Question about Samsung Refrigerators
Error code 8889 on display
Fridge model number rfg237aawp has error code 8889 on display, I have unpluged for 2 minutes and plugged back in, still will not go away, unit is cooling properly and working ok, ice maker will not dispense ice though
Error code 8889 on display Fridge model number rfg23
Try resetting it by pressing the top left and right buttons on the display and holding them for 10+ seconds.
Best to you.
Mar 10, 2018 | Refrigerators
The display stopped showing temps and displayed a "6". The actual temperatures dropped to freezing. I unplugged the unit a few times for up to 2 days but the same issue developed.
Whirlpool Refrigerator Error Code: Flashing 6 on the fridge display
Condition: The 6th Sense technology is activated - If you put warm food in the refrigerator or leave the door open, the 6th Sense technology kicks on to return the refrigerator to the set temperature. The flashing 6 should go away once it gets back to the right temperature.
Part or Parts: Allow fridge to get back to temp on its own (no parts required)
Whirlpool Refrigerator Error Code: 6 on the fridge display
Condition: Computer error
Check: Remove power for 5 minutes
Part or Parts: If code returns replace mother board
Apr 29, 2016 | Avanti Refrigerators
I have an LG fridge display giving me ER F1 code. i can unplug the fridge and plug it back in and the display resets for about 2 minutes and the the code comes back?
The ER 1F code usually means that there is a problem with the ice compartment fan, the ice maker motor or one of the control boards (the one for the ice maker or the main control unit). You can try resetting the refrigerator by leaving it unplugged for a day. Next check for ice build up on the fan that is blocking it from turning. Usually, if the fan hasn't been turning, you will have to at minimum replace the motor. It will burn out trying to force the fan to turn.
Sears Parts Direct has a diagram of the LFX23961SW case parts here: http://www.searspartsdirect.com/lg-refrigerator-parts/model-LFX23961SW/3204/0161000/K0810254/00001.html . The fan motor is part 405G.
I hope this helps.
Apr 15, 2015 | LG LFX23961SW French Door Refrigerator,...
My refrigerator was moved away from the wall and unplugged for 2 weeks. They just moved it back and plugged it in. The displays light up, the lights come on but it is not cooling. What should I do?
Leaving it unplugged for 2 weeks should not have caused any problems. The fridge may have been on a defrost cycle. As the unit is unlikely to have had any frost, it should have started refrigerating about 15 to 25 minutes after plugging it in.
Apr 09, 2015 | Refrigerators
Kul dehumidifier error code as unplug and plug back in still has the error code.
"For the above error codes, Power the unit off, and then unplug the unit for 15 minutes. Plug in and power on. If the issue persists, please contact customer service."
https://edgestar.zendesk.com/hc/en-us/articles/201000315-My-dehumidifier-is-displaying-an-error-code-What-does-it-mean-
Apr 28, 2013 | KUL 65 Pint Dehumidifier
Fault code EF is flashing on my Electrolux fridge FSC23R5DSB6. What does this code mean?
EF on the Electrolux refrigerator digital display means "evaporator fan."
The long answer is, it doesn't necessarily mean there is something wrong with your Electrolux refrigerator.
Turn the power off on the digital display and carefully unplug the refrigerator from the power source. Leave the refrigerator unplugged for three to five minutes. Plug the refrigerator back in and give the refrigerator a few minutes then turn the power button back on. Press the default button on the display and see if the EF code goes away.
Electrolux recommends that you do not plug the refrigerator into an outlet that has a reset button. If your refrigerator is plugged into one of these outlets, try plugging it into another outlet and see if the refrigerator resets itself.
Hope this helps.
Jul 21, 2011 | Refrigerators
Our power went out due to the snow storm, and the display panel shows 88 on each side...how do I reset this...will this cause the fridge temp to go up?
From http://www.samsung.com/us/support/supportMain.do
Your refrigerator is equipped with an onboard diagnostic system. If the diagnostic system detects a fault, it will display a specific line segment on you refrigerators LED display. If your refrigerator is displaying an error code, please note the error code, and reset the refrigerator by unplugging the refrigerator for 30 seconds. When the refrigerator is plugged in, it performs a self diagnostic check of the various sensors and functions. If the error code reappears your refrigerator will require service. Please click the "Create Online Service Request" button below this article to initiate the service process. After a power outage the display panel may start blinking "88 88." If you unplug the unit for 30 seconds then plug it back in the display will return to normal operation after several hours. The power outage/surge can cause a communication error between the circuit boards in the unit. It can take several hours for these boards to stabilize.
If the display does not reset, go to the Samsung Support link above, enter your model number, and follow the prompts to request a service ticket.
Good luck, and if this helps, please rate my answer!
Feb 02, 2011 | Samsung Refrigerators
I have a whirlpool side by side fridge. This
On some models you have a mother board located on the back outer section of the refrigerator that can be faulty. There is a tech sheet located behind the kick plate or under the front of the ref bottom to refer to. If someone olays with the digital controls you may have to reprogram the mother board, which is explained in the tech sheet.
Jul 21, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
My kenmore Elite 795.77569600 fridge has er ff code
I pulled plug out of the wall socket waited a minute re-plugged unit in and so far error hasn't come back.
Sep 01, 2009 | Kenmore 73502 / 73504 / 73509 Bottom...
EF error code on frigidaire refrigerator, help!!!
My Frigidaire also got the dreaded E-F error code and stopped cooling. Technician over the phone told me to unplug it for 5 minutes and then plug it back in to see if the control board would reset itself. Did that with no luck. Unplugged the refrigerator last night while I tranferred my food to a spare fridge in the garage. Plugged the fridge back in this morning (9hrs later) and it works fine with no error codes. It looks like the control board has reset itself but how long it takes...I dont know. 10.. maybe 15 minutes? Well more than 5 at least. Guy over the phone told me that you can buy DRY ICE at a local grocery store and put it some in your freezer and a little bit in the frigdge to keep the food cold for a day. I had a spare fridge but I thought that was a good tip for anyone that needs to buy time for a tech to come repair the fridge. I had just bought $300 in groceries the night before so that tip would have come in handy if I did not have the spare fridge. I have no idea what the EF error was for but it's been 5 hours since I plugged my fridge back in and it's running fine so I'll cross my fingers. Got around to cleaning the fridge and plugging in a surge protector too. Hope this post helps someone out there.
Apr 03, 2008 | Refrigerators
Refrigerators Logo
102 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
