Question about Eagle Hardware & Accessories
MY RISOGRAPH GR 3750 gives the code T4 call service. I don't know what to do?
2 Suggested Answers
  • 17 Answers
SOURCE: anybody know if Risograph GR hd black ink is ok
Short answer is no. RISO GR HD ink is only compatible with a GR3770, a 600 dpi machine.
Posted on Mar 30, 2010
How do i change the color of riso drUm from red to burgundy?
How-to: Convert Z-type Color Drums ' stencil.wiki
stencil.wiki/how-convert-z-type-color-drums Procedure for converting the color of a Z-type drum. Steps 1 - 9 also work ... Z-type Color Drums. Posted: 17 Oct 2014 14:04 by issuepress Last edit: 01 May 2015 14:20 by issuepress ... This tells the Riso to recognize newly installed ink tube.
Riso RP3505 drum color change - CopyTechNet.com
www.copytechnet.com > Forum > Technical Forums > Digital Duplicators Sep 9, 2008 - 3 posts - ‎3 authors Is there any way to change an RP color drum to black? How to change a drum color on a Riso MZ 770E? (I'm new ... 3 posts 8 Apr 2014 Riso gr3750 Drum versus GR377\GR373 Drums. 6 posts 1 Jul 2013 Riso RP3700 Print drums wont ink up 7 posts 28 Sep 2012 Riso GR 3750 alignment, drum and colour change ... 9 posts 3 Oct 2009 More results from www.copytechnet.com
change color drum riso Questions & Answers - Fixya
www.fixya.com > Forum > Tags Find solutions to your change color drum riso question. Get free help, tips & support from top experts on change color drum riso related issues.
Risograph GR drum conversion.mp4 - YouTube
z? 0:25 https://www.youtube.com/watch?v=YCttIfFdu0Q Jun 30, 2012 - Uploaded by SpareResidency Used citrus solvent to clean the exterior of an old red drum then switched the ink for a new tube of blue.
My Top 7 Risograph Lessons - Alfalfa Studio
alfalfastudio.com/my-top-7-risograph-lessons/ Jun 16, 2014 - When you need to add another color, you open up the drum door and change the drum to use purple, for example. The Risograph prints one ...
Replacing The Print Drum (cylinder) (color Change ...
www.manualslib.com > ... > Printer > RZ1090 > User manual Riso RZ1090, RZ1070 Manual Online: Replacing The Print Drum (cylinder) (color Change), Replacing The Print Drum (cylinder) (color Change), Removing The ...
Riso printing - Instructables
www.instructables.com/id/Riso-printing/ Risograph The underlying technology is very similar to a mimeograph. ... This master is then wrapped around a drum and ink is forced through the ... Change the color drum, change the paper on the glass sheet, make a master layer and . ... Remember that every different color you want to print, you have to print separate.
Jan 31, 2016 | Office Equipment & Supplies
Anybody know if Risograph GR hd black ink is ok for use in Riso FR machines?
Mar 05, 2010 | Eagle Signal Br1 30min Reset Timer
Reset RISOGRAPH GR3750
Check the Power PCB ,maybe some fusies' ve blown
Aug 27, 2009 | Eagle Signal Br1 30min Reset Timer
No drum in machine and can't pull out tray to put one in.
Look at your drum. Is it locked in it's home position?.. If it is then look into the machine.. Take a pair of needle nose pliers reach in and insert the into the female side of the cam and manually turn it so it matches the drum.. (with the machine off) Turn on the machine again and try to re-insert the drum. Look carefully at that cam in there.. It only can go one way.. It appears that you could turn it just 180 degrees and it would work.. but it won't fit.. This should solve the problem.. once the drum is in the machine it will find position b on it's own..
Apr 20, 2009 | Riso Office Equipment & Supplies
Riso gr 3750 error T14
Means a clamp error. Inspect the clamp on the drum to make sure it moves smoothly and that that clamping mechanism in the back of the machine works as well.
Apr 06, 2009 | Canon PC-140 Black and White Copier
Risograph GR 1700 E02
check the Paper Feed Tray.. is there something in the way? does it go up and down? if it is all the way up or down maybe it got pushed off the rail?
Mar 11, 2009 | Riso Office Equipment & Supplies
Code Error T4
T-4 is an ink overflow condition. You may need to check and clean out ink section of drum. Remove the ink then press reset button. Then turn off and on and re-insert ink.
Dec 01, 2008 | Riso RZ220 Duplicator
Code d--13, ---9 risograph rz220
Check out copytechnet.com. Its a free service that covers copiers only. You can get in touch with a Risograph technician to give you the answer.
Oct 08, 2008 | Office Equipment & Supplies
Hardware & Accessories Logo
52 people viewed this question
Top Eagle Hardware & Accessories Experts
Gene Haynes
Craig Butler
Craig Butler
Are you an Eagle Hardware and Accessory Expert? Answer questions, earn points and help others
