Question about Panasonic Televison & Video
Where are the wall bracket mounting points
I have a Panasonic viera tx-p42c2b I lost the manual and want to double check that the 4 plastic screws in the back are the correct mounting points for a wall bracket
  • 47 Answers
Http://www.google.com/aclk?sa=l&ai=CLqs1A7ODU9OtBIrK-QPA-IKwBoCIxdEB0Jraiyv4iqKGCBAHILZUKAdQu_qDxvn_____AWDJhv6LzKTUGaAB1qjI_QPIAQGqBCZP0PZkJ7I-J_ocBTyzcwrIpK6rYGu1Mi06MnoWEdkzCSQSG132koAFkE6AB5LXtwKIBwGQBwI&num=7&sig=AOD64_171CwmbnF5QgQ0TlX6PmoqiuqNcw&rct=j&q=&ved=0CMIBENEM&adurl=http://manualsink.com/Panasonic-Manuals.aspx&cad=rja
Posted on May 26, 2014
  • Robert Peterson May 26, 2014
    http://www.google.com/aclk?sa=l&ai=C...
SOURCE: Attaching to wall mount
I want to remove my akai flat panel tv FROM the wall mount. The mount itself is attached to the wall by screws but it seems the tv had some type of nobs on the back that slid into slots on the mount. i cannot remember exactly how it was mounted 5 yrs ago. But the tv picture has blown and i need to remove it from the wall mount. I have tried lifting it to remove knobs on back of tv from slots but its seems locked. Can anyone help me with this problem.
Posted on May 15, 2008
ron1235
  • 11 Answers
SOURCE: Can't find inserts/holes needed to wall mount the television.
i went thru this with my tv.. you can pop off those caps, if there's no obvious way to remove them
then when you shop for a mounting system, get a bigger/ higher capacity mounting system with generic connector system.
Dont go for the cheapeast price.
Posted on Nov 30, 2008
  • 9 Answers
SOURCE: purchased universal wall mount kit for Samsung LN46B530
I have found that Home Depot and Lowe's (the bigger hardware stores) do not carry something like this. I alway got to my Local ACE Hardware where they have a whole isle with nothing but screws, nuts, bolts and fasteners. I always find what I am looking for there. So if you have a little hardware store in your area then I suggest trying them. It is alittle more expensive than the bigger guys but always worth it cause you can buy one, Two or 100.
Posted on Oct 03, 2009
budmrtn
  • 11361 Answers
SOURCE: screw size to bolt panasonic 32 inch lcd into
Metric M5 or M6, they should come with the mounting kit.
Posted on Dec 23, 2009
SOURCE: Wall mounting Panasonic Viera 32" tv
There's a little more elaboration required on the above post...You need to remember that the base has two long pins that go up into the TV. These pins are held in by two screws each. The screws are on each side of the TV (two vertical inline screws, inside a small inset section). Remove all four screws and the TV will come up off the base. Pull it straight and gently, but firmly, to unseat it from the pins.
Posted on Dec 28, 2009
I have a panasonic viera plasma tv model number TC-P60U50, where on tv do I put brackets to mount to the wall?
You will need to purchase a suitable wall mount separately. (You'll need one for LARGE TVs.) On the back of your TV set you'll see there are 4 holes in the lower-central region of the rear panel. They are about 20" apart (left-right) and about 12" apart (up-down) These should match up with the bracket that comes with your wall mount. You will need M8 metric screws that are about 1.25" long. These will also be included with the wall mount. (Which will include some general directions for wall mounting.)
Here is a manual for your TV:
PANASONIC Viera TC P60U50 Owner Manual Page 7
Feb 09, 2016 | Panasonic Televison & Video
CAN I GET SCREW HOLE SIZE OF BACK OF TV FOR WALL MOUNT
The 3 most common sizes for the bolts to mount the wall mount to the TV is either M8x20mm or M6x20mm or M4x20 depends on the size of the screen. This site has a chart that will show you what to look for, for your TV M6x20mm TV to Wall Mount Bracket Phillips Bolts Screws Stainless VESA 200
Aug 23, 2015 | Panasonic Viera TC-32LX85
How do i mount my panasonic tx-l26x10b on the wall. no fixing holes
drill holes put in wall plugs fix bracket insert and tighten screws
Aug 07, 2012 | Panasonic Televison & Video
Need to find user guide and owners manual
Hello;
I have lost the user manual to a Panasonic TX-32LXD700 32" TV. Does any one know of a link to download a copy?
Many thanks to any one who can help?
Feb 10, 2011 | Panasonic Viera TX-32LX70 32 in. LCD TV
Moen 3836...lost installation manual...what size drill bit for the hand held brkt.
There is no single answer that I can give you because it will vary due to material you are mounting to. If you are going to be mounting on ceramic tile or fiberglass shower wall I would recommend you use the plastic anchors that come with the bracket and mounting screws. Use drill size 3/16 drill holes and insert anchors. Mount bracket and screw in place. If you have hollow wall with nothing but sheetrock to hold the bracket I would get small butterfly anchors from hardware store and drill hole slightly larger than the wings on fastener when they are folded back along side the screws.If you have a wood backer board behind shower wall then drill holes with 1/8 inch bit and use screws long enough to reach through shower wall and sheet rock and mount bracket. Hope this helps you. Thanks P.S. If you have to drill thru ceramic tile you will need a carbide tipped bit.
Nov 26, 2010 | Moen Plumbing
How do i wall mount this tv
theres 4 fixing mounts at back of tv covered by plastic caps just remove those to mount
May 20, 2010 | Panasonic Viera TH-42PX80U Plasma TV
How do you remove the base inner bracket parts so that you can mount the TV on to a wall?
What make and model?
Most wall-mountable TVs will have threaded holes in the back for wall-mounting. Most of which you can bolt a bracket to then unscrew a few of the set-screws for the stand and slide the TV off of the stand.
Most TVs have 4 set screws for the stand located near the bottom middle of the TV where the stand inserts into the TV. The screws may be recessed fairly far into the back of the set and may require a long thin screwdriver.
Jan 01, 2010 | Panasonic TX-32LXD1 32 in. LCD Television
Cant get the stand off a panasonic 32 inch TX 32LXD60 to put on the wall
TX 32LXd60
Lay the tv face down on a flat surface. Do not scratch the screen ! Use a cloth.
Remove the 4 screws above the stand. Pull stand out. Replace screws.
You can get Operating Instructions from;
http://www.panasonic.co.uk/html/en_GB/Support/Downloads/220239/index.html#anker_220239
enter the model number- click search- and download the Operating Instructions . The Operating Instructions will illustrate the stand.
Apr 12, 2009 | Panasonic Viera TX-32LX70 32 in. LCD TV
What is the screw hole size in back of tv
The screw holes are metric. The set is supplied with M5x25 screws to attach the pedestal, so the wall mount screws will be in that same range.
Mar 01, 2009 | Panasonic Viera TH-42PZ80U Plasma TV
How do I remove the stand from a panasonic tv. model TX - 32LXD70
The stand is held on by four screws. Lay the tv face down on a flat surface. Cover the surface with a blanket first. Use a regular phillips screw driver. (If you have a users manual see page 7)
The screws are the set just above the stand on the back of the set. The stand will then slide out.
Jan 31, 2009 | Panasonic Viera TX-32LX70 32 in. LCD TV
Televison & Video Logo
70 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
