Question about Samsung Computers & Internet
NP365E5C problems When I press the power button the fans turn on but nothing happens
PcExpert
  • 293 Answers
SOURCE: Power problem
NO POWER Maybe you have a faulty Power Cord try replacing that first. Secondly check your powersupply's Fan if its turning. Lastly check your power button maybe its defective. SWITCH PROBLEMS A trick can be done here. Unplug it then spray the switch (Soaked) with warm distilled water with mild soap. then let it dry using a Hair Dryer. Then test! If failed, Replace the switch. If Persists then There is a problem with the Main Board or Power Driver. FOR LONG BEEPS, ONE SHORT BEEP IN AN ENDLESS LOOP, BLUE SCREEN OF DEATH AT STARTUP Try using Memtest 86+ http://www.memtest86.com/ to diagnose your memory problem. You can also try the following methods. Turn off power, Unplug. Remove the cover of your PC. Remove the memory from the Motherboard. Note on the locks! Clean the memory contacts with an eraser yes that's right a rubber Pencil eraser. It should be shiny gold. Reseat your memory to the motherboard and Test! ====================== If you are having trouble with Newly bought items save your self from headaches by returning them and demand a replacement or a refund! You may have purchased a reconditioned\repaired\factory defect product.
Posted on Sep 20, 2007
SOURCE: Nothing happen when pressing the Start/Stop button.
One ov my decks (same Gemini PT-1000 II) had the same problem. Just open it and clean the micro switches underneath the big buttons. It worked fine for me.
Posted on Aug 05, 2008
mediarich
  • 188 Answers
SOURCE: Nothing happens when I press the power button except the light
Regardless if you don'r feel comfortable taking the comouter apart it needs to be taken apart and looked at. Depending on what got spilled inside the sooner the better. If it was a soda of some kind it could be bad.I would take out the battery and not try it again.
Posted on Oct 03, 2008
SOURCE: dell inspiron 2650 wont power up
the monitor imean the in built one would have shortcircuited from inside..
so u r facing the problem.
got it>??
contact a dell expert.
Posted on Dec 13, 2008
  • 29 Answers
SOURCE: Computer does not turn on when I press the power button
do u have the power adapter plugged in, or are you using battery power? the first thing i would try is disconnecting the battery. just compleatly remove it and set it aside. then try starting it with the adapter plugged in. sometimes the batteries go bad and are corrupt. i had this happen to a compaq laptop a few years back. after i got rid of the battery it worked fine. if it works u can always buy a new battery.
Posted on Feb 27, 2009
The problem is that when I press the 'Start' button, nothing happens. The clock is working, the fan is working, but I cannot cook anything even after I have entered the time and the power level
If when you press the start button the turntable starts but no heat then magnetron is faulty otherwise if nothing happens then the touchpad itself is faulty.
Oct 10, 2013 | Samsung 1.8 Cu. Ft. Over-the-Range...
I have a Hampton Bay Miramar 60 in ceiling fan, when you try to turn it on the upper light just blinks and nothing else happens. You can't even turn the blinking light off. HELP!!!
Turn off the breaker that controls power to the fan. Remove the batteries from the remote and press the buttons in case one is stuck. Reinstall batteries or new ones. Turn on the fan breaker and try using the remote again
Dec 16, 2012 | Universal Remote Control Hampton Bay...
2008 Mercury Mountaineer HVAC/Heater Fan button not operating
it will probably be the resistor. Check on you tube for detailed instructions and info.
Dec 14, 2017 | Mercury Mountaineer Cars & Trucks
I have a Gateway DX-4720-03 when I press the "ON" button it lights up briefly then goes out and computer will not boot. Fans do not come on. nothing happens. (If I press button again immediately nothing...
I would actually lean a little more towards the power supply being the problem. You can either have someone locally test it for you, or you can buy a power supply tester to check it out.
Aug 26, 2010 | Gateway DX4720-03 PC Desktop
Computer turn on, but when it does it won't POST
It seems like a motherboard issue. It heats up, thus is not able to turn on continuously. You may need to check internal parts embeded on the motherboard llike the fan and processor before you could know what needs replacement.
Jul 18, 2010 | Dell Dimension E521 PC Desktop
My laptop fell down and now my screen does not display anything
try to press and hold Fn and F8 - this is to toggle screen setting to ext and back to LCD on laptop. if nothing happens turn off computer by pressing power button, unplug the ac adapter, remove the battery. remvoe residual electricity from computer by pressing power button 10 times. just plug again the ac and leave the battery out. Pres and hold the letter D and while holding that press the power button once and release both of them. it will perform the built in self test on the lcd. if nothing happens, turn off computer. press anf hold Fn and while holding it press power button. it will perform diagnosis on computer. if still nothing happens need to repalce motherboard and LCD.
Mar 03, 2010 | Dell Inspiron 6000 Notebook
Had my laptop plugged in overnight. I turned it on
try to press the power button for more than 10 seconds and try to power it again
Jun 08, 2009 | Acer Aspire One PC Notebook
Wont turn on
If you press the power button and nothing happens, most likely you will need a new power supply.  If all the fans and whatnot come on when you press the power button, but you get no video, I would remove the RAM from the motherboard, and see if you get video.  If you are still getting no video, but the fans are all coming on, there is still a slight chance that it is your power supply, but most likely your motherboard.
Mar 30, 2009 | Compaq Presario 5000 PC Desktop
Computers & Internet Logo
13 people viewed this question
Top Samsung Computers & Internet Experts
270rexton
270rexton
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
