Question about Toshiba 55G310U LCD TV
Multiple vertical lines
Has sound, looks like large squares
Vertical lines on my vizio p50hdtv10a
If its one large line an inch or two you have a problem with the x boards. If its several thin lines multiple its going to be in your digital/main board.
Nov 21, 2011 | Vizio P50HDTV10A 50 in. Plasma HDTV
Vertical lines, no picture
If the tv is an LCD television and you have multiple vertical lines with sound and button function ok..the fault is the T-Con module or the LVDS cable may be loose connecting to the T-Con
Feb 04, 2010 | Televison & Video
I have a Sharp AL-1631. The single copies made face down on the glass are fine. The multiple copies made on the automatic feeder have vertical lines running through them. Can you please assist me.
This is caused by the adf scan glass needing to be cleaned. If you look just to the left of the large glass you will see a thin strip of glass encased in plastic. You need to clean this glass. It may look clean but this glass is only used when using the feeder and sometimes any ink spots or dirt are not visible. If you only get the lines when using the feeder the problem is on this strip of glass.
Dec 02, 2009 | Office Equipment & Supplies
White Vertical line in the screen.
Again, this sounds like a light tunnel failure. See my other post about this.
I replaced my light tunnel with square brass tubing I picked up at the hobby shop.
Sep 21, 2009 | InFocus ScreenPlay 4805 Multimedia...
Sound is one but very often picture goes to just a line across the screen, mid-screen
sounds like cold solder joint in the vertical circuit. May be schematic inside case, or look on main board for silkscreen labels, ones starting with V are for vertical circuit. look at solder side with magnifier and you will most likely fine one or more "cold" broken joints, especially where large wattage resistors or IC's with large heat sinks are attached to the main board. Just reheat them and flow new solder on them and send me 5 bucks (only kidding) should be a good fix.
Jun 12, 2009 | Insignia NS- 27" TV27 TV
Vertical red lines on screen
LCD correct?
There are 2 types of lines they may be showing, both requiring the replacement of the LCD Panel.
1. Delamination Lines- they are usually multiple vertical lines that do NOT flow from the top to bottom of the screen. Looks look water dripped down or something similar
2. Single/Multiple Vertical lines - This is normally 1 or maybe a few solid vertical lines that travel from Top to bottom. I belive in some cases they may only travel to the screen center.
In both cases, this will always show when the TV is ON. Even if there is no signal being input to the TV. There are other possibilities but these can be the most common. Both require a new panel.
Apr 29, 2009 | Sony KDL-46XBR4 46 in. LCD Television
Green vertical line on the right side of screen
if someone found a solution for the verical line please post it. the laptop has never been hit and the vertical line just showed up there...
Nov 26, 2007 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
Vertical lines on LCD monitor
You have capacitor problem in power supply, if many lines then replace the bigest cap and find anymore that needs replacing. Its an AC filter problem.
Sep 14, 2007 | Dell E173FP 17" Flat Panel LCD Monitor
Print Problem - vertical lines
If the problem only occurs when using the document feeder, the problem is not usually caused by the drum. When using the document feeder, try to notice where the scanner (the light assembly under your scan glass)stops just before the paper is being fed. Some multifunction machines have a small piece of glass that is separate from the large scan glass and the scanner assembly stays parked underneith it as the original is being fed over it. Most likely there is something on the glass where the scanner parks as originals are being fed thru the feeder. When putting your original on the large scan glass to copy, the mark on the glass will only show as a spot, but will show as a vertical line thru the whole copy when using the feeder.
Feb 23, 2007 | Brother MFC-7820N Laser Printer
Multiple vertical colored lines on DVD player screen
check this out http://www.techlore.com/forum/thread/12629/
Sep 26, 2006 | Audiovox D2010 Portable DVD Player with...
Toshiba 55G310U LCD TV Logo
21 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
