Question about Ford Vehicle Parts & Accessories
2005 jaguar x type 3.0 misses and judders in 4th gear...what is it?
    New Friend:
  • 21 Answers
Does the problem occur instantly as it goes into fourth? Or does it take time? You could be experiencing an electrical problem but I doubt it. The first thing I would do is change the fuel filter. If the problem persists then check the output fuel pressure from the pump. This is a silly thing but make sure you don't have any blown fuses. Also the car may have stored error codes. Checking these codes with a diagnostic tool can help point you in the right direction. Is the air intake system completely in tact? did you clean the mass airflow sensor?
I’m happy to help further over the phone at https://www.6ya.com/expert/louis_03c793f49b118a83
Posted on Apr 17, 2014
What is causing a couple of second judder when accelerating away after changing from 2nd to 3rd and 3rd to 4th gear ?
it may be from failing engine mounts allowing the engine to misalign the drive shaft under acceleration and allowing problems in the cv joints or "U" joint
May 12, 2016 | Ford Cars & Trucks
My 2005 Pontiac Bonneville GXP will not shift into 4th gear I was to it was a fourth gear band but is that the only problem that will cause itI'notto shift into 4th gear
Which transmission does yours have 4T65-E or 4T80-E ?
4T80-E
No Fourth Gear
Checks
Causes
1-2 Shift Solenoid Valve
Inoperative
Debris
Pinched wires
3-4 Shift Valve Bore Plug
Misassembled
4th Band
Burned, slipping, missing
4th Servo Cover
Cracked
4th Servo Pin
Broken, seized
4th Servo Piston
Damaged
4th Servo Seals
Rolled, cut or damaged
4T65-E
Slipping or No Fourth Gear
Slipping or No Fourth Gear Checks
Cause
DEFINITION: A large engine RPM increase is noted in fourth gear, Drive range, with little or no vehicle forward speed increase. First, second, and third gear operation are normal. Shifts into fourth gear are soft or do not occur. Fourth gear ratio is 0.705:1.
Automatic Transmission Fluid Level
Low fluid level
Transmission Main Line Pressure
Low transmission main line pressure
Oil Filter Assembly
• The oil filter assembly (100) is missing, plugged, or damaged.
• The oil filter seal assembly (101) is missing or is damaged.
Control Valve Body Assembly
• The 3-4 shift valve (362) or the 4-3 manual downshift valve (360) is stuck or binding.
• Debris is found in the passages of the control valve body (301) or of the control valve body spacer plate and gasket assembly (396)
Case Cover Assembly
Distortion or damage occurs at the manual valve (404) or at the case cover (401), causing PRN oil leak.
Driven Sprocket Support Assembly
A plugged third clutch oil passage in the driven sprocket support assembly (609)
Fourth Clutch Assembly
• The clutch plates (500-502) are worn, damaged, or misassembled.
• A missing or not seated fourth clutch spring retaining ring (601)
• A damaged spring assembly (602) or piston (603)
• Worn or damaged fourth clutch piston seals (604, 605)
Third Clutch Sprag Assembly
• The sprag (720) was misassembled or backwards on the inner race (661).
• A damaged third clutch sprag assembly (653, 661, 719-721)
Dec 06, 2015 | Pontiac Cars & Trucks
My 2005 jaguar s type stuck in reverse. Please help me
My 2005 S-Type was stuck in reverse but the gear stick was stuck in park. After taking the console apart trying to figure out why the shift lock wouldn't open...three hours later I got under the car and discover that one of the two bolts that held the transmission cable in place was missing...I replaced it and that was all it took.
Dec 20, 2012 | 2005 Jaguar S-Type
When accelorating. engine judders then picks up if revs kept high. the car is 2.2 56 plate
Mine does this. It's accompanied by what sounds like air escaping with a high pitched sound, usually when changing from first to second. Also, sometimes no grunt in first gear as if turbo not working, engine revs but car goes nowhere and then loads of black smoke comes out of back.
May 19, 2010 | 2005 Jaguar X-Type
Black smome on heavy acceleration and around 50mph judders ver slightly
black smoke is excess fuel ,clean air filter ,if air filter is ok then dealer only
Nov 13, 2009 | 2005 Jaguar X-Type
Cannot get the car into gear
usually a cable/linkage issue on s types and x types. cable stretches and a plastic clip breaks and you have to go to 3 or 4th on the automatic shifter to get it to engage. about a $400.00 repair. This is a very common issues on these model Jaguars.
Nov 08, 2009 | 2001 Jaguar S-Type
Jaguar 2.0 se diesel turbo power loss
Sound like you are looseing some boost from your turbo,check all your hoses from your turbo,if all of them are ok you may have a waste gate sticking, you need to check for movement there it only move very little but has alot to do with hp.Thanks And I hope this helps you
Sep 20, 2009 | 2005 Jaguar X-Type
I have a Jaguar 2L X type diesel, my problem is that the car has a slight jerking/juddering when driving. The engine management light is not illuminated and there seems to be plenty of power there when...
I have a Jaguar 2L X type diesel, my problem is that the carlb_icon1.png has a slight jerking/juddering when drivingicon1.png. The enginelb_icon1.png management light is not illuminated and there seems to be plenty of power there when accelerating.plz let me no a.s.a.p plz can you put pictures of the problems
Aug 31, 2009 | 2005 Jaguar X-Type
Vehicle Parts & Accessories Logo
26 people viewed this question
Top Ford Vehicle Parts & Accessories Experts
xxxxxx xxx
Thomas Perkins
Thomas Perkins
Colin Stickland
Colin Stickland
Are you a Ford Vehicle Part and Accessory Expert? Answer questions, earn points and help others
