Question about Whirlpool Water Dispensing & Filtration
Model whelj1 whirlpool central water filtration system manual
josh1856
  • 105 Answers
SOURCE: Whirlpool side-by-side refrigerator - 2 problems
I would suggest that you get a certified person to come out and look at it you very well could have bent the doors in the move.
but... if you want to do it yourself.
click here for a walkthrough
for your drip:
Flush air from the water system the first time it is used and after replacing the filter. Air trapped in the water line or filter may slowly travel through the coiled water reservoir to the dispenser, pushing any water ahead of it. This can cause the dispenser to drip. Water needs to completely fill the lines for all air to be cleared.
  • Use a sturdy container to press and hold the water dispenser bar for 5 seconds, then release it for 5 seconds. Repeat until the water begins to flow. Once the water begins to flow, continue pressing and releasing the dispenser bar (5 seconds on, 5 seconds off) for an additional 2 minutes. Repeat if dripping starts again because air can re-enter from the water supply.
  • As air is cleared from the system, water may spurt from the water dispenser.
  • Make sure the refrigerator is connected to a cold water supply.
One or two drops of water immediately after dispensing is normal. It may be necessary to hold the container under the dispenser for 2 to 3 seconds after releasing the dispenser lever.
Posted on Jan 26, 2008
SOURCE: I have a pur water filtration system model fm-9400
Manual can be downloaded from PUR website.
http://www.purwater.com/manuals/HFM_OM_Final%202.pdf
Posted on Aug 27, 2009
  • 47 Answers
SOURCE: my icemaker quit making ice its a whirlpool ref.
i could bet my left leg that your solenoid coil has died. im guessing its still pumping water and getting cold.
Posted on Nov 11, 2009
  • 56 Answers
SOURCE: Filter for UltraEase water filtration system?
This may not be the problem now but by the sound of the malfunctioning water lines etc., it could be in the future. The start device on some models of refridgerator for maytag and whirlpool have been recalled. If your appliance was manufactured in the last 5-10 years you may be having an issue with this component. Mine recently caught on fire at this device that is located near the compressor. If you would like to be a part of the petition for a recall on this appliance contact me at jboooor@hotmail.com
Posted on Jun 10, 2010
bobicehouse
  • 1524 Answers
SOURCE: Whirlpool ice maker will not
The temperature lower then 19*F ?
Posted on Nov 02, 2010
Looking for water filter
The model number is probably ET8WTKXVB00 . If this is the correct model, it does not have a water filtration system. The manual is available from http://www.managemylife.com/mmh/owner_manuals/6142/WHIRLPOOL-Top-Mount-Refrigerator-L0604713?brand_name_search=ET8WTKXVB00 . Sears Parts Direct and other appliance parts stores have the parts diagrams and most replacement parts for the ET8WTKXVB00. No filter is listed and no add-on water filtration systems are available for the refrigerator.
I hope this helps. You could put a whole house filter before the water line gets to the refrigerator if you have a problem with the taste of the ice.
Sep 21, 2012 | Whirlpool Refrigerators
I get ice, but no water--water valve already replaced & lines checked for clogs. Could the problem be the quick disconnect at the bottom of the door.
The quick disconnect should have nothing to do with this problem. There is a micro switch behind the area you press the cup and that could be the problem or something has changed within your water filtration system.
Click Here=> sea_breeze_88.jpg Once there enter your model number and pull up user manual for your model. On page 7 of user manual there will be information about your Filtration System. You may also have a loose wire in the plug connection between the door and the cabinet. or item 72 in photo Here has become defective. Sometimes those switches get stuck on so you can see where that could become a problem. Let me know what you find HERE or here on Fixya, There are very few other possibilities so by doing these your answer will come soon, Thanks Sea Breeze
Feb 18, 2011 | Hotpoint HSS25GFT 25.0 Cu. Ft....
Jun 08, 2010 | Whirlpool 25.3 Cu. Ft. Side-by-Side...
How do I change a filter in a fridge that has a water filtration system, there are no instructions in the manual
WHEN YOU BUY THE REPLACEMENT FILTER IT SHOULD HAVE INSTRUCTONS WITH THE BOX BUT MOST FILTERS UNSCREW ABOUT A QUARTER TURN COUNTER CLOCKWISE THEN PULL OUT. ALLWAYS LAY A TOWEL UNDER TO CATCH ANY WATER THAT DRIPS
Jan 12, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
My icemaker quit making ice its a whirlpool ref. imperial series with an ultra ease water filtration system
Nov 10, 2009 | Whirlpool Freezers
Whirlpool refrigerator not cooling freezer seems to be working
my icemaker makes ice and water but the ice doesn't come out when pushing the button what is the problem?
Aug 30, 2009 | Whirlpool ED2FHEXNS 21.8 Cu. Ft....
This is a new whirlpool hot water heater.Pilot lights, burner fires, water heats up to temp. burner and pilot both shut down. Unit has to be started manually each time
LP OR NAT GAS , IF IT IS LP CHECK GAS PRESSURE @ TANK AND MAKE SURE NOT TO HIGH , IF NAT STILL COULD BE THE PROBLEM HAVE THE GAS COMPANY CK PRESSURE
Feb 22, 2009 | General Electric GE SmartWater Household...
Water Dispensing & Filtration Logo
64 people viewed this question
Top Whirlpool Water Dispensing & Filtration Experts
ray gallant
Bill Boyd
Tom Chichester
Are you a Whirlpool Water Dispensing and Filtration Expert? Answer questions, earn points and help others
