Question about Singer 9960 - 9960 Quantum Stylist
Neelde broke now machine won't sew
Needle broke so i replaced and machine won't sew
Singer 3321 Talent Sewing Machine jammed after one turn forwards or backwards, even when thread and needle removed it won't work
This sounds more like the motor is bound up. The other solutions are, check for thread wrapped around moving parts, any belts that may have become displaced.
Mar 01, 2014 | Singer 3321 Talent Sewing Machine
Needle Wont Move When Pedal Is Pressed
check if the foot pedal connect correctly or not change the footpedal if still not working
Jan 18, 2014 | Singer 2250 Tradition Basic 10-Stitch...
Sewing machine bobbin
needle my be bent, you may be pulling the fabric to fast , with out knowing it
Mar 27, 2013 | Singer 3321 Talent Sewing Machine
II replaced and now handwheel difficult to to turn and cannot catch bobbin.
did you get the machine from a dealor or individual? not all machines put their needles in the same way. do you have a manual? it sounds like the machine needs to be cleaned (serviced). the oil is probably thickened, and will freeze the machine up. make sure the needle is in correctly, and threaded correctly. bobbin too.
Feb 08, 2013 | Singer 4423 Heavy Duty Sewing Machine
Sewing machine keeps skipping stitches
Generally, it means that the bobbin is too tight in the cavity.
1. Remove the bobbin
2. Try a drop of oil in the bobbin cavity in the machine, using a Q-TIP
3. After applying the oil, use a clean Q-TIP to remove excess oil in the cavity (may need more than one clean Q-TIP).
4. Replace bobbin.
(I'm sure you already tried differenty thread)
Hope this helps!
Sep 01, 2009 | Kenmore Irons
Singer 9960 - 9960 Quantum Stylist Logo
47 people viewed this question
Top Singer Irons Experts
Chance Miller
Are you a Singer Iron Expert? Answer questions, earn points and help others
