Question about Argosy HV335T
Hdd not showing up
The hdd doees not show up when plugged either iinto the tv or my laptop. I can still play it on my tv through the USB port
Hdd 2tb only showing in device & printers
Sounds like you require new drivers for the USB sockets. Only use Acer drivers, Microsoft are not trusted to work without issue.
Acer Explore Beyond Limits
Aug 30, 2016 | Acer Aspire V5-571P-6835 15.6" Touch...
How can we play video from a USB device? Why can we not download more apps???
Shop for tv How can we play vide... on Google
WD TVĀ® Media Player
$109.99
Staples
(165) Hauppauge Computer Ha...
$84.99
Dell
(400) C2G 29351 Micro USB to...
$21.23
Sears Audio?Technica ATR2USB 3.5...
$13.95
zZounds Diamond ATI TV Wonder H...
$39.92
B&H Photo-Vi...
(12) Search Results
    USB Flash Drive Movies on your Flat Screen TV - YouTube
    ? 4:10
    https://www.youtube.com/watch?v=ge4Wo9FQf8w
    Oct 5, 2014 - Uploaded by 21NorthMedia
    How to watch Movies & Photos from your USB Flash Drive via the USB Port on your Flat Screen TV.
    Watch a movie on your TV from a USB drive. - YouTube
    ? 2:40
    https://www.youtube.com/watch?v=jOhvbdVkPaM
    Nov 10, 2012 - Uploaded by DIYallday
    I'm trying to play movies from my USB port, but when I plug it I can't .... My LG 47" TV will recognize and open the flash drive, but shows empty.
Jan 05, 2016 | Televison & Video
I have a Toshiba Desktop Ext Hard Drive PH3100U-1EXB ... i unplugged it from my desktop to plug into my laptop like i have done before but this time it wouldnt load so i tried to eject it but it wouldnt...
but does it still work on the desk top.
if yes, then you have lap top issues, ONLY.
easy ,huh?
try all lap top USB ports no ext. hubs allowed.
what is wrong in the LAP top OS, unstated)
are you using the correct external power adaptor for both Desk and lap top usage,
have you tried a diff. usb cable.
Laptops can not power the hdd via the USB at all, and in fact
should be avoided at all times. no matter.
the laptop can be infected.
the laptop might have USB issues, with drivers.
do a USB driver update. (no 0S stated)
does the HDD show up in Disk manager, as DISK2
can you set the drive letter?
can you set the volume label on this disk via DM?
if yes, you then can read and write the drive.
as stated on all pages for USB
disconnect all other USB devices, and now try this HDD.
do a full virus scan, and malware scan
do wInDoZ update.
I think i hit them all.
Oct 01, 2013 | Computers & Internet
I have just acquired a 500 GB USB HDD and its NTFS formatted, it doesn't show when I plug in SONY BRAVIA USB port
I think it should also come with a power supply also.Does it have lights on it. Try a different port.
Mar 05, 2012 | Computers & Internet
My external usb hdd showing unknown device
If the unit has mains power, check that it is getting it. Also if it comes with two usb plugs then make sure both are plugged into usb ports on your pc. Try the unit on someone elses pc/laptop. if it works on theirs then your pc has a problem with the usb ports.
Aug 05, 2011 | Seagate FreeAgent Go 250 GB USB 2.0 Hard...
My external HDD is no longer recognised by my PC. The usb port I tried works with other devices so that's not the reason. The curious thing is that when I connect the HDD to my TV I can view & play...
Plug it in, then on your desktop right click the My Computer icon, then click on Manage. From the window that opens click on Disk Management. In the right hand pane, you may then see your drive displayed. Right click in the lower right pane on your device and click on Explore. If it open the drive to show the files, you should be able to come out of all the windows and then access the drive normally.
Please rate this answer.
Cheers
Bob
Jan 09, 2011 | Western Digital My Book Essential 1TB...
Drive is not ready to be read ?Error Check/device/harddisk1/DR7 ?
if you external hdd do not show on other computers, usually it meant that power supply on these casings die... but in this particular case it is possible that power supplied by usb port is insufficient to support data transfer. connect recommended power supply (on the back of this particular model you have usb plug and power plug, power supply is/was sold separately) usually hdd inside is still fine and retain data.
if this did not solve your problem, i would suggest purchase little powered universal hdd craddle, they cost about $15 to $25, remove, hdd from casing and connect to the craddle. data should be then accessible directly from your usb port.
as long as hdd is turning, data is accessible and recoverable, even if disk was wiped off.
Jul 20, 2010 | LaCie Design by F. A. Porsche 160 GB Hard...
Can I play my Ipod on my Lg tv through the ipod
Not if the USB port on the TV says "SERVICE" next to it. At least I don't think that it would work. But go ahead and try it. It can't hurt anything.
Plug it in and toggle through the input modes to see if there's an extra one showing your Ipod. Or look within the MENU settings to see about turning on or accessing the USB port as a video input.
Dec 05, 2009 | LG 32 in. LCD TV
HDD from dropped laptop
Could it be a power issue? Some older laptop HDs need more power than one USB port can provide and won't spin up properly. If you have a cable with your HD enclosure which had two USB connectors on the end, make sure you plug both into ports on your laptop.
When they don't spin up correctly, you tend to hear them clicking as they try to spin & then cut out. Have a listen to it when you plug it in & see what you can hear.
Sep 01, 2008 | Seagate 160GB 3.5" External USB Drive 160...
Argosy HV335T Logo
37 people viewed this question
Top Argosy Televison & Video Experts
Electro Med Services...
Are you an Argosy Televison and Video Expert? Answer questions, earn points and help others
