Question about JVC GR-D73E Mini DV Digital Camcorder
E03 eject and reinsert tape
Hi Some black rubber part felt off from my camcorder. Now I have E03 error eject and reinsert the tape Can you tell me how or where should I put the small rubber part back? Thanks
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 56 Answers
Because of the black rubber part you have that problem so now you need to find one and insert on the bottom part of you tape deck for your camera to work.
Posted on Feb 11, 2014
SOURCE: Error message: E03 Unit in Safeguard Mode - Remove and reattach battery
HI, ERROR CODE E03 MEANS THE THE TAPE IN YOUR CAMCORDER IS TOO SLACK, ALL YOU NEED TO DO IS EJECT THE TAPE & TIGHTEN IT USING YOUE THUMB LIKE I DID, ONCE I PUT THE TAPE BACK IN THE ERROR HAD GONE ( FOR EVER I HOPE!) GIVE IT A GO ANYWAY, HAYLEY X
Posted on Mar 21, 2007
Taisha
  • 44 Answers
SOURCE: My JVC GR-D77OU Mini DV
Remove the battery and or the power supply (plug), leave it out for a few minutes, then reattach. This should solve your problem.
Let me know if this helps....
Posted on Jan 03, 2009
SOURCE: JVC Camcorder Model # GR-D270U
I thought this was a camera issue, but it ended up being a tape issue. So it shouldn't matter if you have the same model of the JVC mini camcorder as I did or not. Anyway, the tape has a tab that "locks" the tape to keep from recording over it accidently. I moved that tab and it started working. If your tape is stuck in the camera, you may have lost the tape already. Try to get it out of the camera without damaging the tape or the camera...more importantly the camera. You may have to take it to a professional to prevent damage. If you get it out undamaged, check to see if the tape is locked or not. Move the tab and try the tape in the camera again (unless you're afraid of it getting stuck again). In that case, try it in another camera. That's how I discovered that this was a tape issue rather than a camera issue...because I tried the same tape in a different camera and got the same error message. Don't despair if your tape comes out with part of it sticking out or crumpled, as long as it's not broken, you can salvage it. Even if it's broken, you can probably salvage the majority of the tape by taping it back together (call a professional, you may need special tape for this), just don't touch any of the undamaged tape or pull it out of the cassette too far and all you will lose is the damaged portion. I actually couldn't see the tab well enough to tell if it was in locked or unlocked mode since it's so tiny and my close-up vision is getting blurry, but I moved the tab to opposite of what it was and that seemed to do the trick. My mistake was in trying to save money with the cheaper tapes...next time I'll spend a little extra for the better tapes to avoid all this headache. Hope this helped. Have a great day!
Posted on Apr 08, 2009
SOURCE: Can't play or record because of error E03 on display
I GOT
Posted on Aug 30, 2009
kala
  • 156 Answers
SOURCE: GR-DVL320 keep getting E03 error indication.
1. The idler gear does not engage with the reel disk well.
2. Though the idler gear and reel disk are engaged with
each other, the tape is not wound because of overload
to the mechanism.
3. No FG pulse is output from the reel sensor.
4. No power is supplied to the reel sensor.
5. Tape transport operation takes place with a cassette
having no tape inside.
6. The tape slackens and no pulse is produced until the
slack is taken up and the tape comes into the normal
Posted on Sep 12, 2009
How do I get a jvc camcorder out of safeguard mode. Error 06
Step 1 Look at the camcorder's display to identify if it is in Safeguard Mode. If its display indicates an error number of E01 to E06, your camcorder is in Safeguard Mode.
Step 2 Disconnect your camcorder from its power source and remove its battery by sliding the latch forward and sliding the battery down while pulling it away from the camera's body. Wait at least two minutes before continuing.
Step 3 Remove the camera's cassette by pressing the "Eject" button, waiting for the cassette door to open, and lifting it out of the tape bay. This step is only necessary if the camera indicates the E03 or E04 error code or it tells you to eject and reinsert the tape.
Step 4 Replace the camera's battery, power connection and cassette, and turn the camera on.
Sep 04, 2015 | JVC Video Cameras
MY CAMERA SHOW E03 ;unit in safeguard mode ;EJECT AND REINSERT TAPE WHT SHOULD I DO............
JVCGR-D270.Digital Camcorder. When we put the tape in the cam it chews the tape whiles loading and says that it's in 03 safe guard mode. Please help.
Jan 24, 2011 | JVC GR-D73AG Mini DV Digital Camcorder
Error code E03,camcorder shuts down,won't eject tape.How do I fix it.
E03 means the motor drive has failed.The damage is permanent. The camcorder GR-AX5 is too old to repair.Recycle it and buy a new one.
Nov 10, 2009 | JVC GR-AX230 Camcorder
GR-DVL320 keep getting E03 error indication. Ejecting and reinsertion of the tape does not seem to be fixing the problem, also says unit in safeguard mode. What do I do to remedy this?
to the mechanism.
Sep 02, 2009 | JVC GR-DVL320 Mini DV Digital Camcorder
E04 Error Message
Here's what i found. I was able to clear the message by opening and closing and ejecting the cassette. I also had to play with the battery at the same time. Keeping the cassette door open and then pulling out the battery. After is did this a couple of times i got the message to clear. I too haven't used my camcorder for some time and now that the error message has cleared the camcorder tells me that i need to clean the heads. Hope this helps. Below is the message i found that pointed me toward ejecting the cassette. Good Luck, i'm off to buy a tape head cleaning cassette. An error indication (E03 or E04) appears. - (E03 or E04 UNIT IN SAFEGUARD MODE REMOVE AND REATTACH BATTERY) This massage a malfunction of some kind has occurred. In this case the camcorder's functions become unusable. - Eject the cassette once and re-insert it, then check if the indication clears. When it does, you can resume using the camcorder. If the indication remains, consult your nearest JVC dealer or service center
Oct 17, 2007 | JVC GR-DVF21 Mini DV Digital Camcorder
Frustrated
E03            TU & SUP REEL FG
In the case no REEL FG is produced for 4 seconds
or more in the capstan rotation mode after
loading was complete, the mechanism mode
is shifted to STOP with the pinch roller set off.
This error is defined as [E03].
However, no REEL EMG is detected in the
SLOW/STILL mode.
to the mechanism.
Dec 09, 2006 | JVC GR-D290 Mini DV Digital Camcorder
JVC GR-D73E Mini DV Digital Camcorder Logo
357 people viewed this question
Top JVC Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
