Question about Samsung FX510BGS 30" Freestanding Gas Range with 5 Sealed Burners, 5.8 cu. ft. Convection Oven, Self-Clean, 4 Preset Menu Options, Proofing and Storage Drawer
Converting the Samsung NX583G0VBSR/AA to propane
Converting the Samsung X583G0VBSR/AA 30-in range from natural Gas to propane
Is there something available to convert a hardwick propane stove / oven to run on Natural gas?
Should only be a matter of changing the jets, see a gas fitter if they can be changed.
Dec 20, 2015 | Maytag Crosley Hardwick Caloric Kenmore 8"...
I Have A Jenn-Aie Model 720-0164 Natural Gas Grill. When I Grill, The Control Knobs Get So Hot Theyh Will Burn You. What Could Csuse This?
Can this grill be also used on propane? If so you might be running it too hot on natural gas, check to see if the control knobs have two different set of markings.
Sep 16, 2014 | Jenn-Air Outdoor Liquid Propane Lp...
Convert natural gas to propane on JGP945--part numbers do not match manual. orifices are color coded not numbered. Any idea on how to match?
Hi, W/D here.
I can tell you how I have done a similar appliance. I contacted my local propane company. They had all of the orifices, and cross reference guides necessary to convert it over to propane and they did it for free. Contact your local company. If your's won't do it for free like mine, they can surely get you the parts reasonably, and provide further guidance.
Best regards, --W/D--
Please take a moment to rate this solution so that we may continue to improve in helping others. Thanks.
Feb 24, 2011 | GE 30 in.Profile JGP945 Gas Cooktop
I have a bosch cooktop 5 burner and one burner lites its very dim and then goes out
Is this cooktop new? Was it converted to propane or do you use natural gas? If it was converted, I was just thinking they put in the wrong size orifice. If it has been working fine and is just now giving you problems, then check the burner holes and see if they are partially plugged from food spills.
May 18, 2010 | Bosch 30 in. NGP 732 / 736 Gas Cooktop
Can a dacor range be converted from natural gas to LP liquid propane ??
I will trade you parts. I have the NG version and need to switch to LP.
Email me at adjuster@me.com.
Thanks
Jul 10, 2009 | Dacor Preference SGM365SS Gas Cooktop
Propane conversion
All gaq cooktops come from the factory ready to be installed to natural gas. If the only gas available is propane the orifices have to be changed. The orifices are product specific and must be ordered for your particular stove.
That being said, if this is a new cooktop you have the answer. If this is a used cooktop and you do not know which style of orifices are installed now just contact your propane company and they will be happy to help you for free.
good luck with this. and please remember to rate my answer.
Feb 12, 2009 | Maytag 30 in. Admiral LGC1330 Gas Cooktop
JDS8130 Cooktop Conversion Kit : Propane to Natural Gas Conversio
here is a site that has gas conversion kits
http://en.allexperts.com/q/Major-Appliances-3603/Jenn-Air-gas-range.htm
Jan 31, 2009 | Jenn-Air 30 in.JGD8430ADS Gas Cooktop
Dacor pgm 365 lp to naural gas
Yes by a licensed person so as not to break any local laws or Kill You,
LPg typically delivers at a higher psi than natural gas, and the propane content requires more combustion air than the methane butane mix of natural gas,
methane CH4 needs 2 oxygen (O2) to make CO2 +2 H20
Propane C4H10 needs 7.5 (02) 4 CO2 5 H2O
the nozzle injecting the LPg has small diameter, The Gas certified plumber can remove the nozzle(s) and replace them with larger diameter Natural gas ones for a small price, most manufacturers make both, its a simple job
Cant stress - Gas Certified plumber/tradesman - strongly enough, one explosion will ruin your whole day
May 09, 2008 | Dacor Preference SGM365SS Gas Cooktop
Propane to Natural Gas Conversion
on the regulator there is a 1/2" nut, made of aluminum. loosen the nut, thur it around and screw it back in, there is a "NAT" on one side, and a "LP" on the other side, make sure the "LP" is facing out if you are using propane, and "NAT", if you are using Natural Gas. Very simple, all you need is a 1/2" wrench, or a small adjustable wrench,
Jan 06, 2008 | Dacor Preference SGM365SS Gas Cooktop
Viking range - no way to simmer
There is a conversion kit to convert the range from natural gas to propane, it is possible that it was not installed or not installed at the time of purchase. There is a part in the regulator that has to be switched from one gas type to another as well as individual burner orafices that have to be changed. You should have the point of purchase service verify that this has been done correctly. The complete information should be in your owners and installation manual or available directly from the viking website.
Nov 19, 2006 | Viking 37 in. VGSU161 Gas Cooktop
Samsung FX510BGS 30" Freestanding Gas Range with 5 Sealed Burners, 5.8 cu. ft. Convection Oven, Self-Clean, 4 Preset Menu Options, Proofing and Storage Drawer Logo
88 people viewed this question
Top Samsung Cooktops Experts
Lawrence Oravetz
Tom Chichester
Dave Lammas
Level 1 Expert
Are you a Samsung Cooktop Expert? Answer questions, earn points and help others
