Question about Vehicle Parts & Accessories
I have a clifford G4 alarm/remote start system installed 12 years ago. since yesterday, the vehicle starts then shuts off. it appears that the module sends a signal to keep the starter engaged after it starts, so then it shuts off a few seconds later. i had this problem a few months ago and tapped the control module and it never happened again. we have below zero weather here in Chicago lately the last few weeks, but no problem....however, this started yesterday. Have not had a chance to tap the module. what do you think?
    Top Expert:
  • 867 Answers
It sounds like broken or cracked solder joints in the control module, hitting the module causes it to make connection temporarily
Posted on May 15, 2017
  • 12 Answers
SOURCE: remote start on my viper alarm wont stay running
it is getting a shutdown trigger from somewhere. check manual for diagnostic trouble code section to find out where from is step one.
Posted on Jan 15, 2009
  • 26 Answers
SOURCE: viper remote starter-
The start/stop 3x thing could be one of a few main issues. You need a bypass module or it needs to be reset. You need to program the tach if you're using it. Make sure with the new models(5101, 5301) it's programmed for auto transmission. The come default for manual transmissions.
Posted on Jan 16, 2009
  • 265 Answers
SOURCE: car alarm wont turn off
Try changing the batterys in the remotes mate
Posted on Feb 16, 2009
  • 58 Answers
SOURCE: car won't start, makes clicking sound
If you have a bulldog remote start, you should have it removed right away. I work at best buy, and we will not install these any more because of the problems they cause. You should buy something made by DEI, they cost a little more, but are very well made and come with a lifetime warrenty.
Posted on Aug 18, 2009
  • 33 Answers
SOURCE: battery went dead,clifford alarm locked the engine
Assuming that all is well with the vehicle's electrical system (fuses, etc...), the following should work, as Viper/Clifford uses the "fail safe" method of starter disable, and it only works to lock out the starter when the alarm is functioning properly and in the armed state.
That system has a "starter kill" system. When the alarm is actived, the starter kill is engages, and won't let the starter get voltage from the ignition switch. First thing I'd try is connecting the car's battery while the ignition key is turned to the "on/run" position. Cycle the alarm to arm, then disarm, so that the LED is not blinking. It also may require using the manual override button/switch (with the key on) to reset the alarm. Should start after that.
If all else fails, reconnecting the starter wires back together (they are spliced and running through the alarm via a SPDT relay.
Posted on Oct 23, 2009
The service light turned on, security light turned on and my car wont start after I tried to install a alarm system
Aftermarket car alarms/remote start systems are difficult to install in newer cars since many of them already have alarm systems and immobilizers in place. The aftermarket manufacturer will specify additional modules that must be purchased and installed in order to successfully integrate their product into your vehicle without causing conflicts. Some of these modules are expensive and some even require you to have a spare key for the vehicle to install into the module for it to work. Without more details on your vehicle (Manufacturer/year/model) and the alarm manufacturer ( and model), all I can make is generalizations as to what your problem is....
Feb 19, 2016 | Cars & Trucks
How I can get a service repair business for the diagnosis of a Clifford car alarm system?
First replaced the batteries, you may find a CR2032 in there easy to replace then try before blaming any other components
Aug 03, 2014 | Brand Remote Start/keyless/car Alarm Very...
Clifford g5 alarm how do i reset it after i was checking fuses it wont let me start the car
The car won't start because the Clifford alarm has a starter interrupt wire where the start wire runs through the alarm system module/relay. The unit then must still be active for the car not to start. If pressing the disarm/unlock button on your Clifford key FOB does not turn the system off, you will after to do it manually. You will need to locate the manual override button installed somewhere in the car that is connected to the alarm system. Turn the ignition switch to "on" or "run" and within 10 seconds press the manual override switch. That will turn the alarm system off and allow the car to be driven normally. I would then take the vehicle to an authorized Clifford or other DEI (Viper) install shop and have them diagnose your apparent problem.
Jul 31, 2014 | G5 IntelliGuard 770 P/N 919621 Car Alarm
I have had the Avital 4103 installed in my truck a couple of years ago. Over the last few days while driving, the horn alarm goes off by itself. It is happining about every 5-10 minutes. I need to keep...
The bypass module is most likely interfering with the vehicle data causing the OEM security to trigger. Take it to a security/remote start retailer and have the bypass module reprogrammed or replaced.
Apr 06, 2014 | 4103LX 4Button Remote Start System with...
When i remote start the truck it will run for about 30 sec. then it will turn off and the alarm will go off. if i started up the truck with the key and then push the remote start when i take out the key it...
Ok. You don't tell us what year, make, or model the truck is, but I'm assuming it is a later model. They all come with integrated alarm and immobilizer systems installed. If you did not get an aftermarket adapter to disable the factory alarm system, then if the vehicle is started without the key it will shut off and alarm after 30 seconds. Once you used the key, you satisfied the manufacturers alarm system and then your remote start worked. You need to get a module specifically designed for your vehicle and alarm system to use with the Viper to make it work. They can be a real pain to get working correctly. Good luck!
Aug 16, 2013 | 5204 Responder LE 2-Way Security and...
My Viper Alarm started going off while I was driving. I pulled over, shut everything off. Got out of the car and closed the door and locking and unlocking the vehicle wouldn't shut the car off. I opened...
The alarm may not be going off. Rather it may be a malfunction of the relay that is driving all the sirens and piezo. Next time it happens check for flashing parking lights. They will flash only when alarm is going off. Also ignition input to the alarm prevents this alarm from going off while driving. Panic from the remote can still be triggered. Got to play detective....
Feb 27, 2017 | Viper Vehicle Parts & Accessories
I need a Clifford 50.7x installation manual
go to www. and download for freeGod bless youcreateLink
Dec 14, 2012 | Clifford Matrix 50.7X - Car Alarm with...
I have a new prestige car remote installed recently and i have a problem how to shut off the alarm coz the installer did not or forgot to give me the manual. When i start the car remotely i press the...
You did not mention the year/make/model of your vehicle but, the issue appears to be the factory alarm. The installer failed to make the connection. If you intend to make the connection yourself I would need information pertaining to the vehicle. The (-) pulse before start wire for Prestige remote starters is black with a blue stripe. It is in a 4 pin connector at the module. This wire can be used to disarm the factory alarm before the remote start sequence.
Jan 23, 2011 | Prestige Remote Start
Scytek 5100 RS-2W system Problem
How do you reset the remote, alarm. I have a scytek two way security alarm, remote start. I can lock and unlock my vehicle, however the remote start and alarm won't work. When I press the middle button to have the car start it just beeps, and when I lock my car it just locks it doesn't beep to let me know the alarm is on.
Please advise, do I need another alarm, or just reset it.
Aug 14, 2009 | 5000RS-2W Remote Starter with...
Vehicle Parts & Accessories Logo
125 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
