Question about Coffee Makers & Espresso Machines
Caffitaly coffee machine, model S14
My Caffitaly machine, model S14, has heating problems. Only button D,blinks RED with beep sound. A,B and C lights (cup symbols)do not blink (remain off). Tried to reset, without success. Does not beep after reset cycle. Can you help?
  • 25 Answers
SOURCE: Keurig starts & stops without brewing coffee, just descaled
The pic is clogged with coffee or the air bladder is bad. Use the tool on the underside of the tray to clean out pic. If that doesn't work, the bladder will be bad.
Posted on May 14, 2009
  • 211 Answers
SOURCE: coffee ground are coming out of the k-cup area
Make sure the needle in the bottom of the K cup holder is not missing, broken or bent. Also, look at your used K cup when it comes out. Is there a hole in the top and the bottom? It sounds like the pressure is building up within the K cup due to a backup at the bottom of it. This could also occur if the bottom needle hole is obstructed. Be careful...the needles are sharp!
Posted on May 28, 2009
SOURCE: Heating Element Shuts Off Very Early
Reset the timer for shutting off the hot plate, instructions are in the user manual.
Posted on Jul 10, 2009
SOURCE: Blinking on/off light won't turn off
It means it's time to "decalcify" your machine. Not sure how to do that, I assume run vinegar or something like that through it. You can turn the blinking light off by holding down the "set clock" and the "set timer" buttons at the same time.
Posted on Jan 16, 2011
SOURCE: Cleaning light will not quit blinking after cleaning
The same thing happened to our Mr. Coffee this week! I followed the instructions about running vinegar through, then rinsing several times with water. However, the light would not stop blinking. We did by-pass the light by setting the timer for delayed brewing and it worked. However, that blinking light came on again. Then, my husband tired the vinegar wash again but instead of doing it one time, he ran the same vinegar through 6 times until the light went out! Then he proceeded with the water rinse. Our Mr. Coffee is working again!
Posted on Jan 22, 2011
Caffitaly manual
Hi I have a caffitaly modal so1hs/po1hs , I having a prom with mine , the water dos not go into cup I have cleaned it twice and still , it's doing the same thing need help please thanks Julie Donnelly
Oct 23, 2013 | Coffee Makers & Espresso Machines
Caffitaly coffee machine is continually beeping
The Caffitaly Machine Beeps when it needs Descaling...the reduction in the water flow is an indicator that your machine badly needs this maintenance procedure to be completed. Refer to Page 15 of your User Manual.
Sep 30, 2012 | Dualit Coffee Makers & Espresso Machines
When the machine is on and the heating has completed, pressing the buttons to make coffee has no effect. They just blink once and nothing happens. The steamer seems to work fine tho.
This happens to us sometimes and we find that the problem is with the capsule holder. Try taking the capsule holder apart and then twisting it together again. If it's not quite in the right position, the machine will not dispense the coffee!!
Oct 28, 2010 | Gaggia Caffitaly K111 Coffee Maker
My capsule / pod holder is broken. Where can I get a new one, and how much do they cost ? Thank you
hi,
contact ylavoie@sybco.com. they are located in canada and are the distributor for caffitaly. they have a model called ocs3000 that has exactly the same capsule holder.
ciao
Sep 26, 2010 | Gaggia Caffitaly K111 Coffee Maker
Coffee Makers & Espresso Machines Logo
Top Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
