Question about GE (PSS26MSRSS) Side by Side Refrigerator
Installing a water filter for a GE Profile TFX22PRXD fridge
How do I install a water filter for my fridge ?
  • 74 Answers
SOURCE: water leaks when filter is connected
Does it leak from the back or the front of the appliance ??
Posted on Aug 28, 2008
SOURCE: GE Profile side by side fridge - water dispenser doesn't work
More than likely, your water line is freezing up in the door. You can remove all of the ice cubes and lower the freezer temp to about 3. Leave the freezer door open for about 5 minutes or so and if this does not work, leave the door open a little longer. Also, disconnect the water line at the base of the freezer door, near the floor, and press the dispenser lever. If you have water there, you most likely have a frozen line in the door. Changing the water filter often will help but it is not the answer and is can get quite expensive. By the way, Make sure to hold the dispenser lever forward for at least a couple of minutes each time you test for water flow. If you do not get water at the connector at the base of the door after you have disconnected the line, you have a problem with the valve in the back of the refrigerator.
Posted on Nov 17, 2008
  • 172 Answers
SOURCE: GE Profile water filter housing leaks
Hi there is a grommet you can replace.
#WR02X10678 it is about $7.00 It can help seal the plug sometimes. Ge does want you to buy the whole filter assembly it is number
#WR17X11618 $51.50 . You may also consider putting a new filter in. It seals better than the plug it is number
#gwf $42.95. I dont know why they dont sell a o-ring kit. I guess they just dont make much money on o-rings. I hope this will help you. Have a nice day.
Michael Anderson
Anderson Appliance Repair
(865)945-3808
Posted on Feb 17, 2009
  • 531 Answers
SOURCE: odor in refrigerator/freezer
check the drip pan
Posted on Apr 02, 2009
jumptrout51
  • 3361 Answers
SOURCE: My GE Profile fridge periodically (eve other n) leaks water
Thaw out the defrost drain in the freezer. It has frozen over and the defrost water has nowhere else to go except on your floor.
Posted on Apr 08, 2009
Where are the duel water inlet valves located on ge fridge arctic profile
unless you have a water dispenser, top mount refrigerators usually only have a single inlet water valve. Either way, the valves will be located in the back on the machine and covered by the lower portion cover, but will have a small area for the water line to hook up. Just remove the lower panel in the back and you will be able to see it
May 22, 2012 | GE Profile Arctica Stainless Steel Top...
Ice tastes bad from ice dispenser in side by side LG fridge. Water from my tap is fine
Check your box for a filter. If not than buy one from hardware store. They are easy to install. Also try flushing the system. Just run water thru dispenser about gallon worth. Ihope this helps.
Aug 23, 2011 | GE Profile PSW26P Stainless Steel Side by...
I replaced my GE profile MWF water filter (identical GE part) and now I dont have water dispensing and don't have a working ice maker
Quite frequently carbon fines can be flushed from filter and plug the filter. If you have the bypass plug to replace the filter. Put that in and flush system completely. Take the filter and flush it at the kitchen sink. It is best to fill these with water before installing and flush the carbon fines before installing in fridge.
RJ
Mar 09, 2011 | GE Mwf Ge Refrigerator Smart Water Filter...
I have a GE MWF water filter that is dripping water into the refrigerator. Fridge is about 8 yrs old and have changed many of the MWF water filters. 1st time with this problem.
Many times fines from these filters become dislodged and plug up the filter housing. If you have the bypass plug for the filter, install it and run a couple gallons of water through fridge to flush the system completely. The install the filter again. Make sure none of the water lines feeding fridge are pinched or kinked and valve is on all the way.
RJ
Nov 30, 2010 | General Electric GE SmartWater Household...
GE Fridge - The water filter bypass plug is stuck
Should just take a quarter turn CCW to remove. You may loose a few drips of water, but the water shuts off automatically when the plug or a filter is removed. A wrench should not be needed to do this.
Jul 26, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Low water flow after changing the water filter in a gf profile re
Just a suggestion, you could try installing a filter on the water supply line to the fridge. A nice one should dramatically lessen the frequency of replacing the one in the fridge. As for your the pressure being low, look for a kink or pinch in the water supply line.
Sep 08, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Just installed new fridge; water is only trickling after 30 mins
check were you connect the water line water may not be flowing properly
Apr 03, 2009 | GE Profile PSW26P Stainless Steel Side by...
About 15 yr. ol GE Profile
YOU MIGHT NOT HAVE ONE ge started puting factory filters on in 1999 . you might have an inline one in the water line behind the fridge . but only if the homeowner or installer put one in , ge has nothing to do with it .... replacements at any hardware store
Feb 14, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
GE SmartWater Filter - Model MWF
make sure filter is installed correctly (not to doubt you but it can happen) make sure there isn't some foriegn object or packing materialetc in the filter end. You could have a bad filter. also make sure the unit is purged well
May 15, 2008 | Refrigerators
GE (PSS26MSRSS) Side by Side Refrigerator Logo
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
