Question about Farenheit DVD-35 Car Video Player
No Power for Farenheit DVD-35 mobile car player
I have a Farehheit DVD35 player. What are the color's and voltages of the 14 pin connector on the back of the unit. I recently had a remote start and wiring removed and they cut the power to the DVD. They do not know what the input wies or voltages are. I have lost the owners/installation manual.
  • Anonymous Oct 14, 2008
    Having the same issue. I've been continually googling this solution, and I get no responses! C'mon, google!
Take the cover off of the unit and the four screws that hold down the disc driver and you will find a printed layout of the receptacle on the back. Jim
Posted on Jul 27, 2010
Need color code for 16 pin connector, power plug
Pin Number Wire Color Function 1 White Left Front Positive 2 Green Left Rear Positive 3 Violet Right Rear Positive 4 Grey Right Front Positive 5 Blue/White Amplifier Remote 6 Blue Antenna Remote 7 Red Accessory 12 Volts 8 Black Ground 9 White/Black Left Front Negative 10 Green/Black Left Rear Negative 11 Violet/Black Right Rear Negative 12 Grey/Black Right Front Negative 13 Sky Blue Telephone Mute 14 Orange/White Illumination 15 Not Used Not Used 16 Yellow Constant 12 Volts
Sep 18, 2015 | JVC KW-AVX706 Car DVD Player
Farenheight van dvd player very dark screen
If you visit FarenheitUSA com Support you can download the manual for your unit (free).
Mar 14, 2014 | Farenheit DVD-13 Car DVD Player
I lost the 4pin wire connector for my dvd-61 but found another one that fits. the wire on this one has 2 yellow and 2 black wires. i dont want to damage the unit by hooking up the power wrong. i cant find...
Its best to buy a new connector rather than using different ones as colors could be meaningless depending on where it was made as in china and that some colors are used with no significance to them.
Or you could try that connector worst that will happen is either unit won't turn on you Fuse in fusebox will blow which is so cheap to replace and normally you have box of spare fuses most people have them.
Aug 13, 2010 | Farenheit DVD-61 Car DVD Player
My Farenhiet will not power on
Verify input power is12vdc, and that the fuse ( should be inline with the power supply wire or in fuse panel depending on installation) is not blown.
I’m happy to assist further over the phone at https://www.6ya.com/expert/robert_aad3edb7dfa380b9
Mar 10, 2009 | Farenheit DVD-35 Car Video Player
Can't eject the dvd from a farenheit md-830cm
First Plug out the dvd player , then remove the cable from the back of the tv , leave for about 5 minutes then put the cable back then plug back in startup and it should work if not bring it back to the place where you bought it .. Hope i helped
Dec 30, 2008 | Farenheit MDM-830CM Car DVD Player
Farenheit DVD-36 Car DVD need wiring diagram please
USUALLY THE BLACK IS ALWAYS GROUND AND THE RED CARRIES THE FUSE. IF IT DOES NOT SOLVE YOUR PROBLEM I GUESS YOU WILL HAVE TO TAKE IT TO A TECHNICIAN .THANK YOU.
Aug 14, 2008 | Farenheit DVD-36 Car DVD Player
Can't get screens to work
there should be a color fuse and a fuse to make the screen power up the wires the fuse are on are yellow and red try that if it doesnt work check your ground
Jul 03, 2008 | Farenheit T-7013HRS 7 Wide (16:9)...
Power supply
ATX Version 1.2 - 20 wire motherboard connector Pin 1 Pin 2 Pin 3 Pin 4 Pin 5 Pin 6 Pin 7 Pin 8 Pin 9 Pin 10 3.3V 3.3V Gnd 5V Gnd 5V Gnd P_OK 5VSB 12V Oran Oran Blk Red Blk Red Blk Gray Purp Yell Oran Blue Blk Green Blk Blk Blk White Red Red 3.3V -12V Gnd P_ON Gnd Gnd Gnd -5V 5V 5V Pin 11 Pin 12 Pin 13 Pin 14 Pin 15 Pin 16 Pin 17 Pin 18 Pin 19 Pin 20 The color scheme used for the voltages in the 20 pin connector holds for the other ATX standard power supply connectors. However, brand name manufacturers often build proprietary power supplies or make up their own color coding, so I wouldn't throw out a power supply that supplies 5V where you think it should supply 3.3V. It's more likely a proprietary design than a failure.
Feb 21, 2008 | Computers & Internet
Farenheit DVD-35 Car Video Player Logo
274 people viewed this question
Top Farenheit Car Audio & Video Experts
Martin Clarke
Martin Clarke
afairman1927
Are you a Farenheit Car Audio and Video Expert? Answer questions, earn points and help others
