Question about Fargo HDP5000 Thermal Printer
Hdp5000 not laminating completely
The laminator is leaving one end of the card unfused onto the card.
5 Suggested Answers
SOURCE: fargo pro l lamination
I cant even get my cards to print the lamination on there. Can you please help me!.. Can you show me pics on how you installed the Lamination rolls. Also is there a special driver you installed or option you clicked beside the over laminate one. THANK YOU SO MUCH!
Posted on Dec 11, 2007
SOURCE: Lam Error/Out
I contacted fargosupport.com and a technician walked through the solution, free of charge.
Posted on Jul 18, 2008
SOURCE: low temp error on DTC525 Laminating unit
I believe, it is the thermocoupler. We can get you this part.
Posted on Aug 18, 2009
CPU solution
  • 164 Answers
SOURCE: The Laminator has failed to warm up to standard
you have a bad heating plate there is nothing you can do unfortunately except for buy a new one! sorry and good luck
Posted on Dec 18, 2009
ERROR MESSAGE 246
There was a communication
failure between the Printer
and Laminator.
FARGO Electronics HDP5000 User Manual Page 96
Feb 25, 2016 | Fargo HDP5000 ID Card Printer Dual-Sided -...
Fargo hdp5000 error 273
ERROR 273 does not come up in the manual but I might have nailed it. This error is a generic error which applies to several issues but most likely if you've just recently fiddled with the printer it could be a motor or other cable not connected.
In my case I swapped out the laminator sensor and had forgotten to connect the cable back on the laminator motor. After I connected it all worked normally with no errors.
Surely hope this helps someone out.
May 27, 2015 | Fargo Office Equipment & Supplies
How do I remove the back of my GBC laminator to remove paper that is stuck inside the unit?
First, you must take out 4 screws out of the cover on each side of the laminator , then you will see the screws that hold the back panel onto the laminator. West Laminating secs 405-324-6092
Oct 14, 2014 | Gbc HeatSeal Ultima 65 Laminating System
Scotch Thermal Laminator not heating up.
well it sounds like you may have cut a wire or pull one somewhere. i would go ahead and take it apart carefully and check everything. may have unplugged something hopfully! let me know whwat happens!
Jan 31, 2014 | 3M TL902VP Scotch 9" Thermal Laminator...
Lamination Problem
You have to go to printer driver, see the general settings and put more darkness(normally it ranges from 0-20, it should be set at 10. Try puting the darkness at 11,12,13, etc until it laminates properly. Don't forget to put back the setting when printing ymcko, or you will burn ribbon.
If the head that prints color is the same that laminates, then you should be cleaning the head after use.
Jan 17, 2014 | Datacard SP75 Plus Card Printer
Laminator 17466 I need to take my laminator apart.
Can you please provide a model and brand for the device in question?
Oct 22, 2013 | Tools & Hardware - Others
What is a laminator?
A laminator is a tool used to plastic coat documents to protect them. Your social security card may have a laminate coating.
Jan 28, 2013 | Office Equipment & Supplies
Card Jam Error 112 & 245
please calibrate the Lam Film sensor.error 245 is lam sync error please check Lam power/connections and restart the Printer.
Oct 02, 2012 | Fargo HDP5000-LC ID Card Printer...
Guess I'm not too bright. Have a pack of GBC SelfsSeal Laminating Sheets, 9 x 12. Instructions say "Center item face sown on the clear non-adhesive." "Peel away the liner and...
It's not you, it's the instructions. They are just wrong and will not work as directed. However, I have found a way to use these sheets that works for me, but it is still not particulary easy.
Step 1) Lay the 1st sheet on a flat surface, adhesive side up. Pressing down on the small 1/2" strip of backing, peel away the large backing sheet exposing the adhesive. Holding the sheet you want to laminate face down and at an angle to the work surface, carefully align the material by "bumping" it up against the edge of the 1/2 strip. Once aligned, carefully and gradually lay the item onto the adhesive. Like I said, not particularly easy, but if you are careful, it will work.
Step 2) If you want to double laminate, which I usually do, the second laminate sheet seems easier to me. Leave the Step 1 laying flat on the work surface. Take a second lamination sheet and again, hold it down on a flat surface and peel away the large backing sheet, leaving the small 1/2" backing attached. Take this 2nd sheet and holding it over the 1st, face down and angled up from the work surface, align the 1/2" strips of both sheets together and again carefully lay the 2nd sheet over the first single-laminated item. The two 1/2" strips don't stick to one another allowing a bit more flexibility for alignment.
Press all of this together and work out any bubbles or wrinkles. Once that is done, pry the two sheets apart at the very edge to remove the two 1/2 strips.
Unless you are incredibly lucky the edges will never align 100%. I use a paper-cutter to trim off any irregularities after I finish laminating.
Apr 11, 2011 | Gbc Selfseal Letter-size Laminating Sheets...
I have a Lamiart-3201 laminator and the rollers are not working - or i cannot feed my item through the laminator. Usually I just put it in and the laminator feeds it out the other end...
Make sure your laminator is heated up properly before feeding material through. Usually, for a low-end laminator, you will wait anywhere between 10 to 20 minutes before it is completely heated up, allowing you to use it. There should be a red button that will tell you it is NOT ready yet, and a green button will tell you it is.
Nov 16, 2010 | Office Equipment & Supplies
Fargo HDP5000 Thermal Printer Logo
56 people viewed this question
Top Fargo Office Equipment & Supplies Experts
Safe-Card ID...
Are you a Fargo Office Equipment and Supply Expert? Answer questions, earn points and help others
