Question about Spin Master Flutterbye Flying Fairy Doll 25246421
Can't get Flutterbye fairy to fly
Don't know if doll needs to charge on base with batteries to get it to fly
How to put the legs on flutterbye dream swing
Request instructions directly from Flutterbye.
Jan 25, 2015 | Toys
My fairy just spins on the base and I have lost the instructions,please can you help
The defect with this toy is cheap design. What is happening is the weights at the waist are support to spin, and lift the top set wings. This causes it to take off. There is a little plastic piece inside shaped like an 8. One side of the 8 is attached to a small round ball attached to the weights (the round ball snaps into the top loop of the 8) and the other side of the 8 is attached to a plastic ball to the top wings. When off the weights hang down and so do the wings. When it starts the weights spin (lifting up) and they are suppose to lift the wings, since there attached to each other. Since the fairy has some violent crashes, the plastic 8 attachment dislodges off one of the other or both. I found on my daughters fairy both were snapped off and the small plastic 8 was laying in the waist. I reattached them and it worked fine for about 5 minutes and it came off again. Now we have lost the 8 piece and out of luck. To try and fix yourself. You can twist off the legs (just turn counter clockwise while pulling lightly). Once the legs are off lift the head off. A stem is attached with a washer, don't lose the washer. Look inside the waist and you will see the little plastic balls hanging off the side of the weights and wings. To fix just snap the 8 piece over the round balls. Probably won't last long because the plastic is already damaged some what and will come off easier each time it reattached. You will need a very small screwdriver to reach down to snap on or dental tools.
Jan 27, 2014 | Spin Master Flutterbye Flying Fairy Doll...
My flutterbye fairy doesnt fly
Jan 14, 2014 | Spin Master Flutterbye Flying Fairy Doll...
Flutterby fairy charge with charger blinking
STATUS LIGHT will FLASH RED when
charging. Allow at least 30 minutes
for a full charge.
STATUS LIGHT will turn ORANGE,
and then turn off when charging is
complete.
STATUS LIGHT will FLASH GREEN
when the batteries in the CHARGING
BASE are LOW. Replace the
batteries.
STATUS LIGHT will FLASH RED &
GREEN when there’s a CONNECTION
ERROR. Reconnect the FAIRY.
Jan 03, 2014 | Butterfly Toys
Flutterbye fairy is not flying, the wings are spinning but not strong enough to lift her, she is completely charged
Mine is doing the same thing ! Look to see the upper rotors are flying even with each other mine are not ... One seems to be spinning higher . I'm thinking that's my issue
Sep 22, 2013 | Cars & Trucks
Got a Pixie Light Fairy (Iridessa) and the wand is not activating any sounds. I replace the 3 batteries but that didn't solve it. And yes, the switch is in the on position (not in try me). Is there a known...
problem solved... wand is NOT waved in front of doll. Rather you touch the wand to the chest area to get the sound to activate.
Works...but lame. Commercials show you waving it and the box alludes to it as well.
Dec 28, 2010 | JAKKS Pacific Disney Fairies 9 inch Pixie...
I bought on of those falcon-x helicopters for my son and just wanted to know how to charge the battery as efficiently as possible. The helicopter needs to be off correct? And how long should it charge for...
The instructions say the helicopter is ready to fly when the led shows red. I found some info online that says to charge the helo for 35 minutes. I've been letting it go 45 mnutes, and have been getting abou6 6 minute flight times. Unfortunately, my helo will no longer fly forward or backward. Does anyone know how to adjust the control for the tail rotor?
Dec 25, 2010 | Toys
Spin Master Flutterbye Flying Fairy Doll 25246421 Logo
64 people viewed this question
Top Spin Master Toys Experts
Andrew Taylor
Andrew Taylor
Are you a Spin Master Toy Expert? Answer questions, earn points and help others
