Question about Dryers
Whirlpool dryer awz 7819 Don t do nothing , don t turn on, no light,nothing.
  • 55 Answers
SOURCE: Whirlpool AWZ 3303 Tumble Dryer
http://www.whirlpool.co.uk/ifudocs/501930700361GB.pdf
Posted on Mar 25, 2008
smartr10U
  • 1305 Answers
SOURCE: Whirlpool Gas Dryer LGR4634EQ2 is not getting hot,
You may have damaged the glow bar gas ignitor when cleaning the dryer.. it's a ceramic element that gets brittle after it has been used. And if you bang into it with a vacuum hose or tool or whatever while you're cleaning it, it can crack or break....try cycling the dryer and watch the ignitor while it attempt to heat up... if there isn't any glow at all, its the ignitor... it's a simple job to swap it out...
Let me know if that doesn't work...
KEN
Posted on May 09, 2009
SOURCE: Whirlpool AWZ 650 condenser dryer
MY FILTER LIGHT IS ONN ALL THE TIME, HOW DO I CLEAN THE FILTER...WHERE IS IT, IS IT THE ONE BELOW THE FRONT DOOR THAT PULLS UP AS IN THAT CASE I'VE CLEANED THAT?
Posted on Aug 27, 2009
rogrrabbit
  • 986 Answers
SOURCE: Whirlpool AWZ 7303 tumbling but not drying.
blower wheels will get loose in dryers. Sometimes they will get a whole lump of lint in them or you can hear a rattling noise in the dryer, this is the blower wheel, its worn out and it can cause the fuse to blow too,or it can half *** work and take fifty forever's to dry the clothes.Or it could be just that the dryer needs a good blowing out .I use a lawn blower to get all the lint out of the dryer as well as the vent pipe and vent to outside. I take the filter HOUSING out and wash it also. That is, I remove the housing and clean is good! Making sure that the dryer is properly flowing air is a good thing!
Posted on Sep 12, 2009
SOURCE: have to replace broken belt on a whirlpool awz
Double the belt and slide it between the two arms of the tension pulley. Then slip the belt over the drive motor pulley. The belt will be pushing against the tension pulley from underneath.
Posted on Sep 30, 2010
Trying to get the service Manual for awz 3477 whirlpool dryer. The heating element goes on but after about 5 minutes it turns off + lint light goes on. Have cleaned the traps. thinking thermostat?
Have you cleaned the sensor bar? Did you remove the grates and clean out the lint traps, not the filter the actual traps? Does it have any codes stored? Most modern dryers can give error codes (even ones without a display)
Oct 13, 2016 | Whirlpool Dryers
Whirlpool dryer AWZ 8578, power is going into the
2 things stops your drum from turning ist thing to check is belt broken you take the top off and look into and you will be able to see if iis broken if that is ok then you will have to check the compasitor it on the side it like a big fuse
Oct 13, 2014 | Dryers
Awz 8676
Try this link http://tumble-dryers.tech-specs.com/whirlpool-awz-8676-n30037723
Aug 29, 2014 | Whirlpool Dryers
WHIRLPOOL AWZ 410-1000 parts
I bought before through Ebay , might get it cheaper there though .
Just make sure you got the right part number :) and search it ..
Regards,
Feb 19, 2013 | Whirlpool AWZ410 Front Load Washer/Dryer
I have a whirlpool dryer model AWZ 3513 and the filter light is on but the filter is spotless and I have cleaned out the extract tube
If the ambient air temperature is below 10 Degrees C the drier will not work and I think the filter light is a warning for the temperature as well.
Nov 29, 2010 | Whirlpool AWZ7303 Electric Dryer
HOW DO I LOCATE THE HEATING ELEMENT ON THE 6TH SENSE DRYER
take the back panel off it is located in the rear.
Mar 19, 2010 | Whirlpool Dryers
How to clean a whirlpool awz7913 condenser tumble dryer heat exchanger
how do i clean my heat exchanger on the whirlpool awz 7913 condenser tumble dryer?
Jan 19, 2010 | Whirlpool Dryers
Whirlpool tumble dryer model NO- AWZ 121/3-belt replacement
how do i replace my belt on my tumble dryer
Jan 09, 2010 | Whirlpool Dryers
Dryers Logo
65 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
