Question about Epson Stylus Photo R1800 InkJet Printer
Epson r1800 cleaning the head cleaning sponge
websnail
  • 419 Answers
SOURCE: Head cleaning after cartridge change
It sounds like you're trying to force the printer to clean the printhead and only ever partially resolving it before it clogs up again.
Ok... first you need to do is get a decent cleaning solution that can help de-clog the printhead. Usually Windex (the ammoniated version) is a good option but you might want to get some from your ink supplier.
Cleaning cartridges may be worth considerinb BUT I only ever use these are a passive cleaning system, not as active "clean NOW! dagnabit" impatient approaches.
Right, anyway... process is this.
  1. Leave your existing cartridges in
  2. Find a piece of paper kitchen towel or if possible a lint free piece of cloth and soak it in the cleaning solution. Fold into a 2mm or so thick pad.
  3. Move the printhead off the parking pad and out of the way to the left. (usually by starting the printer, waiting for the head to move and then pulling the power cord so you can freely move the printhead).
  4. Place the pad of solution soaked kitchen towel and then move the printhead back to sit over this in the parking pad.
  5. Then go make a cup of tea/coffee, do the ironing, or whatever but leave it alone for at least overnight.
  6. Remove the kitchen towel pad and replace with a fresh one
  7. Leave for a further 12 hours
  8. Remove the pad and turn the printer back on
  9. Run a SINGLE cleaning cycle and then a nozzle check
  10. Let the printer sit for an hour
  11. Try using the printer as normal.
What this approach does is allows the cleaning solution to slowly break down the clog by whicking up into the printhead nozzles and over time turn the hard pigment into a solution again. This requires time so patience is an absolutely essential ingredient.
A few things to note...
  • Obviously don't try to force a thick wad of paper towel under the printhead.. a single fold should be enough
  • DO NOT use the towel to scrape back and forth across the printhead as this will damage the printhead (it is incredibly sensitive and paper towel is more abrasive than you may realise!)
  • The cleaning solution is not just some off the shelf oven cleaner... If in doubt use distilled water and add more time to the process
  • If you're using cleaning cartridges do not use them to force clogs out... Instead allow the solution in them to work on the clog from above in the same way as the pad of solution in the parking pad will work on the clog from below.
Hope this works for you and try to adopt more pro-active measures to reduce the likelihood of clogging ie:
  • move out of particularly hot/warm rooms
  • move away from radiators
  • use the printer regularly (don't leave it idle)
The last one is the kicker... It's a lot like having a dog... They're happier if they're kept exercised so don't save the printer for special photos or whatever, try to use it for the odd graphic, letter too.
Good luck :)
Posted on Feb 18, 2009
SOURCE: How to remove print head of epson stylus photo r1800
Had the same problem - but the print head is actually easy to remove.
1) Remove ink cartridges
2) Remove 3 Phillips head screws at the bottom of the cartridge housing. (looking down from the printer front - top left, bottom left, top right).
3) There are 2 small plastic tabs on a plastic bracket that secure the flex cable on the right hand side of the cartridge housing. Gently release the tabs with a small flat head screw driver.
4) Lift the print head straight up (don't pull on the flex).
There may be a release for the flex to separate from the print head. But I did not see one. Instead I poured 1/4" of Windex in the bottom of a small plastic container and soaked my print head for about 15 minutes (occasionally agitating).
Then put back in reverse order - be sure to seat the flex in the guide (top-back-right) of the cartridge housing before screwing down. Then run a cleaning or two to flush the cleaning fluid out of the print head. (I have a waste ink tank installed so I am not worried about dumping excessive ink into the waste sponges).
The differences was remarkable - though there was still slight banding - maybe should have soaked longer (1 hr perhaps?) - I may repeat if it remains an issue.
Additionally there were large solid deposits on the left side of the print head which were responsible for scraping heavier weight photo paper. These dissolved in the Windex too.
Posted on Apr 07, 2009
  • 9 Answers
SOURCE: Color variations - not realistic in my prints from Epson R1800
If nozzle Check is OK Try Reinstalling the Driver.
Posted on Jun 02, 2009
jpweaver96
  • 3 Answers
SOURCE: epson r1800 nothing printing
I had same problems and i took it back bc it happened right away. I ask if there was any recalls and was told no. My best advice i was given about printers is buy a new one when your ink runs out bc the cost of ink will get you a better printer than you have now bc prices drop so much.
Posted on Aug 15, 2012
Epson Stylus R1800 is not printing correctly. It is skipping spots leaving clear areas across the page. Changed all the cartridges.
your problem is not with the inks it is with the printhead... try running the maintenance and head cleaning... epson is notorious for print heads getting clogged!! good luck
Mar 31, 2010 | Epson Stylus Photo R1800 InkJet Printer
Anyone know how to fix banding in dark areas of photographs?
I see your problem. You need smap and eject adjusment (PF adjusment), using R1800 adjsument program. Try to find at indoreset.blogspot.com
Jun 26, 2009 | Epson Stylus Photo R1800 InkJet Printer
My yellow ink head on my r1800 printer is clogged.
If it is within warranty then contact epson support. If not and normal head cleaning doesnt work then try a print head cleaning solution such as:
http://websites.uk-plc.net/UK_Inkjet_Cartridges_PLUS/products/Print_Head_Cleaner.htm
Hope this helps.
Mar 12, 2009 | Epson Stylus Photo R1800 InkJet Printer
Rebuild Epson R1800?
You could run head cleaning from the driver a few times and see if the nozzles start to clear out. If you send it in for repair they run a solution through it that is supposed to clean it out. If the solution doesn't work the head is like a $400 part.
Oct 04, 2008 | Epson Stylus Photo R1800 InkJet Printer
R1800 printing way too green/yellow
I have the same problem. Your printer head is clogged. You can use the head cleaning utility within Epson. However, if that doesn't work, you may need to use a head cleaning solution.
Apr 27, 2008 | Epson Stylus Photo R1800 InkJet Printer
R 1800
where can i get a print head for my epson R1800 printer?
Mar 04, 2008 | Epson Stylus Photo R1800 InkJet Printer
Jan 26, 2008 | Epson Stylus Photo R1800 InkJet Printer
Epson Stylus Photo R1800 InkJet Printer Logo
47 people viewed this question
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
