Question about Karcher DE4002 Steam Vacuum
Stopped working tried fuse and still not working any way i can fix this please
How do I replace the fuse in the canister body?
there should be a reset butto on the right side of the power head.If so try pushing that first,then ge back to me.. Chris
Jun 04, 2015 | Electrolux Epic 6500 Vacuum
Bosch pmf 190e just stopped working.fuse ok lead ok
I know this is an OLD post - but just in case anyone else comes across this question/problem - the fix is here - worked for so many people . . . http://jb-service.blogspot.co.uk/2013/04/bosch-pmf-180e-multi-tool-240vac.html
Aug 21, 2013 | Bosch Pmf 180 E Multifunctional All...
The roller brush stop working
the fuse in the plug may have blow so replace it any ways
Jul 12, 2010 | Dyson Ball DC24 Bagless Upright Vacuum
Floor level brush stopped rotating after it caught
Look at the bottom and check a thread of carpet isn't wrapped around the brush, if so try pulling it off or carefully cutting it off. You'll probably see a collection of fluff etc above the brush that's stopping it from sucking up, pull this out, or it just may be that cause the brush isn't working its not picking up.
If this helps please rate me
Jun 20, 2010 | Bissell 6594 PowerForce Bagless Upright...
DOES A DISHWASHER HAVE A FUSE? i HAVE 2 EXACT SAME DW STOP WORKING IN THE SAME MANNER - THEY BOTH JUST STOPPED MID CYCLE
yes, there is a fuse at the fuse box...there is no internal fuse... if they are both on the same circuit, that may be why it popped the circuit breaker (fuse)
Dec 05, 2009 | Vacuums
Hoover turbo cyclonic only 12 weeks old stopped working while cleaning. I was using the hand tool and after about 3 minutes it just stopped and will not turn back on.
try changing the fuse in your plug ( uk ) if this fails to fix it , have it repaired under warranty
print-icon.gifPrint/Download
Warranty The Platinum Collection Lightweight Bagged Upright plus Portable Canister warranty covers parts and service of the cleaner for six years.
As a member of the Hoover Platinum Collection, the Platinum Collection Lightweight Bagged Upright warranty gives the owner access to the exclusive Platinum Collection member services line for the best in customer service.
TTI Floor Care North America
7005 Cochran Road
Glenwillow, OH 44139
1-877-MY-PLTNM
Nov 15, 2009 | Vacuums
It just stopped working - without any smoke or weird smell. It does not look like motor but I do not know - Is it worth fixing it or buy something new. If I could I would buy the same one but they do not...
if the motor get over heated it will just switch off on you, let it cool down and try it again later,,,
there is also a thermal fuse inside the motor if this has poped on you then its a bust bin job im sorry to say,, there is realy not an easy way to fix this bit, and if you try by-passing this fuse,,,
it is a bit naughty!!! it could be just the brushes worn out on you but again getting them put in would work out cheeper to buy a new cleaner,
look at it this way,,, how old is it? how much work has it done for you? lots of years??????
maybe its time to put it out to grass
Oct 23, 2009 | Black & Decker HV7010 DirtBuster Handheld...
Gen 3 model Kirby vaccuum won't start
Checked your bag if they are full, if bagless check your filter. If still not working maybe the protected temperature fuse blown out. You need to open it and replace the protected blown fuse.
Jul 24, 2009 | Vacuums
Dyson DC04 not working
Have you trod on the cable at all, sometimes the cable breaks inside the sheathing, test by switching on and wiggling cable where it enters machine, if it starts then thats your problem, easy to fix, disassemble switch, cut off and discard 6 inches of cable then reattach the reamaining.
May 29, 2009 | Dyson DC14 Animal Bagless Upright Cyclonic...
Kirby G5 - Stopped
The carbon brushes in the motor need to be replaced. Very IMPORTANT....... DO NOT run the Kirby anymore until you get this fixed. If you do, the armature will be in danger of being damaged. (and that part is expensive!) The carbon brushes are reasonably priced, and you can use this online guide to get to them and change them. It's a guide for replacing the power switch, but it will help you change the carbon brushes too. Hope I've helped...
Marci
http://reviews.ebay.com/REPLACING-THE-POWER-SWITCH-ON-ANY-KIRBY-G-SERIES-VACUUM_W0QQugidZ10000000003752018
Nov 07, 2007 | Kirby G5 Bagged Upright Vacuum
Karcher DE4002 Steam Vacuum Logo
Top Karcher Vacuums Experts
kbright1
Level 1 Expert
richie46
Are you a Karcher Vacuum Expert? Answer questions, earn points and help others
