Question about Intel Desktop Board DH61CR - Classic Series - motherboard - micro ATX - LGA1155 Socket - H61
What is watts usages for DH61CR Classic series
    New Friend:
    Problem Solver:
  • 6 Answers
How many volts is 1200 watts
Watts to volts doesn't translate as they are different units to measure things. Watts is a power measurement while volts is what is trickling through the cable. You could have 12 volts at 6000 watts or 240 volts and 5 watts, depends on usage. If it's for a car audio amp, it will be generally 12 volts to power it which at 1200 watts means it will run at around 100 amps current according to ohmslawcalculator.com
Oct 14, 2014 | Car Audio & Video
Remove BIOS password
take out the cmos battery wait one min then put it back in
Mar 18, 2014 | Computers & Internet
Reset bios motherboard
Here's how to recover your BIOS http://downloadmirror.intel.com/19802/eng/DH61CR_ProductGuide03_English.pdf
If you want to clear the bios look for jumpers near the bios chip that say BIOS clr
What do i have to know about watts in order to work out each appliances power usage aday
Add up all the wattages of the appliances you are using when they come on and go off including lights. fridges. freezers, fans , stoves, tools and every thing. add them all up and you will get thousands of watts called kilo watts . see how many you use per hour and you will get a kilowatt/hr usage rate. Find out the power cost per kilowatt/hr and multiply the usage by the cost and you have your answer. Or you can get a wireless transmitter that is clamped around the input line to your premises and it transmits to a receiver to inside your house (mine sits on the fridge) and it tells you the cost as everything is running . press the mode button and you get progressive cost and other modes are there as well. It is great because if I forget and leave the pool running I can see at a glance that something drawing a lot of power is running so I can check it out and turn it off. Ask you power provider about it or a good electrical shop.
Oct 07, 2013 | Computers & Internet
Will a dh61cr board take a 75w + gfx card
nah u can't the two cards must be the same *clones* with sli feature for nvidia cards
or crossfire for ati cards
Oct 31, 2012 | Nvidia Computers & Internet
Hi. I have a 5000 watt inverter in my truck. The alternator in the truck is a 150? amp alternator. I also have 3 deep cycle batteries (about 150 ah each) to run the inverter. Is this overkill for my...
A 5000 wat inverter is very large. Your alternator could not supply it alone without the batteries. The moderate to low usage is the key. Calculate the wattage of the load you want to connect. Depending on what else you're doing with the truck, lights, heater, air condition etc, you could probably draw somewhere between 1,0000-1500 watts on that alternator. Rember even if your alternator is rated for 150amps (large alt) it is not a 100% duty cycle. Alternators are usually around 50% duty cycle, so figure about 75amps continuous, or around 900 watts. That's considerably less than your 5,000 watt inverter. Buy a generator.
Jul 01, 2010 | Inverter Aims Pure Sine Wave Power...
Standby power usage of the 42" Vizio Gallevia?
According to a Cnet review of the 42" Vizio Gallevia, the standby power usage is only .75 watts. Because it is so low, I now have no concern about leaving the set in standby mode. Virtually no savings to be realized by unplugging the set between usage.
May 18, 2009 | Vizio Gallevia GV42LF 42 in. LCD...
Shuts down during high graphics usage
get a new 450 watt to 500 watt power supply
Jan 18, 2009 | In Win (IW-ISP300J2-0) (isp300j20)...
Checking power consumption
you need a clamp on amp probe, a multimeter wont hack it. if you can get a amp probe, you first seperate the wires on your cord and then place the probe over one of the wires only this will give you your consumption. by the way, your approx usage of watts on a 26 inch lcd tv would be 160 watts. models do vary.
Mar 29, 2008 | Televison & Video
Intel Desktop Board DH61CR - Classic Series - motherboard - micro ATX - LGA1155 Socket - H61 Logo
54 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
