Question about Canon ImageRunner C3080i Color Copier
Message board wont go away
Message board will not go away from screen and can't copy, scan or email
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 46 Answers
Pls write down the message and machine details
Posted on Feb 17, 2014
How do I attach a hard copy to an email- HP Officejet 7500 E910
scan it to a file
Find program called hpscan in your list of all programs to scan to file.
This is usually what it is called with hp scanners
Note the directory that the file is scanned and saved to .
and then attach file to email message using attach file option on email program when you compose email message.
Apr 09, 2014 | HP Officejet 7500a E910 Multifunction...
When document is scanned to email--email copy shows a large yellow band down the left side of the document--shows everytime--replaced toner--cleaned everything--willl not go away
You need to isolate the problem first. Try scanning from the ADF and then scanning by placing the document on the glass. If the error shows on both then it is likley you have an issue with the scanner. If it only shows on the ADF copy then most likley the glass is dirty and needs to be cleaned. Curious as to why you replaced the toners to resolve a scanning issue? The scanner does not use any of the toner system, it is purely electronic.
Mar 22, 2011 | HP LaserJet 2840 All-In-One Printer
I do not have cartridges in my canon mp610 at the moment and there is a message on the screen that tell me that but it wont go away and when i try to scan it says on my mac that it is undergoing...
Without cartridges installed on a printer, it'll never run unless you install them. You'll see the error message and you'll not be able to do anything. If you have old cartridges, you can try. While there's an error message, you can't even scan or copy or print. So the only solution is to install the cartridges and do whatever you have to do with it.
Good luck..
Thanks for using FixYa.
Aug 22, 2010 | Canon MP610 Photo All-In-One Printer
Message says "Scanner Failure" and "Unable to scan or copy"
Obviously its scanner error,the whole scanner assembly needs replacement.It could be the bulb or the scanner board, but upon replacing it needs both.
Sep 17, 2009 | HP Photosmart C5280 InkJet Printer
Brother MFC-5840CN unable to scan
From Brother Customer Service email:
You can try the following reset - it will most of the settings back to the default options.
Unplug power cord to the machine.
Press and hold down Menu.
Plug power cord back in.
Let go if menu when fax/scan/copy flash.
You may see either "maintenance" or "machine error xx" on the screen.
Type stop/exit, 9, 1.
The machine should show "param init" or similar to show that the reset is being done.
It will then go back to or machine error.
Type stop/exit, 9, 9.
This should take the machine out of maintenance mode and back to normal.
If the error is still present the machine will require an engineer to resolve the issue.
Jul 08, 2008 | Brother MFC-5840CN All-In-One InkJet...
Error code 6A00
TThere is a prblem with the carriage lift mechanism.
Probale causes
1.PR Lift shaft assembly
2.Sheet Feed Unit
3.Logic Board
Send the printer for repair ,
Apr 21, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Canon ImageRunner C3080i Color Copier Logo
old marine
old marine
