Question about Exercise & Fitness
Nordic Track C700 makes loud noise when i strike (running)
I purchase the C700 Jan 2014 and finally had the time to put it together yesterday 2/2014. The issue is when I walk on it, it makes no loud noise when I strike. When I run, the noise is loud and obvious. I know that when you run, your foot strike is harder that when you walk but the deck shouldn't be this loud. Does anyone have an idea of what it could be?
  • Severina Kluizenaar
    Severina Kluizenaar Feb 11, 2014
    Also....the noise sounds as if I were "jumping" on the deck.
  • 103 Answers
SOURCE: Proform 400GI Treadmill making a very loud noise,
This definitely sounds like the drive motor. One way to check is to remove the drive belt and run the motor without the walk belt connected. Obviously if you still have the noise it will be a motor issue. If not then it will be one of the 2 rollers. Good Luck! Tim
Posted on Nov 13, 2009
  • 103 Answers
SOURCE: Calibration Mode for nordic track treadmill model
Hello there, The calibration mode for a nordictrack is as follows.
With the safety key out, hold the stop and speed up arrow at the same time while inserting the key. Release the buttons. You will then be in diagnostics.
You then press the stop button one time.
If you are trying to calibrate the incline you just need to hit the incline up button and the machine will do an incline calibration. The unit should go all the way to the top and return to the bottom when completed.
If you need to calibrate the speed you will need to press and hold the speed up button on the console until the display reads 85. The machine should then be running at its maximum speed (either 10 or 12 mph depending on the unit)
The display will show a speed on the console and should be within .3 of the maximum speed.
If it is not then it will need to be adjusted using a potentiometer on the control pwb.
To access the control pwb open the hood cover. Should be 3 screws in the rear of the cover and 2 screws on the bottom of the unit.
Once inside the cover locate the control pwb. On the control pwb there will be a yellow/orange potentiometer. This is the adjusting part.
Use a non-metallic phillips head screw driver to adjust the potentiometer either clockwise for faster or counterclockwise for slower.
Hope this helps!
Good Luck! Tim
Posted on Jan 13, 2010
Testimonial: "Although I haven't attempted this solution, but it makes perfect sense and will attempt it as soon as I get back to the treadmill - Thank you"
SOURCE: Belt slipping on Nordic Track c1900
My belt is slipping I tighten both alan head screws to the max roughly 7 turns and still have the broblem
Posted on Jul 10, 2010
SOURCE: need manual for nordic track walk fit 5000 1995
I can't help with the manual. But, if you reach under the area where the readout is, push up on the cord or any of the opening underneath the display will pop out. You should be able to find the battery compartment. The unit uses 2 AA batteries. If you find a manual, let me know.
Thanks.
Posted on Jul 26, 2010
SOURCE: Nordic Track A2250 Pro stuck inclined
My Nordic Track Treadmill A2250 is stuck on the 12% incline position and it wont go back down and I have tried to reset it by turning it off, switching the reset button to off and then on or even unplugging it several times. What would be my next move?
Posted on Feb 13, 2011
Why is my nordictrack T6.3 making loud humming sound all of the sudden?
You don't oil belts as oil will eat away at the rubber. Start with running the machine and checking for lumps of wax build up at rollers (most common issue) if this is not it try oiling roller bearings. But call manufacturer first to see if your warranty is still good because as soon as you touch it it will void warranty.
Jul 18, 2014 | Nordic Track NordicTrack T6.3 Treadmill
How do you reinstall the drive belt on a T6.3 treadmill?
  1. Remove the drive belt
  2. Loosen rear roller screws
  3. Remove the screw holding the front roller
  4. Slip out the roller
  5. Slip on drive belt
  6. Put back together in reverse order
Dec 29, 2013 | Nordic Track NordicTrack T6.3 Treadmill
Knocking, banging sound C1500 my husband just received this equipment
I would call the retail shop and they will organize a repair man out to fix from Icon Fitness. This is done under warranty .
Feb 22, 2012 | Nordic Track NordicTrack Commercial 1500...
Nordic Track C2000 starts and then stops.
Have you lubricated the the running deck? The lack of lubrication can increase friction thus causing the current over load circuit to activate thus shutting down the unit to prevent further damage, Go to your local hard ware store and purchase silicone spray. Apply Lubricant by lift one side of the running belt spray contents length wise starting at motor shroud to the back end repeat this process on the other side. If this unit shut down again then you will have replace the running belt and possibly the deck
May 21, 2010 | Exercise & Fitness
Knocking noise
Unplug unit open motor shroud , then replug unit , start the unit up then place tip on to the a 6" length flat screw driver tip on the front roller shaft put your ear on the insulated end and you should be able locate the knocking noise also check the motor and rear roller you insert tip where th adjustment is made. I believe that the front foller is causing your problem. Go to iconfitness.com go to customer service then replacement parts you will find your M# and pricing
Mar 02, 2010 | Nordic Track NordicTrack Treadmill, A2550
Need to put together a Nordic Track Elite 2900 treadmill.
go to the nordic track website, you can download a blow up of the treadmill that shows how where everything goes, you can also download any manuals you may need in pdf.
Mar 17, 2009 | Nordic Track NordicTrack Treadmill, A2550
Exercise & Fitness Logo
198 people viewed this question
Top Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
