Question about Sony KDL32L5000 32 in. LCD HDTV
Setup code Direct tv remote RC66RBX - Sony KDL32L5000 32 in. LCD HDTV
Need code for remote control
Benny, Check the attached links, direct TV codes.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
DIRECTV Remote Control Code Lookup
How to Program DIRECTV Remote Control DIRECTV Support
DIRECTV Remote Setup to Change the TV Input Source
4 Simple Steps to Direct TV Remote Codes
Mar 11, 2016 | Televison & Video
My remote was working fine until i moved. I have Direct Tv and the remote from Direct Tv works on guide. I bought a new remote from Magnavox but it doesn't work my tv. what should I try? '
You have to program the remote control to synchronize with TV. If you wish to get moredetails; codes, three digits, four digits or five digit ones, check this link. Pull up older posts there. Setup code list and setup instructions to some popular model remote controls are given. Select the 'Timeslide' option from the drop-down list by the 'Sidebar' at the display window. It will make search easy.
Mar 17, 2013 | Televison & Video
I have direct tv and want the remote to work
0568,0193,0182,0162,0155 are the codes to check. If you wish to get more setup codes, check this link. Setup code list to DirectTV remote control are given. Pull up older posts.
Mar 04, 2013 | Samsung AH5900092W Remote Control
Universal Remotes
If there is setup codes for your TV brand with the code list of the remote control you bought, it should synchronized with the TV. If there is no code, you can try a code search method. Even if it do not help you, you must have to buy an other one.
Code SearchIf after trying "Direct Code Entry" your device does not respond, or if your brand is not listed, try doing a search of the code library for your code by following these steps.
  1. Manually turn on the device (TV, VCR, etc.) to be controlled.
  2. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  3. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks once, then stays on.
  4. Press the CHANNEL UP button repeatedly (up to 300 times) until the device to be controlled changes channel. The red indicator blinks, then stays lit.
  5. Press and release MUTE to install the code. The indicator light goes off.
Most users will want to store VCR codes under the VCR button, Cable codes under CBL, etc. If you want to store a VCR code under CBL, etc., first follow the procedure for Direct Code Entry and press CBL in step 2 of Direct Code Entry, then enter ANY VCR code in step 3 of Direct Code Entry. Then follow the steps above for Code Search
Aug 29, 2012 | Televison & Video
Not remote control but remote code for a celcus tv
Just try a code search method. If your remote control have programmed in codes for your TV, it will respond. If not, make sure that the remote you have no code for your device, and it can't be setup with it.
Code Search
Most users will want to store VCR codes under the VCR button, Cable codes under CBL, etc. If you want to store a VCR code under CBL, etc., first follow the procedure for Direct Code Entry and press CBL in step 2 of Direct Code Entry, then enter ANY VCR code in step 3 of Direct Code Entry. Then follow the steps above for Code Search.
Jun 21, 2012 | Televison & Video
Ur8050t
There is no setup codes for Vizio TV with this remote control.
Just check this code, but not sure: 0081
Otherwise, make a code search:
Code Search
Jun 14, 2012 | Universal Remote Control Hampton Bay...
I have a 27 inch Jansen TV. Remote is lost. I have a universal remote. What codes do I need to program the remote ? and will this code work for all remotes we can buy from Target or Wal-Mart ?
Hello
Three digit remote setup codes for Jensen TV are:
004/ 009
Four digit codes are:
0004 0009 0133
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand
CODE SEARCH METHOD
OK.
Aug 18, 2011 | Jensen Q2749J 27" TV
Setup Code for Direct TV
To Whom i may concern,
Here are some codes from Directv that should work with that remote and television.
10171, 11326, 10463, 10150, 10154
If you still need help trying to program your remote please feel free to cantact me by phone @(361)510-0339 my name is Jonas and I am a Directv Installer/ Techniciain Specialist
Jun 12, 2009 | Televison & Video
Direct TV remote does not control TV on/off or volume.
I have the same setup like you. Direct TV and Emerson LCD TV. The Direct TV remote stores a limited amount of codes and none worked on my TV. Sadly it's not something you can update. They seem to only stick with the popular codes. Welcome to the "head of the curve" like me. lol
Jan 04, 2009 | Televison & Video
Direct tv recorder and Vivitek V37835 46 in. LCD remote code for controller
IN THE GOOGLE SEARCH ENGINE TYPE VIVITEK V37835 MANUAL. ONCE YOU GET THE MANUAL LOOK IN THE SECTION OF THE MANUAL THAT SAYS SETUP CODES FOR SATTELITE RECEIVERS. FOLLOW THE INSTRUCTIONS FOR PROGRAMMING UR REMOTE. ALSO WANT TO LET YOU KNOW THAT I HAVE DISH SATTELITE AND I USE MY VIVITEK REMOTE NOT THE SATTELITE REMOTE FOR MY PROGRAMMING. MAYBE TRY THIS. IT WORKS FOR ME.
Oct 18, 2007 | Vivitek V37835 46 in. LCD Television
Sony KDL32L5000 32 in. LCD HDTV Logo
75 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
