Question about Vacuums
Electrolux pri 1
Haw do i open
The beater bar of my Electrolux T8 vacuum doesn't work. No hairs show wrapped around the bar. How do I open the bottom to check it out? It seems to be in two sections, but removing the screws doesn
You probably need a new belt,or maybe a hose.To take the nozzle apart there a screws at the bottom of the head.Take them out then just wiggle and gently pry to top off. Chris
Oct 11, 2014 | Electrolux Access T8 Hepa Bagless Canister...
How to disassemble Electrolux Genisis XL upright to remove roller brush? I have removed all the screws.
There are 2 square holes on the bottom as well. Inside these holes are tabs that need to be released. Insert a medium straight screwdriver head into each hole and pry or twist to release the tabs. At that point, flip vacuum over and gently lift off top of power head.
Dec 18, 2010 | Electrolux Vacuums
How do you take of the base to change the belt? I removed the 4 screws but still cannot take the base off. I do not want to force (break) it... THANK YOU
If it's an Electrolux power head there will be a 5th screw same length in the base.2 at front corners, 1 front center, 2 mid way back all recessed.
Good for asking , do not pry it should pull apart in you hands starting at the front corners
Oct 12, 2009 | Electrolux Vacuums
Frayed power cord on electrolux canister vacuum
1 screw in the front, two in the blower port. take them out and the top bezel comes off. one screw in the bottom and two on the top. need a flat blade screw driver to pry out the cord reel. 4 screws holds the sheild of the reel. take them out and there is a snap ring that hold the reel on the shaft. the reel assembly and drum spring comes out at the same time. 3 screws on the bottom of the reel holding a metal plate and there is also snap ring hold the spring on the metal plate take that off and will expose the cord connection. unhook the the cord and untie the knot and replace the cord and reverse the process
Oct 04, 2009 | Electrolux UltraLux 2000 Bagged Canister...
Bag Full Sensor
Opening The Unit:
Remove the hose, open the door, and remove the bag. Making sure that the door is open wide enough, pull the rubber strip on each side of the canister toward the opening until they are completely removed. With a little shifting, you will now be able to pry open the top cover from the bottom. Remove the obstruction sensor hose so that you can completely separate the halves.
Note: If the strips will not move toward the front, the you will have to slide them off to the rear. You will need two screwdrivers to pry open the top rear of the unit far enough to release the back cover.
Locating The Switch:
The "trip" switch is located on the inside top cover under the power button. The trip switch is activated by the sensor valve next to it.
Aug 17, 2008 | Electrolux Epic 6500 Vacuum
I have Electrolux canister vac. The suction end pops open everytime it loads up.
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=689886
Generic problem for all Vacuums
Posted by wmcox on Jun 20, 2008
I have Electrolux canister vac. The suction end pops open every time it loads up.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. In the door there are vacuum lines that could be pinched or bent and are not letting air through to the bag, the system is designed that if the bag get to full or the air flow is restricted it will pop the door open and save the motor from burn out. This is repairable and nor to expensive and to check with the local vacuum cleaner dealer in your area or to call the Electrolux cust serv @ the factory for further information. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://electrolux.com/ Customer Service 1-800-896-9756
Electrolux Home Care Products – North America
P.O. Box 3900 Peoria, IL 61612
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jun 20, 2008 | Vacuums
Plastic Slides
use a screwdriver to pry up one end. there's a little nubbie that snaps into the canister, then its just a matter of pulling the strip off.
the back part with the rewind has two snaps on top internally. use a screwdriver to pry the back part down and out both sides and the rewind will come out.
Apr 12, 2008 | Electrolux Lux 7000 Bagged Canister Vacuum
Eleectrolux canister sweeper power switch
There should be screws holding the handle asembly on to the top. One near the from, another by the handle, then slide the door near the back, there are 2 more screws there. with the handle off, you can get to the switch. Hopefully you can fina a replacement, alot of parts for the older Electrolux is No Longer Available.
Feb 12, 2008 | Electrolux Guardian Bagged Canister Vacuum
How do i open a electrolux ultralux 2000
If I am right, there is a strip down the middle, on each side, they slide off then, the 2 halfs will come apart.
Jan 15, 2008 | Electrolux UltraLux 2000 Bagged Canister...
Electrolux Lux 7000 retractable power cord
The trim pieces along the sides just pull off seperating the two housings. The back portion where the retract drum is is held by two plastic tangs on top inside. use a screwdriver to pry the ring down to dislodge the tangs. the bottom part will lift off. remove the front part using two screws just below the hinge. the retract has a long coil spring wound around a free spinning hub. there are two "tangs" inside that engage a ratchet-pawl assembly. you'll need to rotate the drum to rewind the spring onto its hub.
Jun 06, 2007 | Electrolux Lux 7000 Bagged Canister Vacuum
Vacuums Logo
54 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
