Question about Ricoh Compatible 4 Color Set Aficio MP C2050 Gestetner MP C2030 MP C2050 Savin C9020 Savin C9025 Lan
Scanner imagers keep getting fainter
The scanned images are now too faint. They were okay but now are barely legible
2 Suggested Answers
SOURCE: Image is Streched when scanned
there are two things to check one clean the read sensors there are 3 or 4 if it was Minolta i would tell you exculley where to clean 2 check the front ant the back of the scanner make sure it rests on scan glass evently .
Posted on Dec 27, 2007
Why does my Canon Mf 8380 scan anything handwritten very faint and non legible
Is the handwriting black ink? Colours come out poorly on most scanners.
You need to increase the contrast when scanning handwriting.
Jul 07, 2014 | Canon imageCLASS Office Equipment &...
Unable to get magic wand to scan documents
Mine was scanning and saving a black image. Needed calibration. To check, I calibrated on a bare lightbulb. Ugly, but there was an image. Recalibrate on brightwhite paper.
Jan 23, 2014 | VuPoint Office Equipment & Supplies
We have a Canon DR-9080C scanner. When scanning in Duplex on pages with data on both sides, the back side of each page is coming out unreadably faint. The header and any overall large blocks of black on...
The Canon DR 9080C is a 'contact' scanner. There is no optical lens, instead it uses a technology called "Contact Image Sensor' or CIS. The page to be scanned must be close to the glass for a proper image. This is achieved by a full-length rubber roller just above/below the scanning module. The roller is spring loaded and in case it gets stuck, there wont be enough pressure on the document to keep it close to the glass. ensure these rollers are moving smoothly and if required clean them. The rollers are on the opposite of the Scanning module.
S. Mohan, Chennai, India
Jul 29, 2011 | Canon DR-9080C Path-Through Scanner
My Epson Perfection 1650 Photo scanner keeps producing scans that have a 3-4 inch bright panel vertically down the middle. The image is visible, but the outer thirds are quite darker than the middle...
Make sure all the scanning settings are correct first then set everything first before you preview image then hit scan.
make sure the size is correct drag the image on the prview screen make ths dotted lines frame your image then scan
remember you tell the machine what to do by setting it, if you dont the machine trys to do thevscan its self. Good luck, have fun
Feb 08, 2011 | Epson Perfection 1650 Photo Flatbed...
Printer copies are very faint and barely legible
Would help knowing the make and model of the printer but sounds like a drum fault to me.
Nov 24, 2009 | HP Office Equipment & Supplies
When I scan film either color or B&W I get a faint grid pattern on the scanned image.
you need to change a setting in the software called "descreen."
if you enable it, it will eliminate that effect.
here is some info about that:
http://www.scantips.com/basics06.html
Feb 18, 2009 | Epson Perfection 4990 Flatbed Scanner
I want to increase size of small items to make them more legible
Set your printer to let you Preview before printing. From there, make sure you have the size upped to a percentage that will fill up the entire paper. You can also try scanning forms and such at a higher resolution initially. This will give you a bigger image to work with. Let me know if these are sufficient for your needs or need a different solution.
Jan 11, 2009 | Canon CanoScan LiDE 25 Flatbed Scanner
Scanning docs & size of pdf files on Mac w/HP l7680 All-in-one
The scanner produces a "picture" of the document, much as if you laid it flat on a table and took a picture of it with your digital camera. If you did this, your .jpg from the camera would be several hundred K at a minimum - comparable to the file size off the scanner. That's why the file is so big, it contains a picture and not text data - even though it's still a .jpg file.
If you reduce the scan resolution you will save space, but at the expense of legibility of the document image. To get it down to the smallest possible size, you will need to run the scanned image through OCR ( Optical Character Recognition ) into a Word document for example, and then print it out to a .pdf file. If you have a clean source document with few graphics this isn't as difficult as it may seem. Microsoft Office has an excellent OCR process known as Document Imaging. You need to carefully proof read the result but with a clean input Document Imaging is amazingly accurate in Office 2007.
In short, there is no easy solution to your problem.
Dec 30, 2008 | HP Officejet Pro L7680 All-In-One Printer
Scanned image on left is cropped by a good quarter of an inch.
To get the image on the right side, Select 11" wide and the length you want. Keep the paper guides at the far ends. Insert the paper at the extreme right side and the image will appear on the right side. The left side would appear dark and You may need software to clean. If you dont have Raster Editing software, best way is to stick your image onto a white paper and scan the whole paper. Ensure that the ends are trim. ( I am assuming it is faceup scanning)
S. Mohan
Feb 08, 2008 | Canon DR-5010C Path-Through Scanner
Ricoh Compatible 4 Color Set Aficio MP C2050 Gestetner MP C2030 MP C2050 Savin C9020 Savin C9025 Lan Logo
29 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
SOURAV KAPOOR
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
