Question about John Deere Pto Clutch For Stx38 And Stx46 Lawn Mowers
I have a oil leak on jd stx 38 on the bottom of. Engine
5 Suggested Answers
SOURCE: Have a JD STX 38. Put an ign light on it, no
have same tractor same problem mine was coil ran but when i shut off after mowing wouldnt start changed coil no problem since
Posted on Aug 21, 2009
nova2nv
  • 197 Answers
SOURCE: main fuse for jd stx 38
Older ones had a fusible link coming off the starter solenoid and routed just to the right side of battery base. and going to key switch.The newer ones had the fuse located just to the rear of battery.
Posted on Nov 16, 2009
BAMOUT
  • 2478 Answers
SOURCE: how to replace a JD STX 38 PTO clutch on riding mower
Check clutch interlock first. They trouble on this tractor. The clutch removal is top of clutch is a nut, some have a bolt, remove nut.
Posted on Apr 14, 2012
the_djdan
SOURCE: Wiring diagram for John Deere STX 38
hope this helps
Posted on Jun 04, 2012
Oil Leak Toro 16-38-XL
Dan, Clean engine with a degreaser and power wash off carefully so as not to soak electronics. After all excess oil/dirt and grime are removed start engine and observe where oil is leaking from. Tighten bolts/replace gasket/seals/etc. If having dificulty locating oil leak consider getting a Dye additive to put in engine oil, this will aide in finding leak. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to Troubleshoot Leaking Oil
Fixing oil leaks
Using UV Dye to help find oil leak
Found my oil leak Now screwed
Jul 27, 2016 | Toro Garden
D40-stx turbo Desil 2006 loud knocking from engine
Diesels leak oil. If you let it get low too many times, you have probably spun a bearing. Is the knocking from the bottom? It is easy to tell. Listen from the top and bottom.
Oct 16, 2014 | Cars & Trucks
How to replace a JD STX 38 PTO clutch on riding mower
Apr 14, 2012 | John Deere Garden
Need diagram to replace belt on manual trans john deere 265
See if this is even remotely close to your mower deck:
http://opebycrigby.tripod.com/decks/jd/jd48edgew.jpg
Also see if you can locate the mower deck model number i.e STX 38, STX 42 (Deck color Black or Yellow?) Should be a silver decal with black lettering. Also... there is supposed to be a belt routing diagram on the mower deck. (Another silver decal with the belt routing picture)
Kelly
Apr 13, 2011 | John Deere Garden
I have a poulan pro chaisaw leaking bar oil from the bottom
Remove the bar and chain. Clean the oil port on the side of the engine and inspect any seals for damage. Start the engine without the bar--it should ooze out oil when engine is running fairly fast. If ok, clean the oil passages in the drive end of the bar--particularly the small passages that lead from the large holes into the chain groove. Clean the entire groove and make sure the end sprocket (if equipped) turns freely. Reassemble the bar and chain--tighten the tension until the chain does not droop from the bar bottom (chain cuts toward you on the bottom run), and yet moves freely by hand. Hope this helps!
Mar 21, 2010 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
Main fuse for jd stx 38
Go to the web site (yesterdays tractor.com) then go to john deer message board they can tell you everything you need to know to get the right one and where.
Oct 10, 2009 | John Deere 420,1020,2010,2020,2510,2520...
Aug 17, 2009 | John Deere 420,1020,2010,2020,2510,2520...
My jd stx 38 has a low power problem
You may still have a dirty carb or bad gas. Clean carb out and add some Seafoam gas additive to your tank to see if it clears up.
Apr 28, 2009 | Garden
John Deere Pto Clutch For Stx38 And Stx46 Lawn Mowers Logo
130 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
