Question about Harman Kardon AVR 500 Receiver
No radio from receiver
I can pick am / fm channels with no sound.speakers are working w/cd.No radio am or fm at all.
Trying to hook up speakers to Pyle Pro PD1000 stereo receiver w/built-in DVD/CD player. I believe that I have speaker wires hooked up correctly but when I play CD no sound. I can actually hearing sounds...
I went thru user manual..there is no special way of wiring speakers..
pls check carefully the speaker connections again and the "speaker selector" too..
what about "MUTE" button ? it should be "OFF" ...
and try to test it on FM radio first ..
just in case ,if you need the soft USER MANUAL pls visit the URL below..
1000 Watt AM-FM Receiver w/ Built-in DVD/MP3/USB
http://www.pyleaudio.com/sku/PD1000A/1000-Watt-AM-FM-Receiver-w-Built-in-DVDMP3USB
Jul 10, 2011 | Audio Players & Recorders
I am getting no sound through my speakers even though the display indicates that the volume is being turned up or down. this is the same for radio and cd.
Either the wires came disconnected from the wire harness in the back, or most likely the cd player is junk. If you blew your output channel, ITS DONE
Jan 11, 2011 | JVC AM FM CD DET FACE CAR STEREO
I have an ONKYO TX-SR606 receiver and I am trying to listen to FM radio using more than just the center channels. I have gone through the setup screens for the tuner and only Analog choices are available....
In reality the correct way to listen to radio or any music source for that matter is in 2 channel stereo. What this means is that the front left and right will play and also the subwoofer. If you absolutely want all your speakers to play while listening to fm, than press the Multi channel button and set it to direct, or any other sound field that you may desire.
Good Luck
Jan 08, 2011 | Onkyo TX-SR606 Receiver
Delphi skyfi2 Xm Radio Receiver car connection
Yes, you can buy an FM Direct adapter that will allow you to transmit directly to your car FM tuner, but if you have an older SkyFi2, the Fm transmitter is so strong, you can sit the radio on the floor and tune your car radio to your preset XM channel, like 107.1 FM and it will work great. Go into "Menu" and pick a channel that's not used locally.
Jul 12, 2010 | Delphi SKYFi2 SA10101 XM Radio Receiver
I have a 1999 Cadillac DeVille Concours with an AM/FM/Cassette/CD/RDS Radio. The AM works fine, the FM does not, screen shows digital info(stations like 99.3, etc) but no sound. RDS does not function at...
Well there's lots of possible reasons. The FM receiver portion of the radio is separate from the AM Band receiver, pre-amp, and amplifier sections of the radio. The FM receiver may have simply failed, as well as the CD player portion of the radio. Your car FM needs repair, you need a multimeter to check it or take it to a repair person. Please post further comments for further help or information......
Good Luck!!
Thanks
Jul 06, 2010 | Car Audio & Video
How to get TV audio on the FR300 radio?
Your TV band radio won't work anymore now that the US has switched to digital broadcasting. The frequencies now in use aren't the same now, so the radio can't receive them. Plus, the radio doesn't have the circuitry to decode the digital sound even if it could pick up the broadcasts.
Sad to say, you have a radio that now picks up only AM/FM/weather and static. Also, as far as I know, nobody is yet marketing a radio for TV sound with digital capability. All you can do during a power outage is use a new TV with battery capability and digital tuning.
Mar 02, 2010 | Eton FR300 AM/FM/Weather/TV Radio
The FM stations are not playing in my 1996 Nissan Maxima.
make sure the antenna is plugged into the back of the factory radio.
Jan 05, 2010 | Car Audio & Video
Hooked up a DURABRAND CD Stereo in my '97 Ford Expedition, because the old factory radio went dead, I got the proper Ford wiring harness for the stereo and proper mount. Every thing is getting power and...
because you have a built in factory amplifier that has to be bypassed. another option is to buy the kit that they make so you can USE your factory amplifier.
Jul 31, 2009 | Durabrand Car CD Player and AM/FM...
Cannot Get Antenna To Pick-Up Signal
If your roadyxt came in a red box then you need to hook up the XM SureConnect to your vehicles antenna. The instructions that come with it are simple and straight forward. Your FM transmitter will not work unless you hook up the sureconnect
Aug 25, 2006 | Delphi Roady XT XM Radio Receiver
Harman Kardon AVR 500 Receiver Logo
Top Harman Kardon Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Electro Med Services...
Are you a Harman Kardon Audio Player and Recorder Expert? Answer questions, earn points and help others
