normally try to run it in reverse while pulling the paper back out to assist the motor. If it won't even run in reverse then you will have to take it apart to manually clear the jam.
Sep 10, 2010 | Royal 15MX Shredder
My shredder is jammed and I cnnot get unjammed
Hi. Go to the local hardware store and purchase a small pair of needle nosed pliers. Use these to pull the paper from the shredder a little at a time. Then in the future only shred up to 3 sheets at a time so it does not jam on u. J.
Aug 06, 2010 | Royal 160MX Shredder
Paper shredder jammed
Yes....this is a consumer model....NO BIN/BAG FULL INDICATOR....to keep costs down, you will just have to try to get the bin out a little at a time and slowly reach-in and "fish out the shredded paper...once you have enough out the bin will come out...hopefully the backed up paper has not jammed the machine and blown the PCB inside.....if it has give Royal a call at 1-800-524-0799 for parts assistance.
May 01, 2010 | Royal 150MX Cross-Cut Shredder
Royal rl 170 mx
We bought another shredder
Sep 13, 2008 | Royal Office Equipment & Supplies
One of the gears has stripped teeth. I've got the same problem and am looking for a replacement.
Apr 02, 2008 | Royal 160MX Shredder
Shredder that sounds but doesn't feed
sounds like you probally have a stripped or broken drive gear. Contact manufacturer for parts availability.
Sep 15, 2007 | Royal VF1000MX Shredder
46 people viewed this question
Top Royal Office Equipment & Supplies Experts
James Cagle
James Cagle
Adorjani Laszlo
Are you a Royal Office Equipment and Supply Expert? Answer questions, earn points and help others
